USA models have a warning system. If the seat is occupied, the weight switch sounds a buzzer unless the belt is fastened. The buzzer is located under the dash to the left of the steering column.
To supplement the buzzer sound, 1972 models also have "Warning" lamp prominently situated on top of the dash.
USA 1972 Owners manual (see pages 9 for warning system):
Switch
The front seats have a weight-activated switch. It is important to get the switch in the correct position (see FSM for specific locating details).
Seat Belt Buzzer wiring schematic: starting in mid-1972 when the Lamp was added, the simple buzzer changed to a buzzer/relay unit.
1971 to mid-1972
1971 Switch Wiring Colors (and 1972 models without lamp):
- White - to warning buzzer
- Red - to 15A fuse in Fuse box (IGN side), L (blue) wire at box
Buzzer
- Red - through door switches to ground
- (BR wires on door switch)
- W - to warning switch
Here is a 1971 dash showing where it bolts:
mid-1972 to 1973
1973 Switch Wiring Colors (and 1972 models with Warning Lamp)
- ? - to warning buzzer
- Black/Red - to 15A fuse in Fuse box (IGN side), L (blue) wire at box
Buzzer/Relay
