Room Lamp
Revision as of 22:18, 14 August 2015; view current revision
The room lamp, also known a dome light.
The middle position operates from the door switches (if equipped).
5036.jpg interior "dome" light
USA 1972 Owners manual (see page 6 for Interior Lamp):
To switch the interior lamp "ON", and "OFF", turn the switch lever clockwise or counterclockwise.
13404.jpg int. lamp switch
3401.jpg alternative interior headliner light
Car
These parts are the same for both B110 and B210.
120Y
510 Lamp
510 lamp is a different style and bolts into B210, so may fit B110.
26410-23100 ASSY-LAMP ROOM -0968 EXC CAN <x> 26410-23101
* 1968 CANADA used dual rectangular side lamps
26410-A0800 ASSY-LAMP ROOM 0968-
Pickup
26410-04100 LAMP ASS'Y-room -7803 IKI
26410-G1000 LAMP ASSY-ROOM -7803 IMASEN
26410-04400 LAMP ASSY-ROOM 7803- IKI
Two wires:
* Red: bulb 12V
* Black: earth/ground
B10
B10 sedan and VB10 wagon uses the same lap as 1200 ute. IKI brand (市川, Ichikawa).
26410-04100 ASS'Y-LAMP, room STD IKI
26410-04400 ASS'Y-LAMP, room DELUXE IKI
521 Lamp
Datsun 521 pickup (USA) uses the same Room Lamp as a 1200 Pickup. IKI brand.
26400-04100 ASS'Y-LAMP, room
* 26411-04100 LENS
* 26715-89900 BULB (12V 6W)
* 5-10813-1 SCREW-machine (2)
See Room Lamp Part Numbers
The room lamp has one side of the lamp (RL wire) always hot from the L wire of the fuse box. The switch has three positions:
  • Off
  • Auto (center)
  • On
In the auto position, the light is grounded by the Door Switch (BR wire in a-pillar). Usually only the driver's side door has a switch. In the ON position, it is grounded through the ground wire in the headliner.
