Sunny Truck staring in October 1989 has a disc brake system similar to B11/N12.
Single-piston calipers (sedan/coupe are double-piston)
41060-G1985 PAD KIT-DISC BRAKE [see below section] 41001-G1500 CALIPER ASS'Y-FRONT RH W/O PADS OR SHIMS [Floating caliper] 41121-05A10 PISTON-CYLINDER $31.23 [~1.8 inch (~45.2 mm)] * USA ** Pulsar SE 1988-1989 ** NX SR20DE, w/o abs 1991-1993 ** Sentra, gasoline, wagon 1988-1989 ** Sentra, SR20DE 1991-1994 47210-G1500 BOOSTER ASSY-BRAKE 40207-G1501 ROTOR-DISC BRAKE, FRONT [? mm] 41080-05A86 HARDWARE KIT-FRONT DISK BRAKE 41120-01A25 SEAL KIT-DISC BRAKE * same as B11/VB11/B12/B13/R10/G20/M10/N12/N13
Measurements
ROTOR 208 mm diameter, 12 mm thick Caliper: marked 'K 36 R' Steering Arm: M10 bolts Disc spacing from caliper mount: 12mm Disc spacing from hub face: 36 mm hub face to back: 19 mm caliper bracket inner bolt spacing: 84 mm caliper bracket outer bolt spacing: 132 mm
Hub snout diameter 70mm Wheel hole diameter: 72 mm Mag wheel hole diameter: 71 mm
Pads
41060-G1985 PAD KIT-DISC BRAKE [ヨウ B102] B120 8910- Unique pad; no FMSI type match Width: 108.4 mm Height: 39.5 mm Thick: 16.0 mm
Aftermarket: Tokico TN289 Akebono AN-311K Kashiyama D1080-02 NiBK PN2306 Nisshinbo PF-2306 Sumitomo SN831 ZJZ GDB7132
Tokico TN289 for B120 89/10-, box also says Akebono AN311, カシヤマ D1080-02
Akebono AN-31 1K (AN-311K) A311K
Labeled "Sunny Truck" and "89,10-" and "B12T,GB12T" [sic]
108.5
Will these fit?
FMSI D275, D233 Width: 108.5 mm Height: 40 mm Thick: 15.7 mm4-17/64" = 4.266 inch = 108.3 mm 108.5 x 40.3 mm x 14.7 mm thick
~4.272" x 1.587" x 0.579" (inch)
EUROPE * Apec 379 * Interpart GBP666 ** CHERRY 1.0 1.3 1.3VAN 1.5 DE 09/82 A 08/86 ** CHERRY 1.5TURBO DE 09/82 A 05/84 ** CHERRY 1.6 DE 09/85 A 08/86 ** SUNNY 1.0 DE 06/86 A 10/88 ** SUNNY 1.3 DE 05/82 A 05/89 + 1.3 KOMBI DE 05/82 A 08/90 ** SUNNY 1.4 DE 10/88 A 12/90 ** SUNNY 1.5 DE 05/82 A 09/88 + 1.5 KOMBI DE 09/83 A 05/86 ** SUNNY 1.6 1.6COUPE DE 08/86 A 05/89 ** SUNNY 1.6I 1.6I COUPE DE 10/88 A 09/90 * Lockheed/Delphi LP261 * Bendix 552206/552208 * Bosch 986469580 * Ferodo FDB293 * Lucas/TRW GDB288/GDB988 * Quinton Hazell BP229 * Nissan 41060-01A25,41060-01A85,41060-12A25,41060-13A25, 41060-13A90,41060-25A25,41060-61A86,41060-62A90,41060-62A92, 41060-67A90,41060-89A90,41060-89A91,DA060-13A85 * Nissan 41060-77A91AS Pulsar, carb, 1984-1985 to -0485 ** Part number 41060-01A25 was superceded by part number 41060-77A91AS * Subaru 725191220 725191631 725191990 725193121 ** Justy 1984-2003 front USA Nissan Pulsar 1984 2BBL carbureted * Nissan 41060-01A25
41000-05A01 replaced 41060-01A25?41000-05A01 BRAKE ASSY-FRONT * B11 JDM 8110-8211 E15,DIE AY040-NS801 PAD KIT-DISC BRAKE K10 AY040-NS812 PAD KIT-DISC BRAKE * M10 JDM 8208-8211 S5* N12 JDM 8205-8207 E15+CD17
* Nissan 41060-77A91AS * WAGNER PD233/ZD233 or MX275 * GUARDIAN 61233 * MONROE DX275/CX275 * AKEBONO ACT275 * Brake Best MKD275 * Raybestos RPD266M/RPD266/PGD233/RPD233 * Centric 10002750 * Beck/Arnley 0891243/0871243/0821243/0881243D/0881243M ** Fits USA models: ** 1983 Nissan Pulsar L4 1.6 Liter Carbureted - VIN P ** 1983-1986 Nissan Pulsar NX 1.6 Liter Carbureted ** 1987 Nissan Pulsar NX XE L4 1.6 Liter FI - VIN P (CA16DE) ** 1988-1990 Nissan Pulsar NX ** 1982-1990 Nissan Sentra ** 1984-1985 Nissan Stanza USA 1983 Pulsar 1.6 @ RockAuto * GUARDIAN 65275 * RAYBESTOS SGD275M/PGD275M * WAGNER 7155A/D275/ZX275 * AC/DELCO 17D275M/18028853 * MONROE DX275/MX275/CMX275 * AKEBONO ACT275 * BECK/ARNLEY 0821243/0871243/0881243M![]()
Centric 30002750 (300.02750) @ RockAuto* FMSI D275 * FMSI D233 108.5 x 40.8 x 16.0 mm
