B210 Tail Gate
Revision as of 03:17, 24 May 2014; view current revision
Categories: Datsun B210 | Body
B210 van and B210 coupe both used a tail gate. The Coupe tail gate is more commonly called the hatch or liftgate.
Coupe Tail Gate
DX came with hatch struts, to keep the hatch open when lifted. GL & GX hatch struts came with switches to turn the light on.
120Y Coupe with hatch open
90100-H5500 ASSY-PANEL,TAIL GATE COUPE
90810-H5501 WEATHERSTRIP-tail gate <> 90810-H5500
TAIL GATE TRIMMING (underside of hatch)
90900-H5500 FINISHER-tail gate (Black)
90900-H5501 FINISHER-tail gate (Brown)
01553-00211 CLIP-trim (Black) (11)
01553-00221 CLIP-trim (Brown) (11)
Hatch Struts
Tail Gate Stay
90210-H5550 BALANCER KIT-tail gate (R.H.) K-GX,K-GL,(op.)K-DX, USA ALL
90211-H5550 BALANCER KIT-tail gate (L.H.) K-GX,K-GL,(op.)K-DX, USA ALL
90210-H5500 BALANCER ASS'Y-tail gate (R.H.) K-DX $175 USD
90211-H5500 BALANCER ASS'Y-tail gate (L.H.) K-DX $175 USD
Aftermarket
* SACHS SG225004 $17 USD
  CONNECTION Ball Socket End
  Extended Length 24"
  Compressed Length 15"
* AMS AUTOMOTIVE 4729 Hatch Lift
  Extended Length (inches) 23.88
  Compressed Length (inches) 14.81
  Stroke (inches) 9.07
  Pounds of Force 46
  Shaft Diameter (mm) 8
  Body Diameter (mm) 22
  Shaft Connection U-Blade
  Body Connection U-Blade
B310
1979-1982 Rockauto.com
* AMS AUTOMOTIVE 4853
  Extended Length (inches) 25.24
  Compressed Length (inches) 15.37
  Stroke (inches) 9.87
  Pounds of Force 78
  Shaft Diameter (mm) 10
  Shaft Connection Ball Socket (Nylon) 10mm
  Body Connection Ball Socket (Nylon) 10mm
  Internal Spring With Internal Spring
* SACHS SG225007
  Extended Length 25"
  Compressed Length 16"
B310 SEDAN
* SACHS SG325006
  CONNECTION Eyelet End
  Extended Length 20"
  Compressed Length 13"
* AMS AUTOMOTIVE 4429
  Extended Length (inches) 20.25
  Compressed Length (inches) 13.15
  Stroke (inches) 7.10
  Pounds of Force 61
  Body Diameter (mm) 19
  Shaft Connection Off-Set Blade (.318 dia. hole)
  Body Connection Off-Set Blade (.318 dia. hole)
