1200 Disc Brake Swap
Revision as of 22:26, 22 January 2012; view current revision
Category: Brake Modifications
Swapping your front drum brakes to disc brakes is a worthwile easy upgrade.
If your 1200 has all-drum brakes, take note that disc brakes are:
  • easier to work on
  • More resistant to fading -- safer after repeated stops (they dissipate heat far better)
Swapping 1200 drums for discs is easy if you obtain the entire strut/spring/brake assemblies for both sides. Just unbolt, bolt in the new assembly and bleed the front brakes.
Details
<please add>
