Seat Belt Warning System
Revision as of 05:46, 29 December 2007; view current revision
USA models have a warning system. If the seat is occupied, the weight switch sounds a buzzer unless the belt is fastened. The buzzer is located under the dash to the left of the steering column.
[hide]
Warning Lamp
To supplement the buzzer sound, 1972 models also have "Warning" lamp prominently situated on top of the dash. 5023.jpg
USA 1972 Owners manual (see pages 9 for warning system):
Switch
The front seats have a weight-activated switch. It is important to get the switch in the correct position (see FSM for specific locating details).
Seat Belt Buzzer wiring schematic: starting in mid-1972 when the Lamp was added, the simple buzzer changed to a buzzer/relay unit.
1971 to mid-1972
1971 Switch Wiring Colors (and 1972 models without lamp):
  • White - to warning buzzer
  • Red - to 15A fuse in Fuse box (IGN side), L (blue) wire at box
Buzzer
  • Red - through door switches to ground
    (BR wires on door switch)
  • W - to warning switch
Here is a 1971 dash showing where it bolts:
mid-1972 to 1973
Switch Wiring Colors (1973 models, and 1972 models with Warning Lamp)
  •  ? - to warning buzzer
  • Black/Red - to 15A fuse in Fuse box (IGN side), L (blue) wire at box
Warning Buzzer
  • BR - through door switches to ground
  • B - ground/earth
  • BR - to warning switch
