Hand Brake Part Numbers
Revision as of 01:40, 9 January 2012; view current revision
Categories: Engine Mechanical | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Hand Brake (Parking Brake Control)
1 36310-H1901 ASSY-LEVER HAND BRAKE
2 36315-H1001 GRIP-HAND BRAKE LEVER
3 36329-H1000 BUTTON-RELEASE ROD
4 36330-H1000 SPRING-RELEASE ROD
5 36327-H1001 ROD-RELEASE HAND BRAKE
6 36332-H1000 PAWL-RATCHET HAND BRAKE
7 36339-H1000 PIN-RATCHET PLATE
8 36321-H1000 PLATE-RATCHET
9 36337-H1000 PIN-PAWL
10 36402-H1025 ASSY-CABLE HAND BRAKE FRONT 2 36402-H1001
10 36402-H1001 ASSY-CABLE HAND BRAKE FRONT
11 36382-18000 PIN-CLEVIS
12 36385-18000 RETAINER
13 36322-H1000 TUBE-HAND BRAKE RATCHET PLATE
14 36326-H1000 CLIP-HAND BRAKE CABLE FRONT
15 08310-50610 SCREW-PAN HEAD M5X0.8 (2)
16 08915-13510 WASHER-LOCK M5 (2)
17 36406-H1001 PLATE-LOCK HAND BRAKE CABLE (2)
17 36406-P0100 PLATE-LOCK HAND BRAKE CABLE (2) DELUXE 2 36406-H1001
18 08911-30610 NUT-LOCK M6X1.0
19 08110-82014 BOLT-HEX M8X1.25 (2)
19 08110-82062 BOLT-HEX M8X1.25 (2) 2 08110-82014
20 36400-H1001 COMP-CABLE HAND BRAKE REAR
21 36530-H1001 ASSY-CABLE HAND BRAKE LH
22 36531-H1001 ASSY-CABLE HAND BRAKE RH
23 36525-H1000 STRAP-HAND BRAKE CABLE HANGER
24 36518-H1001 WASHER-HAND BRAKE CABLE STRAP
25 08911-34210 NUT-HEX M12X1.25
26 08915-14210 WASHER-LOCK M12
27 08360-61214 BOLT-HEX M6X1.0 (2)
28 36545-H1000 SPRING-RETURN HAND BRAKE (2)
29 36407-00100 PIN-CABLE BRAKE (2)
30 00921-11810 PIN-COTTER (2)
31 36538-H1000 SHANK-HAND BRAKE CABLE L.H.
32 36539-H1000 SHANK-HAND BRAKE CABLE R.H.
