Wheel Studs
Revision as of 21:38, 19 May 2012; view current revision
Category: Wheel And Tire
Wheel Studs and lug nuts for Datsun 1200 are M12x1.25 thread. Nuts are 19mm hex head (~3/4 inch).
Discussion: extra long wheel stud info
[hide]
Thread: M12 x 1.25
Torque from the 1978 B120 factory service manual (English RHD/LHD): 8.0-9.0 kg/m (58-65 ft-lb)
Front, Disc Brakes
  • Head Code: 240
  • Knurl Diameter: 13.00mm
  • Thread Pitch: Right
  • Shoulder Length: 10mm
  • Thread Size: M12-1.25
  • Length: 32mm
  • Type: Serrated Stud
Rear
  • Nissan Part Number 40222-18000 BOLT-HUB ROAD WHEEL (B110 & B120)
  • Head Code: 242
  • Knurl Diameter: 12.56mm
  • Shoulder Length: 11.5mm
  • Length: 37.5mm
  • Type: Serrated Stud w/Clip Head
Front, Drum Brakes
40222-18000 BOLT-hub (for front drum brake)
Front, Disc Brakes
  • Nissan 40222-22001 BOLT-hub (for disc brake)
  • Dorman 28321 (Head Code N)
  • Dorman 610-240 (610240)/610-2401/98320/983201
  • Wagner/Guardian/One Source BD60980 [knurled] at RockAuto
  • Raybestos 27792B [knurled]
Stock Fits
  • 1971-1973 Datsun 1200
  • 1980-1981 Datsun 810
  • 1970 Datsun 2000
  • 1974-1975 Datsun B210
  • 1984-1986 Nissan 200SX
  • 1986-1994 Nissan D21 Pickup
  • 1979-1982 Datsun 210
  • 1976-1978 Datsun F10
  • 1970-1973 Datsun 240Z
  • 1998 Nissan Frontier
  • 1974-1975 Datsun 260Z
  • 1982-1984 Datsun Maxima
  • 1975-1978 Datsun 280Z
  • 1987-2006 Nissan Pathfinder
  • 1979-1983 Datsun 280ZX
  • 1995-1997 Nissan Pickup
  • 1984-1986 Nissan 300ZX
  • 1983 Nissan Pulsar
  • 1968-1973 Datsun 510
  • 1983-1986 Nissan Pulsar NX
  • 1973 Datsun 610
  • 1982-1986 Nissan Sentra
  • 1977-1979 Datsun 620
  • 1982-1986 Nissan Stanza
  • 1980-1986 Datsun 720
  • 2000-2006 Nissan Xterra
  • 1997-2003 Infiniti QX4
Head Code N Fits
  • 1972-1973 Datsun 1200
  • 1984-1988 Nissan 200SX
  • 1986 Nissan 720 Pickup
  • 1986-1993 Nissan D21 Pickup
  • 1987-1993 Nissan Pathfinder
Extra Long
  • NISMO 40222-A0220 [2" long/51mm]
    • For A-series front, 510, rear of FWD models, many more
Would this work? 12.9 instead of 13.0 mm knurl. The 510 and Z-car guys use them to replace the front lugs (which are the same as B110).
* 40222-15C01 GC22 Van $2.12 USD each
* 43222-0B001 V40 Quest $9.47 USD each
* NAPA/Balkamp 6412785 $2.29 USD each
* Dorman 610-403 (610403) $1.34 Rockauto
Type: Serrated Stud
Thread: M12-1.25
Knurl Dia.: 12.90mm
Length: 45.5mm
Shoulder Length: 15mm
* Infiniti J30 front 1995-93
* Nissan VAN Front 1988-87, From 1/88
* Nissan QUEST Rear 1998-93, From 1/88
Rear
NOTE: Fits B110, B120, B210, B310. Also B110 front drum
For H145, H150 and H165
* Nissan 40222-18000 BOLT-HUB ROAD WHEEL (B110 & B120) $3.60 USD
* Dorman 98340/983401/610242 RockAuto
* Dorman 28340 (Head Code D.4.0)
* NISMO 40222-H5020 [2" long/51mm]
* Wagner BD60951 [non-knurled]
* Raybestos 9340B [non-knurled]
Application:
* B110
* B120
* B210
* B310
Nuts
Lug Nuts for steel wheels
  • Nissan 40225-27700 NUT-ROAD WHEEL
  • NISMO 40224-R1120 NUT/TAPERED
  • RAYBESTOS Professional Grade 10018N
  • Dorman 711406 AutoGrade/RB 711-406-005 Open End-Bulge Seat
  • Dorman 611064 Autograde/RB 2029933 (09140-12026, 09159-12020, 28171XA00A, 30015781, 40225-27700, 6230 06002, 6230 06003)
    • Standard Open Nut
    • Thread M12-1.25
    • Hex Size 19mm
    • Length 16mm
    • Seat Angle 60 deg.
    • Finish Chrome
  • Dorman 611174 AutoGrade/RB 611-174-006 Acorn, Bulge Seat, Hex Size E
  • Dorman 611099 AutoGrade/RB 611-099-006 Acorn, Hex Size A, 1-pc
  • 40224-21001 B310
  • 40224-21001 B310
  • 40224-M7200 B310 Acorn style
  • 40224-M7210 B310 Acorn style
  • ALLOY WHEELS
  • NISMO 40224-E7200 NUT/SQUARE SHOULDER
    • For most alloy wheels. Shank: 19mm (0.748"), Length: 14mm (0.551")
  • 40224-R4626 NUT SET-WITH LOCK (FOR ALMI) B310
  • 40224-R4670 NUT-ROAD WHEEL,FOR ALUMINIUM B310
  • Dorman 611103 AutoGrade/RB kit611-103 Mag-Short Shank
  • Dorman 611107 AutoGrade/RB 611-107-006 Mag-Standard (2 pc. construction)
Alternatives
Reportedly fit 1200 disk brakes.
S13 (1989-1994 Silvia) Studs:
  • Dorman 610320/98350/983501/983551 (S13 Rear & Front, flat head)
    • Head Code: 320 (19mm diameter?)
    • Knurl Diameter: 12.83mm
    • Shoulder Length: 14mm
    • Length: 41.5mm (~47mm overall)
Fits: Most Datsun/Nissan 1970-2006
Also see: Dorman 28355 (Head Code NS, rounded), somem Datsun/Nissan including S13.
Extra-long Repco Stud S4570:
  • 77mm long overall
  • 72mm long minus head
  • 19mm dia head
  • Use with Repco Nut: NN421
SSR Mark I and Mark II
SpeedStar Wheels Mark 1 or Mark 2 requires a special nut. Imported from Japan. About $5 each in USA (includes washer). MK-I or MK-II M12 x 1.25, they are NOT tapered, but are shank nuts, although a different diameter than most.
USA: http://www.more-japan.com/ssr-mk-i-mk-ii-lug-nut-m12x1.5-w-washer.html
  • 17.1mm shank diameter
  • 19mm depth
NiceProducts (Australia) part number M300
Locking Nuts
Magnetic Locks
