A strut tower bar is a cool-looking piece of hardware that ties the two strut towers together. Also known as strut bar, dampener, damper bar, strut brace, or Monte Carlo bar. The performance theory is that it reduces chassis deformation on hard cornering.
B110 strut-top bolt circle is the same as other Nissans: 122mm diameter
Low and high versions * Flat * Round * Round with taper ends
Cusco Type ST steel shaft クスコ タワーバー (part number 204 510 A) - clears A14/A15 engine
Mad Dat Tri-bar Strut Brace
Dimensions
1200 strut-top bolt circle: 122mm diameter B110/B120 strut width center-to-center 936 mm (36.85 inch)
strut_brace
Uploads
photo:
photo:
photo:
photo:
photo:
photo:
tower bar,strut bar,dampener,damper bar,brace,Monte Carlo bar not steering
