Also see:
Part Numbers Index Main article for usage, photos, cross-reference Hand Brake (Parking Brake Control)
1 36310-H1901 ASSY-LEVER HAND BRAKE 2 36315-H1001 GRIP-HAND BRAKE LEVER 3 36329-H1000 BUTTON-RELEASE ROD 4 36330-H1000 SPRING-RELEASE ROD 5 36327-H1001 ROD-RELEASE HAND BRAKE 6 36332-H1000 PAWL-RATCHET HAND BRAKE 7 36339-H1000 PIN-RATCHET PLATE 8 36321-H1000 PLATE-RATCHET 9 36337-H1000 PIN-PAWL 10 36402-H1025 ASSY-CABLE HAND BRAKE FRONT 2 36402-H1001 10 36402-H1001 ASSY-CABLE HAND BRAKE FRONT 11 36382-18000 PIN-CLEVIS 12 36385-18000 RETAINER 13 36322-H1000 TUBE-HAND BRAKE RATCHET PLATE 14 36326-H1000 CLIP-HAND BRAKE CABLE FRONT 15 08310-50610 SCREW-PAN HEAD M5X0.8 (2) 16 08915-13510 WASHER-LOCK M5 (2) 17 36406-H1001 PLATE-LOCK HAND BRAKE CABLE (2) 17 36406-P0100 PLATE-LOCK HAND BRAKE CABLE (2) DELUXE 2 36406-H1001 18 08911-30610 NUT-LOCK M6X1.0 19 08110-82014 BOLT-HEX M8X1.25 (2) 19 08110-82062 BOLT-HEX M8X1.25 (2) 2 08110-82014 20 36400-H1001 COMP-CABLE HAND BRAKE REAR 21 36530-H1001 ASSY-CABLE HAND BRAKE LH 22 36531-H1001 ASSY-CABLE HAND BRAKE RH 23 36525-H1000 STRAP-HAND BRAKE CABLE HANGER 24 36518-H1001 WASHER-HAND BRAKE CABLE STRAP 25 08911-34210 NUT-HEX M12X1.25 26 08915-14210 WASHER-LOCK M12 27 08360-61214 BOLT-HEX M6X1.0 (2) 28 36545-H1000 SPRING-RETURN HAND BRAKE (2) 29 36407-00100 PIN-CABLE BRAKE (2) 30 00921-11810 PIN-COTTER (2) 31 36538-H1000 SHANK-HAND BRAKE CABLE L.H. 32 36539-H1000 SHANK-HAND BRAKE CABLE R.H.
