A12A engine (1237cc) was used 1978-1982. It has a 75mm bore, larger than an A12 (1171cc) engine with 73mm bore. The A13 Engine has a 76mm bore. The block is virtually identical to the original 1974 A12. The A12A is a 1237cc engine. It used a casting similar to the A12 and same stroke, but machined with a 75 mm bore (up from 73 mm) for an increase of 66 cc capacity. The A12A shared a common block and crankshaft with the redesigned A12 and A13 engines.
Applications
- 1980-1982 'Datsun 210' B310 USA and Canada
- 1980-1980 Datsun Sunny B310 Japan and Asian markets (replaced by the new A13 for 1981/1982)
- 58 HP
- 1237 cc (original A12 was 1171 cc)
- 75 mm bore (2mm larger than A12)
- 70 mm stroke (same as A12)
CYLINDER BLOCK ASSY
- 11010-H9960 A12 USA 0879-
- 11010-H8500 A12 CAN 1278-0779
- 11010-H8502 A12 CAN ^11010-H8500
- 11010-H9001 A12 CAN 0879- °11010-H8502
