Also see:
Part Numbers Index Main article for usage, photos, cross-reference Cylinder Heads Rocker Cover Thermostat
4 11098-18011 INSERT-valve seat, intake 4 ALL (exc. GX) 5 11099-18010 INSERT-valve seat, exhaust 4 ALL (exc. GX) 11099-H1010 INSERT-valve seat, exhaust 4 ALL > 11099-18010 [valve seats not listed in 1972 catalog]
1 11041-H3900 ASSY-HEAD,CYLINDER A12 0671-1272 2 11041-H1001 1 11041-H3901 ASSY-HEAD CYLINDER A12 0173-0273 2 11041-H3900 1 11041-H3902 ASSY-HEAD CYLINDER A12 0373- 2 11041-H3901 11041-H3903 ASSY-HEAD CYLINDER A12 0373- 2 11041-H3902 1 11041-H1001 ASSY-HEAD CYLINDER A12 -571 2 13212-H0110 GUIDE-VALVE INTAKE (4) A12 2 13212-H0111 GUIDE-VALVE INTAKE (4) A12 2 13212-H0110 3 13213-H0110 GUIDE-VALVE EXHAUST (4) A12 3 13213-H0111 GUIDE-VALVE EXHAUST (4) A12 2 13213-H0110 4 11098-18011 INSERT-VALVE SEAT INTAKE (4) A12 4 11098-18012 11098-18011 11098-H1012 INSERT-VALVE SEAT INTAKE (4) A12 5 11099-18010 INSERT-VALVE SEAT EXHAUST (4) A12 5 11099-H1010 INSERT-VALVE SEAT,EXHAUST (4) A12 -273 2 11099-18010 11099-M0111 INSERT-VALVE SEAT,EXHAUST (4) A12 6 00933-20650 PLUG-TAPER (2) A12 6 01647-00011 PLUG-TAPER (2) A12 2 00933-20650 00933-1401A PLUG-WELCH A12 00933-14000 7 00933-14000 PLUG-WELCH A12 14065-B8600 STUD-MANIFOLD M8 (4) A12 08213-82510 8 08213-82510 STUD-MANIFOLD M8 (4) A12 9 08213-82810 STUD-MANIFOLD M8 (5) A12 10 11051-73403 PLUG-BLIND CYLINDER HEAD (4) A12 11 13214-73400 RING-SNAP VALVE GUIDE (8) A12 12 00931-30610 PLUG-HEATER OUTLET HOLE A12 13 11044-18004 GASKET-CYLINDER HEAD A12 13 11044-H1000 GASKET-CYLINDER HEAD A12 2 11044-18004 13 11044-H3900 GASKET-CYLINDER HEAD A12 0671- 0 11044-H1000 13 11044-H3925 KIT-GASKET,CYLINDER HEAD A12 0672- 2 11044-H3900 14 11045-H1000 RING-OIL,OIL GALLERY A12 0672- 15 11056-H1000 BOLT-FIXING CYLINDER HEAD (9) A12 1272- 2 11056-18001 15 11056-18001 BOLT-FIXING CYLINDER HEAD (9) A12 16 11057-18000 BOLT-FIXING CYLINDER HEAD A12 16 11057-H1000 BOLT-FIXING CYLINDER HEAD A12 1272- 2 11057-18000 17 11058-18000 WASHER-LOCK FIXING CYLINDER HEAD (10) A12 17 11058-H1000 WASHER-LOCK FIXING CYLINDER HEAD (10) A12 0172- 2 11058-18000 18 10005-H1000 SLINGER-ENGINE FRONT A12 19 13264-H1000 ASSY-COVER VALVE ROCKER A12 19 13264-H7000 ASSY-COVER,VALVE ROCKER A12 0772- 0 13264-H1000 20 08915-13610 WASHER-LOCK FIXING ROCKER COVER (6) A12 08360-61612 SCREW-MACHINE FIXING ROCKER COVER (6) A12 08310-61612 21 08310-61612 SCREW-MACHINE FIXING ROCKER COVER (6) A12 15255-B3430 CAP-OIL FILLER A12 15255-15953 22 15255-15953 CAP-OIL FILLER A12 23 15270-B3400 PACKING-OIL FILLER CAP A12 2 15270-11200 23 15270-11200 PACKING-OIL FILLER CAP A12 24 13270-18001 PACKING-ROCKER COVER A12 25 21200-A3001 ASSY-THERMOSTAT 82C A12 EXHAUST & EVAPO 25 21200-A3005 ASSY-THERMOSTAT 88C FOR WINTER OP A12 25 21200-78502 ASSY-THERMOSTAT 76.5C FOR TROPICAL USE OP A12 25 21200-78500 ASSY-THERMOSTAT 82C A12 CRANK 26 11060-G0300 OUTLET-WATER A12 AUTOMATIC 26 11060-G0300 OUTLET-WATER A12 MANUAL -273 3 26 11060-H7000 OUTLET-WATER A12 MANUAL 0373- 0 11060-G0300 11062-58000 WASHER-JOINT WATER OUTLET [gasket] A12 11062-18000 27 11062-18000 WASHER-JOINT WATER OUTLET [gasket] A12 28 31139-49006 BOLT-HEX M8 (2) A12 08915-1381A WASHER-SPRING (2) A12 08915-13810 29 08915-13810 WASHER-SPRING (2) A12 30 22120-U2001 ASSY-SWITCH WATER TEMP A12 MANUAL 0373- 31 24200-H7000 CLIP-SWITCH HARNESS A12 MANUAL 0373-
