Air conditioning
Revision as of 00:33, 12 April 2013; view current revision
Categories: Body Electrical System | Air Conditioning
Datsun 1200, unlike the Datsun 1000, was designed with air conditioning in mind. However, it was still a dealer-installed add-on option and so varied by country and region. In April 1978 it became a factory option for Japanese market Sunny Truck. The interior cooler protrudes into the passenger legroom and precludes using a package tray.
Parts Needed
  • Pump
  • Condensor (cooling radiator)
  • Double crankshaft pulley. (The extra pulley runs the compressor)
  • Under-dash vents
  • Hoses
  • Wiring
Since B110 A/C is fairly rare, you can source most of the parts from a B210 or B310. Only the interior vent setup is needed for a B110.
Compressor
The compressor pump bolts to the engine and is driven by a v-belt
20080.jpg Crankshaft pulley double belt
Engine Brackets
Various types were used. Early A12 and late A12 brackets differ.
Late Engine
For late model A12, there were two versions of brackets.
High-mount Pulley
Low-mount Pulley (1979-up)
New Compressor-type
Old compressor type (York-type)
1978 B120
  • V-belt: 810 or 814 mm
Engine Brackets, Early
Compressor on early A12. This in an Australia 1200. It uses a humongous bracket to space the compressor out past the low-mounted alternator.
Here is a USA 1200 with a slightly different setup:
Left-hand Drive
Ecuador
Taiwan
fullsize
1972 Brochure
The air condition for Datsun cars is made by Frigiking. It's the only system approved by the Datsun factory.
Except that the Factory used a different brand. Frigiking was only used in USA.
USA Type 1
Frigiking dealer-installed package. Larger capacity than 240Z, but less than 510 or 521 pickup
PERFORMANCE
Capacity: 12,500 BTU/hour
Airflow: 180 CFM
Evaporator Coil: 3/8 x .016 cu tubes, 4 rows
 staggered pattern, 12" x 5" x 2-1/2"
 fin series 120 flat aluminum
Expansion Valve: 1-1/2 ton
ELECTRICAL
Fan Switch: Reostat
Thermostat: Ranco type A-30
 Cold cut-out: 28°F ±2°
 Cold cut-in: 36°F ±2°
 Warm cut-out: 58°F ±4°
Fan Motor: Double shaft, single speed, 4600 RPM @ 13.5 V
 11.5 amps maximum current draw
Clutch: Pitts 6" double groove 12V 4.0 amp
Wiring: SAE specification J558a
Overload Protection: Inline fuse 30 amps
COMPRESSOR: York 206 (6 cubic inches)
CONDENSOR: 3/8 x .016 cu. tube, 2 row inline pattern
 13 x 12 x 1-1/2 fin seris 10 fins/inch
GENERAL KIT COMPONENTS: All meet SAE specifications
COMPRESSOR MOUNT KIT
Brackets are 1/4" hot rolled steel, arc welded and painted
Drive Pulley material: ASTMA-159, Class G3000, grey cast iron
 precision machined, balanced and painted
Idler Pulley: Cast iron, fully machined with single-row sealed ball bearing
Attaching Hardware: Grade 5, black, rust resistant
Compressor Drive Belt: Standard automotive quality, 500 section
EVAPORATOR SECTION
Material: High-strength injection-molded plastic case
Knobs: injection-molded plastic
USA Type 2
USA Type Frigette
Frigette Brand. Aftermarket kits still sold at JC Whitney!
Optional Fan
Nissan option flex-fan
Dealer item
From USA catalog:
  • 21060-H1001 FAN-COOLING A12 (standard B110 fan)
  • 21060-A4605, 21060-N0100 FAN-COOLING D=330 FOR TROPICAL USA (330 mm diameter)
Sunny Truck Kit
From October 1979 a uniform kit was offered with DKKC type compressor.
This kit is beautiful and easy to install. Unfortunately the interior cooler unit is bulky and protrudes farther into the passenger legroom than other types.
You need all these parts:
  • Ass'y indoor "cooler unit" (with integrated air volume switch, evaporator, and blower fan)
  • air conditioner compressor
  • V-belt: 814 mm
  • compressor bracket
  • crank pulley (double V-belt version)
  • Twin Condensors (before radiator, radiator horizontal)
    One has an electric fan
    • Pipe connecting twin condensors
  • High-pressure flexible pipe (from compressor to condensor)
  • Low-pressure hose (from evaporator to compressor)
  • Tube-Liquid Tank to Evaporator
  • Liquid Tank
    • Bracket to mount Tank on core support
  • Receiver tank (Liquid tank)
  • Relay (for compressor)
  • Wiring harness
  • Capacitor for electric fan
  • Engine Mounted 9810- Fast Idle Control Device (FICD)
    • 14875-G5105 Manifold Connector [right next to carb base plate]
      • Vacuum Hose L=370
    • 27654-H8500 FICD Actuator
      • 92551-95W00 Actuator Bracket
    • 27720-G2500 FICD Lever
    • 92255-G5100 Solenoid Valve
      • 92256-95W00 Bracket
      • Vacuum Hose L=270
Vents may be opened or closed:
Twin Condensors and Liquid Tank with connecting pipes.
Condensor-to-Liquid Tank hose is routed along the top of core support.
Compressor is mounted low on left side of engine.
Cooler Unit lines: Evaporator Inlet & Outlet and drain hose
Legroom
Since the cooler unit takes up some of the passenger legroom, what to do? One enterprising 1200 fan mounted the cooler unit in the dash:
Of course the downside is there is no glove box.
Misc
  • 27630-G1660 COMPRESSOR-COOLER DKKC
  • 27630-W7002 COMPRESSOR-COOLER DKKC [B421]
    • JDM Datsun B120 8110-8910
    • JDM Datsun 720 L18 7909-8105
  • 92610-G1900 COMPRESSOR-COOLER DKKC [B421]
    • B120 8910-
  • 11910-G1661 BRACKET-COMPRESSOR 7804-7907
    • 11911-G1661 BRACKET-COMPRESSOR [2nd piece]
  • 11929-H1000 BELT-COMPRESSOR L-810 7804-7807
  • 11910-G1615 BRACKET-COMPRESSOR 7908-8910
  • 11910-95W00 BRACKET-COMPRESSOR 8910-
  • 11929-G1615 BELT-COMPRESSOR L-814 7808-
  • 11925-A0100 PULLEY ASSY-IDLER,COMPRESSOR 7804-7807
  • 11925-G1615 PULLEY ASSY-IDLER,COMPRESSOR 7808-
  • 11917-M0100 BOLT-ADJUST 7804-7907
    • 11933-A0100 NUT 7804-7907
B310 USA
  • 11910-H9100 BRACKET-COMPRESSOR -0678
  • 11910-H9101 BRACKET-COMPRESSOR 0778-
  • 11910-H9900 BRACKET-COMPRESSOR 0879-
2185.jpg 2187.jpg 2199.jpg 2209.jpg 2210.jpg 2341.jpg 2495.jpg 3053.jpg 3811.jpg 4163.jpg 4164.jpg 4305.jpg 5060.jpg 5063.jpg 7777.jpg 9377.jpg 9378.jpg 11444.jpg 12038.jpg 13181.jpg 13934.jpg 14556.jpg 14557.jpg 14950.jpg 14953.jpg 15192.jpg 15193.jpg 15194.jpg 15622.jpg 16243.jpg 16244.jpg 17263.jpg 17654.jpg 17655.jpg 18256.jpg 18710.jpg 18767.jpg
