1200 performance parts. MAD DAT does mail order, shipping to other countries.
1200 Parts * CA18/1200 Fitting Kit * 13BT into 1200 Engine Fitting Kit * SR20/1200 Fitting Kit * Plug & Play Wiring Loom * 1200 Conversion Sway Bar Kit * Clutch Reservoir Relocation Kit * New Datsun 1200 Ute Engine X-Member * Polyeurethane Engine Mounts * Ultimate Race Coilover Package * Lowered Front Strut Assembly Pair * Adjustable Rebuilt Front End (suit Stanza/200B strut) * Rebuilt Front End (suit 1200 strut) * Tie Rod & Ball Joint Kit 1200 * 1200 Adjustable Lower Control Arms * Caster Adjuster Bar Kit (1200) * Short Throw Shifter (R30 Gearbox) * Short Throw Shifter (A-Series Gearbox) * Replacement Shifter Bushes * New Bush Kit Suit 1200 Models (blue polyeurethane) * 1200 Genuine Nissan Rubbers * 1200 Non-Genuine Nissan Rubbers * Front Brake Conversion Kit (280mm rotors) * Front Brake Conversion Kit Alloy Hub * Brake Booster / Master / Bracket / Clutch * Heavy Duty Clutch Pedal * CA18/1200 Brake Bracket * Underfloor Fuel Package * 1200 Steering Box Brace * CA18/1200 Dump Pipe * SR20/1200 Dump Pipe * Strut Brace (1200) * Strut Brace Tri-bar (1200) * CA18/1200 Accelerator Cable * SR20/1200 Accelerator Cable * CA18 or SR20/1200 Speedo Cable * Intercooler & Radiator * Lowered Rear Springs * Diff Housing & Rear Disc Brakes (Shortened R31 28 spline) * Diff - Gears & LSD * Diff - Minispool * Diff - KAAZ LSD * Adjustable Rear Koni Shocks (pair) * Transmission Tunnel * Universal Heater Box * Steering Column Bush * Hard Top Lid suit 1200 Ute * GENUINE NISSAN PARTS (request) * Front Bumper * Bonnet * Tail Gate Outer
