Accelerator Pedal
Revision as of 02:36, 10 July 2015; view current revision
Categories: Engine Control | Fuel System
The Datsun 1200 Accelerator Pedal (gas pedal, fuel pedal) on mounted to the floor on RHD models, and suspended on LHD models.
Also see Throttle Cable and Pedal Box
[hide]
Throttle Cable ball-end fits into slot on end of Accelerator Pedal. Usually a clip goes over the cable ball-end. But as long as the cable is properly adjusted you can drive it for years without the clip.
full
Right-Hand Drive
full size
  • 18010-H1010 ARM-COMP,accelerator pedal AUTOMATIC
    • includes:
      18100-H1010 ARM ASS'Y,accelerator pedal AUTO
      18021-H1000 BRACKET-ACCELERATOR PEDAL
      SNAP RING
  • 18010-H1000 LEVER ASSY-PEDAL [MANUAL]
    • includes
      18215-27700 SPRING-PEDAL ROD
      18135-14800 BUMPER-ACCELERATOR
      18021-H1000 BRACKET-PEDAL LEVER
      • 08310-51014 SCREW
      • 18137-10600 RING-SNAP
  • 18110-H1000 PEDAL-ACCELERATOR [foot rest]
    • 08310-51214 SCREW (2)
    • fixing pedal stopper
      • 08360-63512 SCREW
      • 08911-30610 NUT
Left-Hand Drive
  • 18010-H1902 COMP-ARM ACCELERATOR PEDAL AUTOMATIC
    • 18100-H1602 ASSY-ARM ACCELERATOR PEDAL AUTO
  • 18010-H1602 COMP-ARM ACCELERATOR PEDAL MANUAL
    • 18100-H1902 ASSY-ARM ACCELERATOR PEDAL MANUAL
  • Above assemblies include:
    • 18017-H1600 PAD-ACCELERATOR PEDAL
    • 18021-H1600 BRACKET-ACCELERATOR PEDAL
    • 18215-H1601 SPRING-RETURN ACCELERATOR
    • 18137-10600 RING-SNAP E TYPE
    • 08310-S1614 SCREW-MACHINE M5 FOR BRACKET TO BODY FIX
  • 18135-14800 BUMPER-ACCELERATOR PEDAL STOPPER
  • 18056-H1600 BOLT-PEDAL STOPPER
Automatic Transmission
See Engine Control Part Numbers
