Rear Body Part Numbers
Revision as of 20:57, 9 January 2012; view current revision
Categories: Body | Catalog
Also see:
Part Numbers Index
Main articles for usage, photos, cross-reference
Rear Body panels & rear 1/4 panel (quarter panel)
Parcel Shelf
Fuel Door
1 78100-H1900 ASSY-FENDER REAR RH SEDAN
2 78101-H1900 ASSY-FENDER REAR LH SEDAN
3 78120-H1000 ASSY-DRIP REAR FENDER RH SEDAN
4 78121-H1000 ASSY-DRIP REAR FENDER LH SEDAN
5 76612-H1250 ASSY-AIR BOX REAR PILLER RH SEDAN 2 DOOR
6 76613-H1250 ASSY-AIR BOX REAR PILLER LH SEDAN 2 DOOR
7 78135-H1000 ASSY-COVER GAS FILLER SEDAN
8 79100-H1901 ASSY-PANEL REAR SEDAN
8 79100-H7000 ASSY-PANEL REAR SEDAN 0772-
9 79121-H1001 REINF-REAR PANEL SEDAN
10 79111-H1000 PANEL-REAR WAIST SEDAN
11 79420-H1000 ASSY-PANEL PARCEL SHELF SEDAN
12 79430-H1001 ASSY-SUPPORT REAR SEAT BACK RH SEDAN
13 79431-H1001 ASSY-SUPPORT SEAT BACK LH SEDAN
14 79434-H1000 BRACE-REAR SEAT BACK (2) SEDAN
15 78130-H1000 ASSY-GAS FILLER LID SEDAN
16 77760-89902 BUMPER-RUBBER GAS FILLER LID SEDAN
17 79910-H7000 ASSY-PARCEL SHELF SEDAN 0772-
17 79910-H1001 ASSY-PARCEL SHELF SEDAN
18 76906-G0511 CLIP-PARCEL SHELF 1 (10) SEDAN
18 01553-00051 CLIP-PARCEL SHELF 1 (10) SEDAN
19 79911-H1000 COVER-PARCEL SHELF SEDAN
20 79912-H1000 PLUG-PARCEL SHELF SEDAN
Sedan
Coupe
1 78110-H1955 ASSY-FENDER REAR RH COUPE 2 78110-H1905
1 78110-H1956 ASSY-FENDER REAR RH COUPE 0172- 2 78110-H1955
1 78110-H1905 ASSY-FENDER REAR RH COUPE
2 78111-H1955 ASSY-FENDER REAR LH COUPE 2 78111-H1905
2 78111-H1956 ASSY-FENDER REAR LH COUPE 0171- 2 78111-H1955
2 78111-H1905 ASSY-FENDER REAR LH COUPE
3 78120-H1800 ASSY-DRIP FENDER REAR RH COUPE
4 78121-H1800 ASSY-DRIP FENDER REAR LH COUPE
5 78135-H1800 ASSY-COVER GAS FILLER COUPE
6 76500-H7100 ASSY-PILLAR LOCK RH WITH PATCH COUPE 2 76500-H1809
6 76500-H1850 ASSY-PILLAR LOCK RH WITH PATCH COUPE
6 76500-H1809 ASSY-PILLER LOCK RH WITH PATCH COUPE 2 76500-H1850
7 76501-H7100 ASSY-PILLAR LOCK LH WITH PATCH COUPE 2 76501-H1809
7 76501-H1850 ASSY-PILLAR LOCK LH WITH PATCH COUPE
7 76501-H1809 ASSY-PILLAR LOCK LH WITH PATCH COUPE 2 76501-H1850
8 78124-H1800 PANEL-AIR DUCT SIDE RH COUPE
9 78125-H1800 PANEL-AIR DUCT SIDE LH COUPE
10 79100-H1905 ASSY-PANEL REAR COUPE
11 79120-H1800 ASSY-REINF REAR PANEL COUPE
12 96224-H1800 BRACKET-REAR LICENCE PLATE COUPE
13 79312-H1800 PANEL-REAR WAIST OUTER COUPE
14 79314-H1800 PANEL-REAR WAIST INNER COUPE
15 78130-H1800 ASSY-LID GAS FILLER (2) COUPE
16 77760-89902 BUMPER-RUBBER GAS FILLER LID (2) COUPE
17 08310-51012 SCREW-MACHINE M5 FIX LID (2) COUPE
18 78843-H2225 SET-GRILLE AIR OUTLET UPPER (2) COUPE
19 78844-H2225 SET-GRILLE AIR OUTLET LOWER (2) COUPE
20 08961-44810 PUSH (4) COUPE
21 08915-43410 WASHER-PLAIN (8) COUPE
22 08915-13410 WASHER-SPRING (8) COUPE
23 08911-10410 NUT-HEX (8) COUPE
24 74993-73000 PLUG-REAR FENDER (2) COUPE
