Block Heater
Revision as of 02:07, 3 January 2013; view current revision
Category: Cooling System
Keep Sunny happy on cold nights with a Genuine Datsun Accessory Part. Granted it is a rare thing which most cold Americans have never seen. It is really only needed when temps are far far far below 0 Celcius. Even so I reckon it'd be nice to jump in the ol 1200 and floor it without having to wait for a brief warmup period.
Yes it ran on 110v US.
Yes it is still available, at about $20.00 USD
Part # 99998-10242. This part # applies to US model (just about everything) B210 '74 to '78. It wil actually fit most Nissan blocks except some L motors for some reason.
Obviously you fit it into one of the welch plugs so it sits in the coolant, & when it's below freezing, you turn it on to heat the coolant before starting. Or maybe you keep it turned on all night so the coolant doesnt freeze & split the block.
They are mostly used in extreme cold climates, e.g. Alaska and Minnesota where temps can reach -40 F (below freezing temperature of anti-freeze).
Although in mountain areas everywhere they are occasionally used.
