Welch plugs (core plugs) are circular discs that fit into, and seal the casting and machining holes in the Engine block, Cylinder Head and Transmission.
Terminology
The Welch plug was originally designed circa 1910 by the Welch brothers at the Welch Motor Car Company of Pontiac, Michigan. You may hear them incorrectly called "welsh plugs". See Patent No 1058210
They are often called "freeze plugs" because if the engine coolant freezes they'll be pushed out of the casting. However, the purpose is not necessarily to solve freezing problems but rather to seal the holes left by the casting or machining process. Those that are designed for freezing safety are called "expansion plugs".
Set
DORMAN 557-031 A12 & A13 engines
MAFCO 437 120Y 1969-1972 (http://www.mafcobell.co.uk)
MAFCO 441 Sunny 140Y 1980-1982
above may be for L14 engine??? PB210 (140Y in South Africa) - L14 engine 11021-21000 PLUG-welch [6 total, 40 mm] * (3) right side * (2) left side * (1) rear cylinder head * 00933-13500 PLUG-welch, 35 -7410 * 00322-13000 PLUG-welch, 30 -7410 * 11048-73403 PLUG-blind (2) 7411
Cylinder Head
- 00933-14000 PLUG-WELCH (1) head, rear [reportedly 40 mm]
Engine Block
B110
* 11019-32200 PLUG-WELCH 44Ø CAM BEARING (1) block, rear (44.425 Ø) [1-3/4 inch] * 00933-15000 PLUG-WELCH 50Ø CORE HOLE (1) block, rear prev. 01648-00084
* 00933-13500 PLUG-WELCH 35Ø CORE HOLE (3) block, right side![]()
* 35mm brass core-plugs
B120
35 mm Expansion Plug 00933-13500 / 11021-E3000 / 00933-1351A Nominal Dia.: 35.21mm Steel Height: 0.380"
プラグ (35mm - 3 required) 7510-8506 00933-13500 8506-8706 11021-E3000 [11021E] 8706- 00933-1351A
Transmission
- 00933-11400 PLUG-WELCH TRANSMISSION CASE (2) inside bell, northwest of mainshaft
- 32102-18000 PLUG-WELCH TRANSMISSION CASE (1) inside bell, below mainshaft
Removal and installation
Removal: tap one edge with a punch or chisel, then grab it with vice-grips and wiggle it out.
To install, fit squarely into bore, and tap gently and evenly into place. No sealer is used.
