Coil Wiring
Revision as of 20:26, 19 October 2012; view current revision
Categories: Engine Electrical System | Distributor
The early 1200 coil -- as with nearly all pre-electronic ignition systems -- uses a Ballast resistor to drop the voltage supplied to the coil. All 1200s used a ballast resistor until the 1990 models.
Early 1200
NOTE: The 1973 Wiring Diagram doesn't show a resistor, but it definitely has one.
Stock wiring harness
Ballast ResistorColorConnects To
ballast resistor (non-coil side)BWIG terminal of ignition switch
ballast resistor (coil side, dual-terminal sideBW
BR
BR wire to R (START) terminal of ignition switch\*
(and)
BW to coil '+' terminal
CoilColorConnects To
Coil '+'BWto ballast resistor dual-connector side
Coil '-'Bto distributor points
\*The coil is supplied full battery voltage during cranking. Hence "R" terminal on ignition switch supplies V+ to coil.
NOTE: all the wires indicate are colored BW (black w/white stripe).
Common Problems
Does your engine start when cranking but immediately die when you release the key to the ON (running) position? Then your resistor is bad or wired incorrectly. As you can see from the diagram, START of the ignition switch supplies full voltage bypassing resistor.
Late 1200
From October 1989, Sunny Truck uses electronic ignition and computerized carburetor. There is NO BALLAST RESISTOR.
Also see: EI Wiring
Coil
BW: unknown. Not needed for old carburetor (non ECU)
BR: Coil + terminal
Distributor
BW: Coil + terminal
L: Coil - terminal
