Dipstick
Revision as of 01:34, 21 October 2012; view current revision
The Oil Level Gauge, commonly called a Dipstick, differs between early and late A12 engines.
[hide]
Early type goes directly into block (1967-1973)
Late type goes into a tube which is inserted into block (1973-up)
H50/H72/H95-type gauge is used by B210 and B310 A12/A14/A15/A12A
H10 version is used by front-distributor A12 engine.
B110 USA + JPN
11140-H1002 GAUGE-OIL LEVEL A12
11140-H1003 GAUGE-OIL LEVEL A12 <> 11140-H1002
* USA: 0271-
RWD
B10 JPN
15140-18001 GAUGE-oil level
11140-18002 GAUGE-oil level <> 15140-18001
B210 USA + JPN
11140-H5001 GAUGE-OIL LEVEL
* USA -0275
11140-H7200 GAUGE-OIL LEVEL 0375- USA 4/5 11140-H5001
15146-H5001 GUIDE-OIL LEVEL GAUGE
B310 JPN
11140-H5001 GAUGE-OIL LEVEL [all engines, all years]
11140-H5010 GAUGE-OIL LEVEL -8010 [2nd source]
15146-H5001 GUIDE-OIL LEVEL GAUGE [all years]
15146-H5002 GUIDE-OIL LEVEL GAUGE 7910-
B310 USA
11140-H5001 GAUGE ASSY-OIL LEVEL (NOK) A12A
11140-H5010 GAUGE ASSY-OIL LEVEL (OOI) A12A
11140-H9500 GAUGE ASSY-OIL LEVEL (NOK) A12A <> 11140-H5001
15146-H5001 GUIDE ASSY-OIL LEVEL GAUGE
15146-H5002 GUIDE ASSY-OIL LEVEL GAUGE -0780 <> 15146-H5001
15146-H9801 GUIDE ASSY-OIL LEVEL GAUGE 0880- <> 15146-H5002
FWD
FWD A-series engines use a totally different dipstick.
F10 USA
11140-M3001 ASSY-GAUGE,OIL LEVEL -1076
11140-M4965 ASSY-GAUGE,OIL LEVEL 1076- Y 11140-M3001
11145-M3001 ASSY-GUIDE,OIL LEVEL -1076
11145-M4966 ASSY-GUIDE,OIL LEVEL 1076- Y 11145-M3001
11146-M3000 ASSY-SUPPORT,OIL LEV
N10 USA
11140-W6660 GAUGE-OIL LEVEL A15S
11140-W7000 GAUGE-OIL LEVEL A14S
11140-W7001 GAUGE-OIL LEVEL A14S <> 11140-W7000
15146-W7001 GUIDE-OIL LEVEL GAUGE A14S
15146-W6660 GUIDE-OIL LEVEL GAUGE A15S
15146-W6661 GUIDE-OIL LEVEL GAUGE A15S
Oil Level
Oil should be between H and L marks.
Marks are the same for early (H10) vs late (H50) gauges, even though the overal gauge length differs. That's because they use the same oil pan! The oil level from the bottom of the pan is what is important.
Tube Removal
Use vice-grips and tap it up and out while twisting back and forth.
