Bolt kit
Revision as of 01:49, 25 August 2016; view current revision
Category: Engine
Dress up bolts, anyone? Datsun bolts are carbon steel. When substituting stainless steel bolts, be aware that SS is not as strong. That poses no problem for some exterior bolts, but SS should not be used for critical bolts - 316 Stainless has a lower tensile yield than even low carbon steel.
Also see: NES Part Numbers
* 08 NES part prefix
* 11 bolt, low carbon steel
* 12 bolt, medium carbon steel
* 13 bolt, alloy steel
* 9111 hex nut, low carbon steel
* 9151 lock washer
* 9154 plain washer
Engine Exterior
316 Stainless Steel (A4 stainless) is OK for these low-torque engine bolt parts. 316 stainless will not corrode, while 304 stainless will tarnish after some time.
OIL PAN
08110-61410 BOLT M6 [x 14] FIXING OIL PAN (12) (except GX)
08911-1062A NUT M6 FIXING OIL PAN [M6] (4)
08915-13610 WASHER-LOCK FIXING OIL PAN [M6] (16)
ROCKER COVER
08310-61612 SCREW-MACHINE FIXING ROCKER COVER [M6 X 16] (6)
08915-13610 WASHER-LOCK FIXING ROCKER COVER (6)
FRONT COVER (timing cover)
08110-64010 BOLT-HEX [M6 x 40] (6)
08915-1361A WASHER-LOCK [M6] (6)
WATER OUTLET
31139-49006 BOLT-HEX M8 (2)
08915-1381A WASHER-SPRING [M8] (2)
FUEL PUMP
08911-10810 NUT-HEX M8 (2)
08915-13810 WASHER-LOCK M8 (2)
00915-41510 WASHER-PLAIN 5/16 (2)
WATER PUMP
08110-45010 BOLT [M8 x 45] (2)
08911-10810 NUT [M8] (3)
08915-13810 WASHER-lock [M8] (5)
OIL PUMP torque: 1.1-1.7 kg-m (8-12 ft-lb)
* 316 stainless is OK, DO NOT OVERTORQUE
15036-18000 BOLT-OIL PUMP [M8 x 70mm] (2) [check length]
08110-85510 BOLT          [M8 x 55mm] (1)
08915-13810 WASHER-LOCK   [M8]        (3)
