Side Glass
Revision as of 00:55, 13 June 2012; view current revision
Category: Body
[hide]
Sedan
2-door sedan has large popout side windows
Rubber
76802-H1202 WEATHERSTRIP-SIDE WINDOW RH
76803-H1202 WEATHERSTRIP-SIDE WINDOW LH
76922-H1200 WELT-SIDE WINDOW BLACK #698 (2) SEDAN 2 DOOR
B310 also fits with some trimming:
B310 83830-H8600 WEATHERSTRIP-SIDE WINDOW RH (BLACK 002G0 $84.53 USD
B310 83831-H8600 WEATHERSTRIP-SIDE WINDOW LH (BLACK 002G0 $84.53 USD
B310 weatherstripping can be used for B110 2-dr sedan rear side window weatherstripping. It's almost perfect, but about 1 inch too short for the B110. Surprisingly, the B110 glass is actually larger! The B110 has a window seal that's glued to the outside of the frame, and an inside cover for the door frame. The B310 uses a one-piece seal. Just trim a bit of it off when fitting to the B110.
Hinges & Latch
The hinges are spring metal
Hinges
Also see Rear Window Part Numbers
76828-H1200 COVER-SIDE WINDOW HINGE
76832-H1201 HINGE-SIDE WINDOW (4) SEDAN 2 DOOR
76822-H1301 GLASS-SIDE WINDOW RH TINTED & TEMPERD T=
76870-H1200 ASSY-HANDLE SIDE WINDOW LH
76872-18000 PIN-HANDLE SIDE WINDOW
B310 Handle comparo:
B310 Hinges are identical except for additional tab for hinge cover
Hinge Comparo
Grommit (Finish Nut) Comparo
Do B210 hinge covers fit?
Coupe
