Bluebird is Nissan's C-class (compact) model family, which grew out of the original Datson (DAT Light Car) model, the Datson Type 10 of 1931. For additional details, see History. Bluebird family includes the 210/310/410/510/610/810 model series -- but not the 710 which was of the Violet family.
the original Datson Light Car
The first Datsun to be called Bluebird was the 210 model series, apparently during mid-run.
- 1957-1959 210 Datsun Bluebird/1000
- 1959-1963 310/311/312 Datsun Bluebird/1000/1200
- 1963-1967 410/411 Datsun Bluebird/410/411
- 1967-1973 510 Datsun Bluebird/510/1600,1300,1400
- 1973-1976 610 Datsun Bluebird/610/180B
- 1976-1979 810 Datsun Bluebird/810/180B/200B
- 1980-1983 910 Datsun/Nissan Bluebird/810/Maxima (to 1986 in Australia)
- switch to FWD starting with U11 model series Bluebird/Maxima
Bluebirds often feature Independent rear suspension (IRS) starting with the 510 series. Wagons are a notable exception, although export sedans may also may have a live axle.
Later models, starting with the G610 and the G810 -- stretched models, may be considered D-class (mid-size) cars.
310
312 minor change
410/411
411 minor change
410 = C1 engine (998cc) P410 = E1 engine (1189cc) P411 = J13 engine R411 = R16 engine
SS = 410 with E1 (1200) Twin Carb SS = 411 with J13 Twin Carb SSS = 411 with R16 Twin Carb
S = Standard D = Deluxe F = Fancy N = automatic clutch L- = left hand drive -L = handling package? R = 2-door sedan SS = Sport Sedan SS-R = 2-dr Sport Sedan U = export W = Wagon
410 JAPAN Carburetors C1 = 2-bbl carb E1 = 2-bbl Hitachi DAB-308-7 E1 = 2-bbl Nikki 2D-30CE <> 2D-30CE-2 Pedal clutch E1 = 2-bbl Nikki Pedal clutch E1 = 2-bbl Nikki 2D-30CF <> 2D-30CF-2 Automatic clutch -K = SS = Twin Carburetor Hitachi HJE38W-1
510
Datsun model series 510 was marketed in Japan as the Bluebird, in America as the 510 and in some countries as 1300/1400/1600 depending on engine (L13, L14 or L16).
510 1300 L13 engine N510 1400 L14 engine P510 1600 L16 engine H510 1800 L18 engine
510 4-door Sedan 510R 2-door Sedan K510 2-door Coupe (semi-fastback design) V510 4-door Van (Wagon)
One-off custom 510 Coupe Utility
610
The Datsun 610 was the Bluebird model for the 1973-1977 Model years. It was marketed in various countries as:
- "Datsun 610"
- "Datsun Bluebird"
- "Datsun 160B" or "Datsun 180B" depending on engine size
See main article: 610
Coupe
Sedan
Wagon
810
Datsun model series 810 was produced 1976-1979. In some countries it was marketed as "Bluebird", in others as "200B" or "180B" or "160B" depending on the engine fitted. Not the same as the 1980-1984 Datsun 810 north america, which is actually model series 910.
North America 1977-1979 "810" Australia 1977-1982 "200B" Japan 1976-1979 "Bluebird"
810 Bluebird 1600 P810 Bluebird 1800/180B RG810 Bluebird 2000 G6 L20 engine HG810 810 L24E engine
810 180B (with swapped-in FJ20 engine)
910
1980-1986 in Australia
- Australia: Bluebird Series I/II 1981-1984 (L20B engine, no IRS, H165)
- Australia: Bluebird Series III/Bluebird TRX 1985-1986 with CA20S engine
910 Europe RHD L16S L18S L18T Z20E LD20
