Also see:
Part Numbers Index Main article for usage, photos, cross-reference Engine Gasket Kit
Truck
11011K GASKET KIT-ENGINE REPAIR 10101-H1025 GASKET KIT-engine 10101-H1026 GASKET KIT-engine (from '72-6) > 10101-H1025 10101-H1027 GASKET KIT-engine (from '73-6) <> 10101-H1025 10101-H3928 7510-7907 <2,0> 10101-M9025 10101-M9025 7908-8503 10101-G1925 8504-8910 10101-G6126 8910- 11042K 11042-G6126 GASKET KIT-VALVE REGRIND 8910-
1974 catalog 11044-H1000 GASKET-cylinder head 11044-H1001 GASKET-cylinder head (from '72-6) <x> 11044-H1000 11045-H1000 RING "O" (from '72-6) 11062-18000 WASHER-joint, water outlet 11130-18002 SEAL-oil, oil pan, front 11131-18002 SEAL-oil, oil pan, rear 11132-18001 GASKET-oil pan (R.H.) 11133-18001 GASKET-oil pan (L.H.) 12279-H1000 SEAL-oil, crank shaft, rear 13510-H1000 SEAL-oil, crank shaft, front 13044-18001 GASKET-cover, timing chain 13219-H1000 SHROUD-valve inner (from '73-5) 8 13207-18000 SEAL-oil, valve (up to '72-5) 8 13270-18001 PACKING-rocker cover 14035-18000 GASKET-manifold, cylinder block 15053-18000 GASKET-oil strainer 17099-21002 PACKING-fuel pump 2 21014-18000 GASKET-water pump 15066-18000 GASKET-oil pump 22180-71200 O RING-distributor support (from '73-5)
10101-H3927 KIT-GASKET ENGINE A12 0673- 2 10101-H3926 10101-H3926 KIT-GASKET ENGINE A12 0672- 2 10101-H3925 10101-H3925 KIT-GASKET ENGINE A12 0671- 0 10101-H1025 10101-H1025 KIT-GASKET ENGINE A12 2 10101-18027 10101-18027 KIT-GASKET ENGINE A12
11042-H3927 KIT-GASKET VALVE REGRINED A12 0673- 2 11042-H3926 11042-H3926 KIT-GASKET VALVE REGRINED A12 0672- 2 11042-H3925 11042-H3925 KIT-GASKET VALVE REGRINED A12 0671- 0 11042-H1025 11042-H1025 KIT-GASKET VALVE REGRINED A12 2 11042-18026 11042-18026 KIT-GASKET VALVE REGRINED A12
