Also see:
Part Numbers Index Main article for usage, photos, cross-reference Door Door Glass Weatherstripping
Sedan
1 80102-H1200 ASSY-PANEL FRONT DOOR WITH SASH RH SEDAN 2 DOOR 1 80102-H7000 ASSY-PANEL FRONT DOOR WITH SASH RH SEDAN 2 DOOR 0772- 2 80103-H1200 ASSY-PANEL FRONT DOOR WITH SASH LH SEDAN 2 DOOR 2 80103-H7000 ASSY-PANEL FRONT DOOR WITH SASH LH SEDAN 2 DOOR 0772- 3 80152-H1200 PANEL-FRONT DOOR OUT SIDE RH SEDAN 2 DOOR 4 80153-H1200 PANEL-FRONT DOOR OUT SIDE LH SEDAN 2 DOOR 5 80210-H1201 ASSY-SASH FRONT DOOR RH SEDAN 2 DOOR 6 80211-H1201 ASSY-SASH FRONT DOOR LH SEDAN 2 DOOR 7 80270-H1001 ASSY-FRAME DOOR VENTILATOR RH SEDAN 2 DOOR 8 80271-H1001 ASSY-FRAME DOOR VENTILATOR LH SEDAN 2 DOOR 9 80244-H1001 GLASS-DOOR VENTILATOR RH TEMR T=4.0MM SEDAN 2 DOOR 9 80244-H1101 GLASS-DOOR VENTILATOR RH TINTED & TEM SEDAN 2 DOOR (OP) 10 80245-H1101 GLASS-DOOR VENTILATOR LH TINTED & TEM SEDAN 2 DOOR (OP) 11 80250-H1001 ASSY-CHANNEL VENTILATOR GLASS RH SEDAN 2 DOOR 12 80251-H1001 ASSY-CHANNEL VENTILATOR GLASS LH SEDAN 2 DOOR 13 80247-H1000 WASHER-STOP (2) SEDAN 2 DOOR 14 80248-H1000 SPRING (2) SEDAN 2 DOOR 15 H0285-H1000 RUBBER-GLAZING DOOR VENTILATOR (2) SEDAN 2 DOOR 15 80246-H1000 PUBBER GLAZING DOOR VENTILATOR (2) SEDAN 2 DOOR 16 80260-H1000 ASSY-CATCH HADLE RH SEDAN 2 DOOR 17 80261-H1000 ASSY-CATCH HANDLE LH SEDAN 2 DOOR 18 80238-H1001 BRACKET-PIVOT TOP LOW (2) SEDAN 2 DOOR 19 80234-H1000 WASHER-BRACKET PIVOT (2) SEDAN 2 DOOR 20 80284-H1000 WASHER-RUBBER A (2) SEDAN 2 DOOR 21 80285-H1000 WASHER-RUBBER B (2) SEDAN 2 DOOR 22 08330-41020 SCREW-MACHINE M4 3 (32) SEDAN 2 DOOR 23 80292-73000 RIVET-SPECIAL (2) SEDAN 2 DOOR 24 80282-H1001 WEATHERSTRIP-DOOR VENTILATORRH SEDAN 2 DOOR 25 80283-H1001 WEATHERSTRIP-DOOR VENTILATORLH SEDAN 2 DOOR 26 80336-H1000 RUBBER-GLASS RUN B SEDAN 2 DOOR 26 80336-H1001 RUBBER-GLASS RUN B SEDAN 2 DOOR 1070- 26 80336-H1800 RUBBER-GLASS RUN SEDAN 2 DOOR 26 80336-H1801 RUBBER-GLASS RUN SEDAN 2 DOOR 27 08420-41012 SCREW-MACHINE M4 FIXING VENTTO SASH (6) SEDAN 2 DOOR 28 08915-53610 WASHER-PLAIN 6 FIXING VENT TO INNER PAN (2) SEDAN 2 DOOR 29 08915-13610 WASHER-SPRING 6 FIXING VENT TO INNER PAN (2) SEDAN 2 DOOR 30 08410-61012 SCREW-MACHINE M6 FIXING VENTTO INNER PAN (2) SEDAN 2 DOOR 31 80310-H1200 GLASS-DOOR WINDOW TEMP T=4.0MM RH SEDAN 2 DOOR 31 80310-H1300 GLASS-DOOR WINDOW TEMP TINTED T=4.0 SEDAN 2 DOOR (OP) 32 80311-H1200 GLASS-DOOR WINDOW TEMP T=4.0MM LH SEDAN 2 DOOR 32 80311-H1300 GLASS-DOOR WINDOW TEMP TINTED T=4.0 SEDAN 2 DOOR (OP) 33 80302-H1200 ASSY-BOTTOM CHANNEL FRONT RH SEDAN 2 DOOR 33 80302-H1201 ASSY-BOTTOM CHANNEL FRONT RH SEDAN 2 DOOR 1070- 34 80303-H1200 ASSY-BOTTOM CHANNEL FRONT LH SEDAN 2 DOOR 34 80303-H1201 ASSY-BOTTOM CHANNEL FRONT LH SEDAN 2 DOOR 1070- 35 80316-H1200 RUBBER-GLEZING (2) SEDAN 2 DOOR 36 80335-H1200 RUBBER-GLASS RUN 'A' (2) SEDAN 2 DOOR 36 80335-H1201 RUBBER-GLASS RUN 'A' (2) SEDAN 2 DOOR 36 80335-H1202 RUBBER-GLASS RUN"A" (2) SEDAN 2 DOOR 1070- 37 80400-H1000 ASSY-HINGE FRONT DOOR UPPER RH SEDAN 2 DOOR 37 80400-H1001 ASSY-HINGE FRONT DOOR UPPER RH SEDAN 2 DOOR 37 80400-H7000 ASSY-HINGE FRONT DOOR UPPER RH SEDAN 2 DOOR 0772- 38 80401-H1001 ASSY-HINGE FRONT DOOR UPPER LH SEDAN 2 DOOR 38 80401-H7000 ASSY-HINGE FRONT DOOR UPPER LH SEDAN 2 DOOR 0772- 38 80401-H1000 ASSY-HINGE FRONT DOOR UPPER LH SEDAN 2 DOOR 39 H0400-73002 BUSH-DOOR HINGE UPPER (4) SEDAN 2 DOOR 40 80402-H1000 ASSY-HINGE FRONT DOOR LOWER (2) SEDAN 2 DOOR 40 80402-H1001 ASSY-HINGE FRONT DOOR LOWER (2) SEDAN 2 DOOR 41 H0402-H1001 BUSH-DOOR HINGE LOWER (4) SEDAN 2 DOOR 42 77720-89913 BOLT-SPECIAL M8 FILLER FIX 1 (12) SEDAN 2 DOOR 42 08120-82062 BOLT-SPECIAL M8 FILLER FIX 1 (12) SEDAN 2 DOOR 0570- 43 77740-89912 WASHER-PLAIN M8 FILLER FIX 1 (12) SEDAN 2 DOOR 44 08120-82062 BOLT WITH SPRING LOCK WASHERDOOR FIX 1 (12) SEDAN 2 DOOR 45 80212-H1200 ASSY-SASH LOWER FRONT RH SEDAN 2 DOOR 46 80213-H1200 ASSY-SASH LOWER FRONT LH SEDAN 2 DOOR
Coupe
1 80100-H7100 ASSY-PANEL FRONT DOOR WITH SASH RH COUPE 0772- 0 80100-H1800 1 80100-H1800 ASSY-PANEL FRONT DOOR WITH SASH RH COUPE 2 80101-H1800 ASSY-PANEL FRONT DOOR WITH SASH LH COUPE 2 80101-H7100 ASSY-PANEL FRONT DOOR WITH SASH LH COUPE 0772- 0 80101-H1800 3 80152-H1200 PANEL-FRONT DOOR OUT SIDE RH COUPE 3 80153-H1200 PANEL-FRONT DOOR OUT SIDE LH COUPE 4 80210-H1800 ASSY-SASH FRONT DOOR RH COUPE 5 80211-H1800 ASSY-SASH FRONT DOOR LH COUPE 6 80280-H1801 SET-COVER DOOR SASH RH COUPE 7 80281-H1801 SET-COVER DOOR SASH LH COUPE 8 80270-H1800 ASSY-FRAME DOOR VENTILATOR RH COUPE 9 80271-H1800 ASSY-FRAME DOOR VENTILATOR LH COUPE 10 80244-H1800 GLASS-DOOR VENTILATOR RH (ANTI-SUN T= COUPE 11 80245-H1800 GLASS-DOOR VENTILATOR LH (ANTI-SUN T= COUPE 12 80250-H1800 ASSY-CHANNEL VENTILATOR GLASS RH COUPE 13 80251-H1800 ASSY-CHANNEL VENTILATOR GLASS LH COUPE 14 80247-H1000 WASHER-STOP (2) COUPE 15 80248-H1000 SPRING (2) COUPE 16 H0285-H1000 RUBBER-GLAZING DOOR VENTILATOR (2) COUPE 16 80246-H1000 RUBBER-GLAZING DOOR VENTILATOR (2) COUPE 2 H0285-H1000 17 80260-H1800 ASSY-CATCH HANDLE RH COUPE 18 80261-H1800 ASSY-CATCH HANDLE LH COUPE 19 80238-H1800 BRACKET-PIVOT TOP LOW (2) COUPE 20 80234-H1000 WASHER-BRACKET PIVOT (2) COUPE 21 80284-H1000 WASHER-RUBBER A (2) COUPE 22 80285-H1000 WASHER-RUBBER B (2) COUPE 23 08330-51020 SCREW-MACHINE M5 (2) COUPE 24 80292-73000 RIVET-SPECIAL (2) COUPE 25 80282-H1800 WEATHERSTRIP-DOOR VENTILATORRH COUPE 26 80283-H1800 WEATHERSTRIP-DOOR VENTILATORLH COUPE 27 80336-H1801 RUBBER-GLASS RUN B (2) COUPE 7010- 2 80336-H1800 27 80336-H1800 RUBBER-GLASS RUN B (2) COUPE 28 80311-H1800 GLASS-DOOR WINDOW TEMP TINTED T=4.0 COUPE 29 80312-H1800 GLASS-DOOR WINDOW TEMP TINTED T=4.0 COUPE 30 80302-H1800 ASSY-BOTTOM CHANNEL FRONT RH COUPE 31 80303-H1800 ASSY-BOTTOM CHANNEL FRONT LH COUPE 32 80317-H1800 RUBBER-GLAZING (2) COUPE 33 80335-H1800 RUBBER-GLASS RUN 'A' (2) COUPE 33 80335-H1801 RUBBER-GLASS RUN 'A' (2) COUPE 7010- 2 80335-H1800 34 80400-H7000 ASSY-HINGE FRONT DOOR UPPER RH COUPE 0772- 2 80400-H1001 34 80400-H1000 ASSY-HINGE FRONT DOOR UPPER RH COUPE 34 80400-H1001 ASSY-HINGE FRONT DOOR UPPER RH COUPE 2 80400-H1000 35 80401-H7000 ASSY-HINGE FRONT DOOR UPPER LH COUPE 0772- 2 80401-H1001 35 80401-H1000 ASSY-HINGE FRONT DOOR UPPER LH COUPE 35 80401-H1001 ASSY-HINGE FRONT DOOR UPPER LH COUPE 2 80401-H1000 36 H0400-73002 BUSH-DOOR HINGE UPPER (4) COUPE 37 80402-H1000 ASSY-HINGE FRONT DOOR LOWER (2) COUPE 37 80402-H1001 ASSY-HINGE FRONT DOOR LOWER (2) COUPE 2 80402-H1000 38 H0402-H1001 BUSH-DOOR HINGE LOWER (4) COUPE 39 77720-89913 BOLT-SPECIAL M8 FILLER FIX 1 (12) COUPE 40 77740-89912 WASHER-PLAIN M8 FILLER FIX 1 (12) COUPE 41 08120-82062 BOLT-WITH SPRING LOCK WASHERDOOR FIX 1 (10) COUPE
