R145
Revision as of 13:01, 23 February 2012; view current revision
Category: Differential
Hitachi R145 was used in 4WD applications as the rear final drive. Many applications used a 4-bolt rear cradle which contained the entire suspension except for the struts.
Standard type
N14, N15 Pulsar
B13, B15 Sunny
N30, JU30
M12, G10,
RB14, W11 P12, VW11, W11
Hydraulic Coupling Type
C24 Serena
M12 Prairie Liberty
K11 March
P12 Primera
VW11V Expert エキスパート
U30 0108-
Electric Coupling Type
T30 X-Trail
Murano USA Z50 electric coupling
Electric Coupled
N14 Pulsar
including RNN14 GTiR
Hydraulic Coupling
Sources
Z50 Murano USA
N14, N15 Pulsar
B14, B15 Sunny
RB14 Rasheen
C24 9907- Serena (IRS post-vanette)
K11 9911-0010 March CG10DE+CGA3DE
M12 9811-0105 Prairie Liberty
P12 0101- Primera
T30 0010 to 2007 X-Trail
JU30 9911- Besara
U30 0108- Presage
VW11 9809- Expert エキスパート
W11 9809- Avenir
Also, unknown countries:
Nissan Qashqai/Dualis
Nissan Rogue
Renault Kangoo
Renault Samsung Koleos/QM5
Gearset
2.466
3.357
3.692
3.700
38100-CA000 GEAR SET-FINAL DRIVE 37/15=2.466 $617 USD
38100-4N500 GEAR SET-FINAL DRIVE 37/15=2.466
 C24,K11,M12,P12,T30,VW11,W11,JU30,U30
38100-11E65 48/13=3.692
 JU30 9911-0108 KA24DE+YD25DDT
 B15, G10, U30
38100-10E60 GEAR SET-FINAL DRIVE 47/14=3.357
 M12, N30, W11, U13
38100-03G10 GEAR SET-FINAL DRIVE 37/10=3.700
 B13, B14, N14, N15, RB14
LSD
Both Nissan and Cusco sell rear LSD
38760
38411-20R21 COUPLING ASSY-VISCOUS $584 USD
* superseded 38411-20R14
* N14 JDM.SR20DET
* M11 USA Axxess 0189-0394 *4WD.KA24E.SGL.FA (R200?)
Cusco
MZ TYPE-RS No. LSD684 1.5 way Subaru BP/BL (2003-2009 Legacy/Liberty)
MZ 1-way
Coupling
The coupling takes the place of a center differential. These models have a totally different case, which is split on the axle centers.
Electric Coupling
The electric coupling, when not powered, allows the rear diff to free-wheel (FWD mode).
When fully powered, the propeller shaft powers the diff as normal.
The coupling is designed to work at any setting from non-powered to fully-powered, for various torque splits.
For this reason, operating as a RWD-only diff is complicated. You could use a relay and fully power it, but the failure mode would be to stop transmitting power.
Z50 USA Murano (CVT)
T30 JDM X-Trail GT
Hydraulic Coupling
38760M
38760-4N210 COUPLING ASSY-HYDRAULIC
* K11 March
38760-4N215 COUPLING ASSY-HYDRAULIC
* C24 Serena
* M12 Prairie Liberty
* P12.QR20DE.AT 0101-
* VW11V Expert エキスパート
38760-4N815 COUPLING KIT-HYDRAULIC
* superceded 38760-4N215?
* U30 0108-
* JDM.U30,C24,M12,JU30,P12,VW11,W11
Gasket
Gear carrier (main housing) gasket
R200 8-BOLT SQUARECLE
R180 8-BOLT RECTANGULAR
R160 8-BOLT SQUARECLE
R145 8-BOLT SQUARECLE
38320 GASKET-GEAR CARRIER
38353-21000 (R160 from 510)
* Replaced by: 38320-N1901
38353-N3100 R200 $5 USD
* 38320-N3111
* USD.S12+S130+Z31
38353-U3000 R180 $5 USD
* 38320-U3011
* 38353-78500
* USA.S130+910+M10+M11
* JDM.M10+M11+B12+U12+910+U12+P10+C31+F30+C31+N13+R30+S12
999MP-A7007P K11 [w/fluid coupling] [split gaskets]
*C8320-00330 $22 Silicon Gasket
38320-01G03
38320-01G02 Gasket Gear Carrier $28 USD
38320-01G00
* R145 and R200?
* JDM.N14,N15,B13,B14,B15,C22,C23,D21,D22,F23,E24,M12,VE24,WE24,
  G10,JU30,U30,N30,R20,R30,R33,RB14,S14,W11,W30,A31,C33,C34,
  R20,U13,WD21
* USA D21,D22 (front diff, four-cylinder models)
Case
38310 CASE (CARRIER COMPL-GEAR)
COUPLED TYPES
38310-8H500 [electric coupling]
* T30
38310-4N500 [hydraulic coupling]
* C24, M12, JU30.QR25DE, P12, U30, VW11, W11
SHORT-NOSE
38311-20E00
* N30 Rnessa
* JU30 9911-0108 KA24DE+YD25DDT
38310-4N500
* JU30.early
LONG-NOSE
38311-71Y00/38311-71Y02
* B13, B15, M12, G10, N14, N15, RB14, W11
R180 38311-S6200
* USA.M11 non-LSD
R200 38311-S7000
* USA.910+M10+M11.LSD+S130
Rear Suspension
431 REAR SUSPENSION
STRUT TYPE
B13,B15 drum brake
N14,N15 DB *DISC OPTION SR20DE
N30 Short-nose
JU30 9911-0108 Short-nose
JU30 0108- Hydraulic Type
U30 0108- R145A hydraulic type
* Double A-arm suspension on cradle
* transverse leaf
* drum brake
P12, strut type, flat 4-bolt?
* disc brake
