Datsun 520 Truck was produced from 1965 to 1968. The minor model change came in late 1968 with the updated 521. The 521 and L521 continued to use the J13 engine until the Premium-engined 521 was introduced for North America (PL521).
Model Variation
520 Truck L520 Truck for LHD (left-hand-drive) L520U Truck, LHD for USA G520 Long wheelbase (long body) Truck U520 Double-cab Pickup (2-dr with back seat, 1-piece body/bed) V520 2-dr Van (wagon)
521 G521 Long Body Truck (long wheelbase) N-engined (J15) N521, GN521 P-engined (L16) PL521 U521 Double-cab pickup 2-dr 1968-1969 UN521 1970 N-engined V521 Van 2-dr 2-dr 1968-1969 VN521 1970 N-engined
1965 520 2-eye 520 G520 Not Available U520 V520
1968 520 4-eye
1968 521 4-eye
Wheelbase
520 2530 mm (Truck 520, Pickup U520, Van V520) G520
521 2530 mm G521 2770 U521 2530 V521 2630
Track
L521 * Front: 1267 mm * Rear: 1260 mm
Length
521 is 45 mm longer than equivalent 520 variation (SWB, LWB, D/C or Van)
Overall length (not including rear bumper)
mm 520 4245 w/o rear bumper G520 4635 w/o rear bumper U520 4300 including rear bumper V520 4300 including rear bumper
521 4290 w/o rear bumper G521 4680 w/o rear bumper U521 4345 including rear bumper 4270 without V521 4345 including rear bumper
Fuel Economy
All models (520 & 521: Truck, Long Body, Pickup, Van) * J13: 15.5 kg/l * J15: 14.5 kg/l
Weight
520 960 kg U520 1035 V520 1055
521 975 kg G521 1010 U521 1050 V521 1070
Wheel & Tire
521 - 14" * front 6.00-14 6 ply LT * rear: 6.00-14 8-ply LT U521/V521 * all 5.60-14 6 ply LT
Gearing
Floor Shift
521T (floor shift)
F4W63 1st 3.657 2nd 2.177 3rd 1.419 4th 1.000 Rev 3.638
J13: 4.875 final drive J15: 4.625 L16: 4.375
Remote Shift
521 (column shift)
R4W63 #1 1st 4.243 2nd 2.558 3rd 1.589 4th 1.000 Rev 4.367
Final Drive 4.625 N521U/GN521U, NL521/GNL521 4.375 UNL521, VN521
Remote Shift Wide
521 (column shift)
R4W63 wide ratio 1st 5.000 2nd 3.014 3rd 1.685 4th 1.000 Rev 5.146
Final Drive 4.875 521U/G521U, L521/GL521 4.625 U521/UL521, V521U/VL521
Load Capacity
520U/520/L520/L520T 2205 pounds export models
520 1000 kg
U520 6 passenger + 400 kg
V520 3 passenger + 500 kg
5 passenger + 300 kg
521 3 passenger + 1000 kg
G521 3 passenger + 1000 kg
U521 6 passenger + 400 kg
V521 3 passenger + 500 kg
PL521 2 passenger + 454 kg (1000 lb)
Transmission
JDM 521 Truck did not come with Floor Shift option. -T suffix indicates Floor Shift 4-speed.
R4W63 Remote Shift (column shift) 4-speed 521/L521 G521/GL521 N521/NL521 N521U/GN521/GNL521
F4W63 Floor Shift 4-speed L521T/NL521T GNL521T U521/UL521/UNL521 V521/VL521/VNL521 PL521TU/PL521TN
Engines
520 J13 engine 521 J13 & J15 engine L521 J13 engine PL521 L16 engine
J13
bore: 73 mm stroke: 77.6 mm capacity: 1299 cc compression: 8.2:1 Horsepower: 62 PS @ 5000 rpm Torque: 10.0 kg-m @ 2800 rpm
J15
bore: 78 mm stroke: 77.6 mm capacity: 1483 cc compression: 8.3:1 Horsepower: 77 PS @ 5200 rpm Torque: 12.0 kg-m @ 3200 rpm
Build Dates
1965 April: 520 introducion 1966 October: 4-eye (4 headlamp) introduction 1968 May: 521 minor change introduction 1969 July: L16 engine introduction for PL521
