Head Gasket
Revision as of 23:26, 23 July 2016; view current revision
Category: Engine Mechanical
The Datsun 1200 cylinder head gasket fit A12 and A10 engines. Aftermarket gaskets vary in material and size of cooling holes.
22208.jpg 22067.jpgAlbum 22067
Also See:
* Changing Head Gasket
* Tune-up
Nissan recommends re-torquing the head gasket bolts ever twenty-four months (every two years):
1972 USA Owners manual (Page 34 ... ):
Retighten cylinder head bolts, manifold nuts & carburetor securing nuts.
slight weeping leak
10755.jpgAlbum 10755
Blown Gasket
When a head gasket is blown out (partly missing) between cylinders it is obvious, and the engine will run on "two cylinders" (barely run, if at all).
15053.jpgAlbum 15053
But gaskets most often fail in a less obvious manner. They lift up enough to allow compression to leak past, causing low compression. An Engine compression test will find this.
A more rare failure is of the oil or water passage. The engine will still run perfectly, but oil will leak or coolant will be lost. A Cooling System Pressure Test can often pinpoint the diagnosis.
18407.jpg 21050.jpg 21051.jpg 21052.jpg 21053.jpg 21054.jpg 21055.jpg 21204.jpg
11044-18004 GASKET-CYLINDER HEAD A12 superceeded
11044-H1000 GASKET-CYLINDER HEAD A12
11044-H1000 GASKET-cylinder head B110, B210 to '75-4
11044-H1025 B210 from '75-5
11044-H1026
11044-H1027
11044-H3900 GASKET-CYLINDER HEAD A12 0671-
fits:
A10 PULSAR 1000  BN10  988cc  1978-ON
A10 SUNNY 1000 B10,B20 1000 1966-1970
A12 SUNNY 1200 B110,B210,C20  1171cc 1970-73.3
A12 SUNNY 1200 B210 1973.4-75
A10 CHERRY 1000 E10, F10 988 1970.10-73.9
A12 CHERRY 1200 PE10, F10 1171cc 1972-78
11044-H2300 A12GX, A12T
11044-H2301 [thinner?] A12GX, A12T
11044-H2325 A12GX from '72-6
Head Set
11044-H3926 KIT-GASKET,CYLINDER HEAD
11042-H3927 KIT-GASKET,CYLINDER HEAD
Head Set gasket includes all you need to change the head:
Cylinder head gasket
Valve stem seals
Rocker cover gasket
Gasket-manifold to cylinder head
it may include the following:
thermostat gasket
intake-to-exhaust manifold gasket (heat riser gasket)
oil cap packing (gasket)
fuel pump gaskets
Gasket Head Set
* Victor HS3602
* FEL-Pro HS21181PT
* ROL HS32060
GX Metal
Nissan Competition
Nissan Competition
11044-M0821 COMPETITION HEAD GASKET
Gasket has a bore diameter of 79mm/3.11", an uncrushed thickness of 0.8mm/0.032" and displaces 3.9cc's.
Nismo head gaskets for Nissan A series motor A12,A13,A14,A15 Engine
11044-M0822 t=0.8 79.0 mm bore diameter
11044-M0823 t=0.6 80.0 mm bore
Spacer Gasket
custom order
シリンダーヘッドガスケット
