Also see:
Part Numbers Index Main article for usage, photos, cross-reference Grille Front Bumper Core Support
Sunny Truck
To March 1978
RADIATOR GRILLE 1 62301 GRILLE KIT-FRONT 62302-G1000 STD 62302-H1003 DX 62302-H1003 ALL 7510-7803 2 96706-B0700 GROMMET-SCREW 5 3 08540-41040 SCREW 5 4 62312-H1026 ORNAMENT-FRONT 5 08915-43410 WASHER-plain 2 6 08915-13410 WASHER-lock 2 7 08911-10410 NUT 2 8 62410 FINISHER-HEAD LAMP,RH (RIM) 62320-G1000 STD 62320-H1002 DX 62320-H1002 ALL 商B113 7510-7803 9 62411 FINISHER-HEAD LAMP,LH (RIM) 62321-G1000 STD 62321-H1002 DX 62321-H1002 ALL 商B113 7510-7803 10 96706-B0700 GROMMET-SCREW (fixing grille) 4 11 08510-41012 SCREW (fixing grille & rim) 8 12 08530-41290 SCREW (fixing rim) 2 13 08964-10440 NUT-sping (fixing rim) 2 14 62322-H1001 MOULDING-SURROUND,UPPER 15 62323-H1001 MOULDING-SURROUND,LOWER 16 62324-H1051 MOULDING-SURROUND SIDE,RH (with rubber) 17 62325-H1051 MOULDING-SURROUND SIDE,LH (with rubber) 18 62326-H1001 SEALING RUBBER 2 19 08540-41012 SCREW 6 20 08964-41090 SCREW 10
April 1978-October 1989: Coupe-style grille.
From October 1989
Sedan
To June 1972 (1971 and 1972 Model year)
1 62302-H1003 ASSY-GRILLE,RADIATOR SEDAN 2 96706-B0700 GROMMET-SCREW,GRILLE FIX (5) SEDAN 3 08540-41012 SCREW-TAPPING,GRILLE FIX (5) SEDAN 4 62320-H1002 ASSY-RIM,HEAD LAMP,RH SEDAN 5 62321-H1002 ASSY-RIM,HEAD LAMP,LH SEDAN 6 96706-B0700 GROMMET-SCREW,RIM FIX (4) SEDAN 7 08510-41040 SCREW-TAPPING,RIM FIX (4) SEDAN 8 08530-41212 SCREW-TAPPING,RIM FIX (2) SEDAN 9 08964-10410 NUT-SPRING,RIM FIX (2) SEDAN 10 62322-H1001 SURROUND-RADIATOR GRILLE, UPPER SEDAN 11 62323-H1001 SURROUND-RADIATOR GRILLE, LOWER SEDAN 12 62324-H1001 SURROUND-RADIATOR GRILLE, SIDE,RH SEDAN 12 62324-H1051 SURROUND-RADIATOR GRILLE, SIDE,RH,W/RU SEDAN 13 62325-H1001 SURROUND-RADIATOR GRILLE, SIDE,LH SEDAN 13 62325-H1051 SURROUND-RADIATOR GRILLE, SIDE,LH,W/RU SEDAN 14 62326-H1001 RUBBER-SURROUND,RADIATOR GRILLE (2) SEDAN 15 08540-41012 SCREW-TAPPING (6) SEDAN 16 08540-41012 SCREW-TAPPING 1 (10) SEDAN 17 62651-H7000 ASSY-BUMPER,FRONT SEDAN 0772- 17 62651-H1900 ASSY-BUMPER,FRONT SEDAN 18 62670-H1001 STAY-FRONT BUMPER,FRONT,RH SEDAN 19 62671-H1001 STAY-FRONT BUMPER,FRONT,LH SEDAN 20 62670-H7000 STAY-FRONT BUMPER (2) SEDAN 0772- 21 62663-27700 BOLT-BUMPER (4) SEDAN 21 62663-18000 BOLT-BUMPER (4) SEDAN 01135-00191 BOLT-BUMPER (4) SEDAN 22 08915-43610 WASHER-PLAIN (4) SEDAN 23 08915-13610 WASHER-SPRING (4) SEDAN 24 08911-10610 NUT-HEX (4) SEDAN 25 08124-23010 BOLT-HEX (4) SEDAN 26 08134-23510 BOLT (4) COUPE 0772- 27 08915-53810 WASHER-PLAIN (4) SEDAN 28 08915-44210 WASHER-PLAIN (4) SEDAN 0772- 29 08915-14210 WASHER-LOCK (4) SEDAN 0772- 30 62680-H7000 BRACKET-BUMPER STAY FRONT,RH SEDAN 0772- 31 62681-H7000 BRACKET-BUMPER STAY FRONT,LH SEDAN 0772- 32 08110-82062 BOLT (6) SEDAN 0772- 33 08915-43810 WASHER-PLAIN (6) SEDAN 0772- 01135-00191 BOLT-BUMPER,B (4) SEDAN 34 62663-18000 BOLT-BUMPER,B (4) SEDAN 34 62663-27700 BOLT-BUMPER,B (4) SEDAN 0772- 35 08911-10610 NUT (4) SEDAN 0772- 36 08915-43610 WASHER-PLAIN (4) SEDAN 0772- 37 08915-13610 WASHER-LOCK (4) SEDAN 0772- 38 62672-H1001 BRACKET-FRONT BUMPER SIDE,RH SEDAN 39 62672-H7000 BRACKET-FRONT BUMPER,SIDE,RH SEDAN 0772- 40 62673-H1001 BRACKET-FRONT BUMPER,SIDE,LH SEDAN 41 62673-H7000 BRACKET-FRONT BUMPER,SIDE,LH SEDAN 0772- 42 62663-27700 BOLT-BUMPER (2) SEDAN 42 62663-18000 BOLT-BUMPER (2) SEDAN 43 08911-10610 NUT-HEX (2) SEDAN 44 08915-43610 WASHER-PLAIN (2) SEDAN 45 08915-13610 WASHER-LOCK (2) SEDAN 46 08360-62014 BOLT-HEX (2) SEDAN 47 62678-21000 SHIM-BRACKET (2) SEDAN 48 08915-43610 WASHER-PLAIN (2) SEDAN 49 08110-61662 BOLT-WITH LOCK WASHER (4) SEDAN 50 08915-43610 WASHER-PLAIN (4) SEDAN 51 62674-H1900 OVERRIDER-FRONT BUMPER RH SEDAN 0772-0672 52 62674-H7000 OVERRIDER-FRONT BUMPER RH SEDAN 0772- 53 62675-H1900 OVERRIDER-FRONT BUMPER LH SEDAN 0772-0672 54 62675-H7000 OVERRIDER-FRONT BUMPER LH SEDAN 0772- 55 85024-H1900 RUBBER-OVERRIDER (2) SEDAN 0772-0672 56 08114-01610 BOLT (4) SEDAN 0772- 57 08915-44010 WASHER-PLAIN (4) SEDAN 0772- 58 08915-14010 WASHER-LOCK (4) SEDAN 0772- 59 62682-H7000 HOOK-TIE DOWN,RH SEDAN 0772- 60 62683-H7000 HOOK-TIE DOWN,LH SEDAN 0772-
From July 1973 (1973 Model year)
Coupe
1 62302-H1800 GRILLE-RADIATOR COUPE 2 08963-10510 NUT-SPRING TYPE A M5 1 (10) COUPE 3 08510-51012 SCREW-TAPPING TYPE 1 M5 (4) COUPE 4 08915-43510 WASHER-PLAIN 1 (10) COUPE 5 08510-52010 SCREW-TAPPING TYPE 1 M5 (6) COUPE 6 62322-H1001 SURROUND-RADIATOR GRILLE UPPER COUPE 7 62323-H1001 SURROUND-RADIATOR GRILLE LOWER COUPE 8 62324-H1001 SURROUND-RADIATOR GRILLE SIDE RH COUPE 8 62324-H1051 SURROUND-RADIATOR GRILLE SIDE RH W/RU COUPE 2 62324-H1001 9 62325-H1001 SURROUND-RADIATOR GRILLE SIDE LH COUPE 9 62325-H1051 SURROUND-RADIATOR GRILLE SIDE LH W/RU COUPE 2 62325-H1001 10 62326-H1001 RUBBER-SURROUND RADIATOR GRILLE (2) COUPE 11 08540-41012 SCREW-TAPPING M4 (6) COUPE 12 08540-41012 SCREW-TAPPING M4 1 (10) COUPE 13 62500-H1800 ASSY-SUPPORT RADIATOR CORE COUPE 14 62510-H1800 RAIL-SUPPORT RADIATOR CORE UPPER COUPE 15 62522-H1001 STAY-HOOD CATCH COUPE 16 62610-H1800 ASSY-PANEL APRON FRONT COUPE 17 62651-H1900 ASSY-BUMPER,FRONT COUPE 17 62651-H1001 ASSY-BUMPER FRONT COUPE 2 62651-H1000 17 62651-H1000 ASSY-BUMPER FRONT COUPE 18 62651-H7000 ASSY-BUMPER,FRONT COUPE 0772- 0 62651-H1900 19 62670-H1001 STAY-FRONT BUMPER FRONT RH COUPE -672 2 20 62671-H1001 STAY-FRONT BUMPER FRONT LH COUPE -672 2 21 62670-H7000 STAY-FRONT BUMPER (2) COUPE 0772- 0 62670-H1001 22 62663-18000 BOLT-BUMPER B BUMPER TO STAY (4) COUPE 23 08915-43610 WASHER-PLAIN M6 BUMPER TO STAY (4) COUPE 24 08915-13610 WASHER-SPRING M6 BUMPER TO STAY (4) COUPE 25 08911-10610 NUT-HEX M6 BUMPER TO STAY (4) COUPE 26 08124-23010 BOLT-HEX WITH LOCK WASHER STAY TO HOOD (4) COUPE 27 08134-23510 BOLT-STAY TO HOOD LEDGE (4) COUPE 0772- 28 08915-53810 WASHER-PLAIN M8 STAY TO HOODLEDGE (4) COUPE 29 08915-44210 WASHER-PLAIN (4) COUPE 0772- 30 08915-14210 WASHER-LOOK (4) COUPE 0772- 31 62680-H7000 BRACKET-BUMPER STAY FRONT RH COUPE 0772- 32 62681-H7000 BRACKET-BUMPER STAY FRONT LH COUPE 0772- 33 08110-82062 BOLT-STAY TO BRACKET (6) COUPE 0772- 34 08915-43810 WASHER-PLAIN (6) COUPE 0772- 35 62663-27700 BOLT-BUMPER B,BUMPER TO BRACKET (4) COUPE 0772- 35 62663-18000 BOLT-BUMPER B,BUMPER TO BRACKET (4) COUPE 0772- 2 62663-27700 36 08911-10610 NUT (4) COUPE 0772- 37 08915-43610 WASHER-PLAIN (4) COUPE 0772- 38 08915-13610 WASHER-SPRING (4) COUPE 0772- 39 62672-H1001 BRACKET-FRONT BUMPER SIDE RH COUPE 40 62672-H7000 BRACKET-FRONT BUMPER SIDE RH COUPE 0772- 0 62672-H1001 41 62673-H1001 BRACKET-FRONT BUMPER SIDE LH COUPE 42 62673-H7000 BRACKET-FRONT BUMPER SIDE LH COUPE 0772- 0 62673-H1001 43 62663-27700 BOLT-BUMPER B BRACKET TO BUMPER (2) COUPE 43 62663-18000 BOLT-BUMPER B BRACKET TO BUMPER (2) COUPE 2 62663-27700 44 08911-10610 NUT-HEX M6 BRACKET TO BUMPER (2) COUPE 45 08915-43610 WASHER-PLAIN BRACKET TO BUMPER (2) COUPE 46 08915-13610 WASHER-LOCK BRACKET TO BUMPER (2) COUPE 47 08360-62014 BOLT-HEX WITH SPRING WASHER BUMPER SIDE (2) COUPE 48 62678-21000 SHIM-BRACKET BUMPER SIDE TO FENDER (2) COUPE 49 08915-43610 WASHER-PLAIN BUMPER SIDE TO FENDER (2) COUPE 50 62611-H1000 COVER-UNDER FRONT COUPE 51 08915-43610 WASHER-PLAIN (4) COUPE 52 08915-13610 WASHER-LOCK (4) COUPE 53 08110-62010 BOLT-HEX M6X1.0 (4) COUPE 54 62674-H1900 OVERRIDER-FRONT BUMPER,RH COUPE 0772- 55 62675-H1900 OVERRIDER FRONT BUMPER LH COUPE -672 2 56 62674-H7000 OVERRIDER-FRONT BUMPER,RH COUPE 0772- 0 62674-H1900 57 62675-H7000 OVERRIDER-FRONT BUMPER,LH COUPE 0772- 0 62675-H1900 58 85024-H1900 RUBBER-OVERRIDER (4) COUPE -672 2 59 08114-01610 BOLT (4) COUPE 0772- 60 08915-44010 WASHER-PLAIN (4) COUPE 0772- 61 08915-14010 WASHER-LOCK (4) COUPE 0772- 62 62682-H7000 HOOK-TIE DOWN,RH COUPE 0772- 63 62683-H7000 HOOK-TIE DOWN,LH COUPE 0772-
