All 1200 body style use the same Front Combination Light Assembly (Coupe/Sedan/Van/Truck). But it varies by country and by year. USA has single-bulb, Japan has dual-bulb. Sunny Truck after 1973 has dual-reflector type.
Market Differences
Front running light lenses are either all-orange or white + orange. Reportedly the lamp housing is different so that you cannot simply swap lenses.
Body Style
Early Versus Late
Sunny Truck 1200 after September 1973 use a dual-reflector lens. Earlier 1200 Trucks use a single-reflector lense.
This uses the same lenses as B210, but the housings are different in that 1200 has bullet connectors, while B210 has multi-connector.
Interchange 1200 with B210: Probable, but requires wiring connector chang.
510 Lamps
Do not confuse 1200 front lamps with 510 laps. They look very similar but the
1200 unit is more rounded.
