Datsun 1200 weighs about 1640 pounds (745 kg) depending on year, options, and how much fuel is in the tank.
Documentation
Weight Distribution (Front/Rear)....54/46
Consumer Reports 1971 September Road Test
Weight .................. 14cwt
MOTORMAN magazine
Curb Weight: 1,609 lbs (731 kg)
Mechanix Illustrated 1973 article
CURB WEIGHT ... 1613 pounds (733 kg)
| 4-dr manual | 1532 lbs (696 kg) |
| 4-dr auto | 1609 lbs (731 kg) |
| 2-dr coupe | 1520 lbs (691 kg) |
| 5-dr wagon | 1609 lbs (731 kg) |
Japan published weights (source: Datsun factory parts catalog C-231)
B110S 690 kg STD trim B110SR 665 STD 2-dr sedan B110 700 B110R 685 DX 2-dr B110A 735 AUTO B110RA 720 B110G 705 GL B110GR 690 B110GA 740 B110GRA 725 VB110 735 Van VB110S 715 KB110 695 Coupe KB110G 700 KB110A 730 KB110GA 735 B110GTK 710 GX Coupe B110GK 705 GX Sedan
Curb weight 2-dr coupe: 1650 lbs (750 kg)
Curb Weight 2-dr sedan: 1630 lbs (741 kg)
Add 75 lbs for automatic transmission (34 kg)
Source: Nissan USA statistics
Measured
It all depends on how much fuel is in the tank at time of weighing, and if using stock components which are generally lighter than non-stock wheels, tires and suspension pieces. Plus options like carpet, transmission type, etc.
Ute
[http:/datsun1200.com/modules/newbb/viewtopic.php?post_id=410623#forumpost410623 Ange had his ute weighed] pre-conversion. It was 730kg.
Ute: 730kg (one example measured)
Coupe
Kelmo weighed his stock 1973 USA coupe, with aftermarket wheels.
Front left: 463 Front right: 464 Rear left: 385 Rear right: 375 Total: 1687 pounds
Sedan
ddgonzal measured his stock 1972 sedan with 1/4 tank fuel: 1640 pounds
