Also see:
Part Numbers Index Main article for usage, photos, cross-reference Cowl Cowl Top Grille Rubber
Includes Sedan.1972 & Truck
18 66810-H1001 PLATE-baffle, cowl top (R.H.) 19 66811-H1001 PLATE-baffle, cowl top (L.H.)
1 66301-H1000 PANEL-COWL TOP -8012 <> 66301-H3100 66301-H3100 PANEL-COWL TOP from 71-12(truck) 71.1(sedan) 66301-G1500 PANEL-COWL TOP -8012 66301-G1900 PANEL-COWL TOP 8101- 2 65433-H1000 SEAL-HOOD HINGE (2) 3 GRILLE-COWL TOP RH 66802-H1002 S-std, T 66802-H1001 S-DX,S-GL S-GX 66802-H2303 #930 Green 66802-H2304 #931 Gold 66802-H2305 #932 Red 66802-H2306 #821 White 66802-H2307 #665 Yellow 66802-H2308 #929 Blue 66802-H2311 #003 Green 66802-H2312 #004 Metallic green 66802-H2313 #005 Metallic turkois 66802-H2315 #117 Gray 66802-H2316 #554 Green 4 GRILLE-COWL TOP LH 66803-H1002 S-std, T 66803-H1001 S-DX,S-GL S-GX 66803-H2303 #930 Green 66803-H2304 #931 Gold 66803-H2305 #932 Red 66803-H2306 #821 White 66803-H2307 #665 Yellow 66803-H2308 #929 Blue 66803-H2311 #003 Green 66803-H2312 #004 Metallic green 66803-H2313 #005 Metallic turkois 66803-H2315 #117 Gray 66803-H2316 #554 Green 5 SCREW-TAPPING M4 FOR GRILLE FITTING (per side) 08530-41212 (6) S-std, T 08530-41290 (6) S-DX,S-GL 08530-41290 (3) S-GX 08530-41690 (2) S-GX 7 66822-H1000 SEALING RUBBER-COWL TOP,FRONT (66810) 8 66810-H1001 PLATE-baffle, cowl top (R.H.) 9 66811-H1001 PLATE-baffle, cowl top (L.H.)
Sedan
1 66301-H1600 PANEL-COWL TOP SEDAN 2 65433-H1000 SEAL-HOOD HINGE (2) SEDAN 3 66802-H2313 GRILLE-COWL TOP RH TURKOIS #005 SEDAN(DX) 1270- 3 66802-H2314 GRILLE-COWL TOP RH ORANGE #006 SEDAN(DX) 1270- 3 66802-H2312 GRILLE-COWL TOP RH GREEN #004 SEDAN(DX) 1270- 3 66802-H1001 GRILLE-COWL TOP RH SEDAN(DX) 4 66803-H2312 GRILLE-COWL TOP LH GREEN #004 SEDAN(DX) 1270- 4 66803-H2313 GRILLE-COWL TOP LH TURKOIS #005 SEDAN(DX) 1270- 4 66803-H2314 GRILLE-COWL TOP LH ORANGE #006 SEDAN(DX) 1270- 4 66803-H1001 GRILLE-COWL TOP LH SEDAN(DX) 5 08510-41212 SCREW-TAPPING TYPE 1 M4X12 1 (12) SEDAN 6 66822-H1000 RUBBER-SEALING HOOD REAR SEDAN 7 66810-H1001 PLATE-BAFFLE COWL TOP RH SEDAN 8 66811-H1001 PLATE-BAFFLE COWL TOP LH SEDAN
Coupe
1 66301-H1600 PANEL-COWL TOP COUPE 2 65433-H1000 SEAL-HOOD HINGE (2) COUPE 3 66802-H1806 GRILLE-COWL TOP RH WHITE #821 COUPE 3 66802-H1807 GRILLE-COWL TOP RH YELLOW #665 COUPE 3 66802-H2307 GRILLE-COWL TOP RH YELLOW #665 COUPE 1170- 4 66802-H1807 3 66802-H1809 GRILLE-COWL TOP RH BLUE #645 COUPE 3 66802-H2309 GRILLE-COWL TOP RH BLUE #645 COUPE 1170- 4 66802-H1809 3 66802-H1810 GRILLE COWL TOP RH GREEN #940 COUPE 3 66802-H2311 GRILLE-COWL TOP,RH,GREEN #003 COUPE 3 66802-H2305 GRILLE-COWL TOP RH RED #932 COUPE 1170- 4 66802-H1805 3 66802-H2314 GRILLE-COWL TOP,RH,ORANGE #006 COUPE 3 66802-H2310 GRILLE COWL TOP RH GREEN #940 COUPE 1170- 4 66802-H1810 3 66802-H2301 GRILLE-COWL TOP RH YELLOW #926 COUPE 1170- 4 66802-H1801 3 66802-H2306 GRILLE-COWL TOP RH WHITE #821 COUPE 1170- 4 66802-H1806 3 66802-H1805 GRILLE-COWL TOP RH RED #932 COUPE 3 66802-H1801 GRILLE-COWL TOP RH YELLOW #926 COUPE 3 66802-H1800 GRILLE-COWL TOP RH WHITE #924 COUPE 3 66802-H1802 GRILLE-COWL TOP RH GRAY #928 COUPE 3 66802-H2302 GRILLE-COWL TOP RH GRAY #928 COUPE 1170- 4 66802-H1802 3 66802-H1803 GRILLE-COWL TOP RH GREEN #930 COUPE 3 66802-H2303 GRILLE-COWL TOP RH GREEN #930 COUPE 1170- 4 66802-H1803 3 66802-H1804 GRILLE-COWL TOP RH GOLD #931 COUPE 3 66802-H2304 GRILLE-COWL TOP RH GOLD #931 COUPE 1170- 4 66802-H1804 3 66802-H2300 GRILLE-COWL TOP RH WHITE #924 COUPE 1170- 4 66802-H1800 4 66803-H1809 GRILLE-COWL TOP LH BLUE #645 COUPE 4 66803-H1806 GRILLE-COWL TOP LH WHITE #821 COUPE 4 66803-H2306 GRILLE-COWL TOP LH WHITE #821 COUPE 1170- 4 66803-H1806 4 66803-H1807 GRILLE-COWL TOP LH YELLOW #665 COUPE 4 66803-H2307 GRILLE-COWL TOP LH YELLOW #665 COUPE 1170- 4 66803-H1807 4 66803-H2309 GRILLE-COWL TOP LH BLUE #645 COUPE 1170- 4 66803-H1809 4 66803-H1810 GRILLE-COWL TOP LH GREEN #940 COUPE 4 66803-H2311 GRILLE-COWL TOP,LH,GREEN #003 COUPE 4 66803-H2314 GRILLE-COWL TOP,LH,ORANGE #006 COUPE 4 66803-H2305 GRILLE-COWL TOP LH RED #932 COUPE 1170- 4 66803-H1805 4 66803-H2300 GRILLE-COWL TOP LH WHITE #924 COUPE 1170- 4 66803-H1800 4 66803-H1801 GRILLE-COWL TOP LH YELLOW #926 COUPE 4 66803-H1805 GRILLE-COWL TOP LH RED #932 COUPE 4 66803-H2301 GRILLE-COWL TOP LH YELLOW #926 COUPE 1170- 4 66803-H1801 4 66803-H1800 GRILLE-COWL TOP LH WHITE #924 COUPE 4 66803-H1802 GRILLE-COWL TOP LH GRAY #928 COUPE 4 66803-H2302 GRILLE-COWL TOP LH GREEN #928 COUPE 1170- 4 66803-H1802 4 66803-H1803 GRILLE-COWL TOP LH GREEN #930 COUPE 4 66803-H2303 GRILLE-COWL TOP LH GREEN #930 COUPE 1170- 4 66803-H1803 4 66803-H1804 GRILLE-COWL TOP LH GOLD #931 COUPE 4 66803-H2304 GRILLE-COWL TOP LH GOLD #931 COUPE 1170- 4 66803-H1804 5 08530-41212 SCREW-TAPPING M4 FOR GRILLE FITTING (6) COUPE 6 08530-41612 SCREW-TAPPING M4 FOR GRILLE FITTING (6) COUPE 7 66822-H1000 RUBBER-SPONGE HOOD REAR COUPE 8 66810-H1001 PLATE-BAFFLE COWL TOP RH COUPE 9 66811-H1001 PLATE-BAFFLE COWL TOP LH COUPE
