Leaf Springs
Revision as of 02:35, 4 February 2013; view current revision
Datsun 1200 used the tried and true leaf spring (blade) rear suspension, which was common among most cars - including american cars - in the early 1970s.
55020-H1000 Sedan, Coupe $159 USD
55020-H1400 Van (heavy duty)
55020-G1000 Truck 4-leaf early
55020-G1001 Truck 4-leaf 7510-
55020-G1002 Truck 4-leaf 8504-
55020-G1060 Truck 5-leaf 7804-8503
55020-G1061 Truck 5-leaf 7804-8503 8504-
Ute 4-leaf pack Type 1
Ute 4-leaf pack Type 2 (2nd leaf overlaps 1st leaf)
Rear Shackle is same for all 1200s
3-point Mount Plate (Sedan, Coupe)
Details (truck, Pin front mount)
Spring Specifications
All 1200 springs are: 1110 mm long, 50mm wide
Spring Eye Diameter
* Coupe, Sedan, Van: 35mm front,  23mm rear
Sedan, Coupe
* 3 leaf: 1 x 6mm thick, 2 x 7mm thick
Van
* 4 leaf std: 3 x 6mm thick, 1 x 13mm thick
* 4 leaf H-D: 2 x 6mm thick, 1 x 7mm thick, 1 x 11mm thick
Truck
* 4 leaf: 2 x 6mm thick, 1 x 7mm thick, 1 x 13mm thick
* 5 leaf: 2 x 6mm thick, 1 x 7mm thick, 2 x 10mm thick
Free Camber
* Sedan, Coupe: 109mm +-3
* Van         : 131mm +-5
* Truck       : 118.5 mm
Laden Camber
* Sedan, Coupe: 11mm @ 192kg
* Van: 11mm @ 295kg
* Truck std 4-leaf: 18.5 mm/kg (589 in/pound)
* Truck HD 5-leaf: 15.1 mm/kg (829 in/pound)
Leaf Mounting
B110 mounts leaf directly to metal (unlike B10 and B210 which use rubber-based isoclamp).
Rear axle mounting
Spring Seat
Spring Seat Assembly
Sedan: 55262-H1001
Truck: 55262-G1000 (RH) 12mm shock Nut wide u-bolt
Van:   55262-H1401 (RH) 12mm shock Nut narrow u-bolt
       55262-H1402 (RH)   (from '73-6)
Coupe: 55262-H1801 (RH)  8mm shock Nut
       55262-H1802 (RH)   (from '73-5)
Also see Shock aborbers
B120 Truck
Coupe
B210 Coupe
Sedan and Coupe parts
U-bolts
U-bolts
55247-H1002 CLIP-rear spring Sedan, Coupe.USA
55240-H1800 Coupe.JPM.early
55247-H1401 CLIP-rear spring Van, Coupe.JDM.late
55247-G1000 CLIP-REAR SPRING Truck 4-leaf
55247-G1060 CLIP-REAR SPRING Truck 5-leaf 7804-
Fasteners for U-bolts (Sedan,Coupe,Van,Truck)
08911-64010 NUT-HEX M10 x 1.25 8
08915-14010 WASHER-spring lock 8
Sedan
Ute U-bolts (same diameter but larger width)
B210 Sedan U-bolts (plate has wider spacing than B110)
Bound Bumpers
Coupe & Van rear suspension bumper (above the axle housing)
55240-H1400 ASSY-BUMPER REAR AXLE
08911-64010 NUT-HEX M10X1.25
08915-14010 WASHER-SPRING LOCK
Sedan rear suspension bumper (on the Shocks)
55240-H1001 BOUND BUMPER A
56124-H1001 BOUND-BUMPER B
Torque Arrester
The Torque Arrester (pinion snubber) is a rubber bumper that prevents the leafs from rotating too much under torque input.
See Rear Axle
Bushings
5 55044-H1001 front upper Sedan, Coupe
  * superseded by 55044-H5001 $4.90 USD
6 55045-H1000 front lower Sedan, Coupe [leaf eye, course] $3.63 USD
17 55046-H1000 rear upper $2.27 USD
18 55047-H1000 rear lower [leaf eye, plain] $1.22 USD
NOTE: B210 USA uses the same bushes as 1200 Coupe/Sedan.
Wagon & Ute
V 55045-H1400 front Van, Truck [leaf eye, fine] $4.25 USD
55044-H5001
Ute/Van complete set
Make your own
Or, make your own performance bushings per Nissan Competition book:
    • I went to a local platics place and bought a piece of
Aftermarket
Or, get stiff aftermarket bushings:
Polyurethane bushings out of Mexico: Parbo
Maddat Leafs
LS1200 Lowered Rear Springs, Heavy duty leaf springs, king spring, reverse-eye lowered.
They are a combination lowering spring and traction spring:
  • Flipped half-leaf to control torque windup
  • Reversed eyes for lowering
  • King Springs lowering base
Maddat LS1200
120Y Springs
120Y has same length spring, but locates the differential in a different spot. Not Interchangeable.
Alternative Leaf Springs
Carbon Leafs
リーフ スプリング シャックル ブッシュ
