The B110 uses a steering gearbox integral (one unit) with the steering column. Optionally available was a collapsible-column unit for safety in case of a crash. The collapsible column was standard for USA models. The gearbox is a relatively fast 15:1 ratio with only 3.3 turns lock to lock, and used a quality recirculating-ball type system. The only problem was a bit of play, as is common to boxes of this type, but as the years have gone by many boxes are worn out. Unfortunately no other gearbox fits. New ones may be available from Nissan South Africa.
For modification-required swaps, see Steering Gearbox Swaps
The B210 and B310 units both have a seperate gearbox and column, joined by a flexible coupling. But these gearboxes will not bolt to the B110 subframe connection.
- B120: Type RB41N, 15.0:1 3.3 turns
- Available in standard or collapsible column types
- B210: 15.0:1 3.38+ turns
- B310 A12: Type RB43N 16.4:1 3.5 turns
- B310 A14/A15: Type BR45L 15.0:1 3.2 turns
- B310 Australia uses 16.4:1 model for all engine (per Gregory's)
48010-H1005 GEAR ASSY-STEERING B120
Steering Gear Pitman Shaft Seal * Oil Seal: Nitrile * Shaft Size=0.984" * Housing Bore=1.496" * Outer Diameter=1.505" * Width=0.276" National 222535 SKF 10173
Alternate Part Numbers: 013-8340-2, 052-3346, 089-409-085, 089-409-085B, 089409085C, 0928326016, 10171, 10173CHR, 10A-0143, 145810171, 145810173, 194740-55620, 222630, 26X38X5T, 26X38X6DG, 26X38X6R21P, 26X38X8HMS, 26X38X8HMSA, 26X38X8MHS, 26X38X8MHSA, 314360-4232-00, 3436454M1, 48137H1002, 65551A, 67453-00117, 67477, 70-7565, 71-10171, 8734980, 965810173, AB1463E0, AB1464E0, AE1306K, AE1306K0, AE1463E, CFW226X38X6, CH14736, CH14765, CHR 10173, CR10173, MHS26X38X8, N10171, N10173, NJ849, SBA334290180, SBA334290181, SBA334292001, W26X38X6R21P, ZAR10171, ZAR10173
USA Collapsible Gearbox & Column
LHD drive gearbox
48805-H1951 ASSY-GEAR,STEERING, COLLAPSIBLE 48850-H1900 ASSY-TUBE,JACKET 48011-H1601 ASSY-HOUSING,GEAR 48820-H1900 ASSY-SHAFT,COLUMN 48025-18000 BEARING-WORM 48103-H1002 SHAFT-SECTOR 48137-H1002 SEAL-OIL 48135-66000 SCREW-ADJUSTING 08911-3401A NUT 08911-34010 NUT 48133-66000 SHIM-SCREW,T=1.62 48134-66000 SHIM-SCREW,T=1.65 48131-66000 SHIM-SCREW,T=1.56 48130-66000 SHIM-SCREW,T=1.53 48132-66000 SHIM-SCREW,T=1.59 48201-18000 COVER-SIDE 48204-18000 PACKING-SIDE COVER 08931-10410 PLUG 08120-82010 BOLT 08915-13810 WASHER-SPRING 08911-24610 NUT 08915-14610 WASHER-LOCK 48031-18000 SHIM-COVER,T=0.05 48032-18000 SHIM-COVER,T=0.07 48033-18000 SHIM-COVER,T=0.08 48034-18000 SHIM-COVER,T=0.10 48035-18000 SHIM-COVER,T=0.12 48910-H1020 BUSH-COLUMN 48910-H1021 BUSH-COLUMN 48931-H1020 WASHER-PLAIN 00922-11700 RING-SNAP 08110-81210 BOLT 08915-13810 WASHER 48960-H1020 ASSY-CLAMP,STEERING POST 08915-13810 WASHER-LOCK 08110-81210 BOLT 08120-83010 BOLT 08915-53810 WASHER-PLAIN 48361-H1000 BOLT 48366-H1000 NUT 48502-H1600 ARM-STEERING GEAR
JDM Collapsible Gearbox & Column
RHD drive gearbox - JDM GL & GX trims
Asterisk (*) indicate this part is same as USA
48805-H1033 GEAR ASS'Y-steering impact (collapsible) 48820-H1021 COLUMN ASS'Y-steering 48025-18000* BEARING-worm (2) 48910-H1021* BUSH-steering column 48931-H1020* WASHER-column bush 00922-11700* RING-snap "E" type 48201-18000* COVER-side 48204-18000* PACKING-side cover 48135-66000* SCREW-adjusting 48130-66000* SHIM-screw 48131-66000* SHIM-screw 48132-66000* SHIM-screw 48133-66000* SHIM-screw 48134-66000* SHIM-screw 08911-34010* NUT 08931-10410 PLUG 08120-82010* BOLT (8) 08915-13810 WASHER-lock (8) 48011-H1002 HOUSING ASS'Y-gear 48137-H1002* SEAL-OIL 48103-H1002* SHAFT-SECTOR 08911-24610* NUT (fixing sector shaft) 08915-14610 WASHER-lock (fixing sector shaft) 48850-H1021 JACKET ASS'Y-column 48031-18000* SHIM-cover 48032-18000* SHIM-cover 48033-18000* SHIM-cover 48034-18000* SHIM-cover 48035-18000* SHIM-cover 48932-H1020 SHIM (t0.05) as req. 48932-H1021 SHIM (t0.01) as req. 48960-H1020* CLAMP ASS'Y-steering column 08915-13810* WASHER-lock (fixing clamp to column) (4) 08110-81210* BOLT (fixing clamp to column) (4) 08915-53810* WASHER-plain (fixing gear housing) (3) 48361-H1000* BOLT (fixing gear housing) (3) 48366-H1000* BOLT (fixing gear housing) (3)
JDM Standard Gearbox & Column
RHD drive gearbox - JDM STD & DX trims
rigid (non-safety, not collapsible) column
Asterisk (*) indicate this part is same as JDM Collapsible Column
48010-H1002 GEAR ASS'Y-steering 3-speed 48010-H1005 GEAR ASS'Y-steering 4-speed, A-all 48150-H1002 COLUMN ASS'Y-steering 48025-18000* BEARING-worm (2) 48201-18000* COVER-side 48135-66000* SCREW-adjusting 08911-34010* NUT 48130-66000* SHIM-adjusting, sector shaft (1.53t) 48131-66000* SHIM-adjusting, sector shaft (1.56t) 48132-66000* SHIM-adjusting, sector shaft (1.59t) 48133-66000* SHIM-adjusting, sector shaft (1.62t) 48134-66000* SHIM-adjusting, sector shaft (1.65t) 48204-18000* PACKING-side cover 48031-18000* SHIM-adjusting, worm (0.05t) 48032-18000* SHIM-adjusting, worm (0.07t) 48033-18000* SHIM-adjusting, worm (0.08t) 48034-18000* SHIM-adjusting, worm (0.1t) 48035-18000* SHIM-adjusting, worm (0.2t) 08140-82010 BOLT (8) 08915-13810* WASHER-lock (8) 08931-10400 PLUG 24210-89913 CLIP 48011-H1002* HOUSING ASS'Y-gear 48250-H1002 JACKET ASS'Y-column 3-speed 48250-H1005 JACKET ASS'Y-column 4-speed, A-all 48054-H1002 BUSH-steering column 48137-H1002* SEAL-OIL 48103-H1002* SHAFT-SECTOR 48502-H1000 ARM-steering gear 08911-24610* NUT (fixing gear arm) 08915-14610* WASHER-lock (fixing gear arm) 48361-H1000* BOLT (fixing gear housing) (3) 48366-H1000* BOLT (fixing gear housing) (3) 08915-53810* WASHER-plain (fixing gear housing) (3) 48324-H1005 CLAMP-upper 48326-H1005 CLAMP-lower 40325-04100 PACKING 08915-43810 WASHER-plain (fixing steering post) (2) 08915-13810* WASHER-lock (fixing steering post) (2) 08120-82510 BOLT (fixing steering post) (2)
Only Datsun 1200 gearbox interchanges. Made in Japan through 1994, and in South Africa through 2007.
B110 mounts with one front bolt, two rear bolts. PB110, B210, B310, 510 mount with two front bolts, single rear bolt. Cherry uses Rack & Pinion, so it does not interchange.
Service
U-joints
Datsun 1200 does not use a separate steering column; it has the column as one piece (integral) with the steering gearbox.
B210 and B310 use a separate column with a rag joint.
Datsun 510 and 240Z use a U-joint
S30 * 28 spline * ~14 mm diameter 48080-E4155 ASSY-JOINT STEERING -0773 * superceded 48080-E4150 48080-N3150 ASSY-JOINT STEERING 2+2 0873-1076 48080-N3151 ASSY-JOINT STEERING 2+2 1176-
510 48085-23125 KIT-U/JOINT STG * superceded 48095-23100
