B140 model changes
2002 Champ model - blocky Champ decal, 1200-style indicators
2005 Champ model - small indicators, blocky Champ decal (2005-2006) spear Champ decal (2007-2008)
2001
If it's no frills, hard working muscle you need, the LDV gets the job done.Up front its got a never-say-die 47kW engine linked to an economical five-speed gearbox. While at the back, an extra tough high-tensile steel loadbox takes everything from boxes to bricks. No matter what you are loading, rear wheel drive gives power where it's needed most - directly under the load. In any conditions, from the unforgiving city to the punishing heartland. And when it's all over, it'll leave you with enough fuel to do it all over again.
2002 Model
2004 Update
From Nissan ZA web site, 2003 August, showing Champ spear graphic
2004 from dealer web site, showing Champ chunk graphic
NISSAN 1400 STANDARD Price R 70,490 CHAMP Price R 75,490 Release Date 200202 Discontinued Date 200412 Dimensions and Weight STANDARD Load 591 CHAMP Load 588 Length 3845 Ground Clearance 160 Height 1425 STANDARD Licencing Mass 758 CHAMP Licencing Mass 772 Width 1495
Engine and Gearbox Engine Layout longitudinal inline 4 Cylinders 4 Aspiration natural Valves ohv 2 valves per cylinder Bore / Stroke 76.0x77.0 Capacity 1397 Compression Ratio 9.4:1 Ignition Type electronic Gearbox Details 5 speed manual Number of Gears 5 Automatic no
Maintenance and Warranty Oil Change Intervals 15000 km Service Intervals 30000 km Warranty Period (Months) 12 * Warranty 1 year unlimited km * optional maintenance plans from 3 year/50000km to 3 year/150000km
Performance Fuel Capacity 50 Fuel Consumpsion - Highway 7.13 Fuel Consumpsion - Urban 12.26 Consumption Annual Average 9.9 Fuel Type leaded/unleaded Fuel Supply carb. dual-barrel downdraught hitachi Acceleration 0-100 Final 13.7 Top Speed Final 152 Power Output 47kw@6000 Torque 97nm@2500 Limited Slip Diff no Towing Capacity (KG) 758 STANDARD Towing Capacity (KG) 772 CHAMP Turning Circle (Meters) 8.2 Peripherals and Accesories Fog Lamps - Front yes, CHAMP Air conditioner no Radio no Metallic Paint option Options Group nis140001 Rim Size - Front 4j Rim Size - Rear 4j Drive Wheels rear Wheel Base 2300 Number of Wheels Driven 2 Tyre Size - Front 155 sr12 Tyre Size - Rear 155 sr12 Front Suspension independent struts, coils, stabiliser bar, dual acting telescopic shocks Rear Suspension live axle, semi-elliptical leaf springs, telescopic dual acting shocks Steering Type recirculating ball
2005 Model
NISSAN 1400 STANDARD Price R 70,490 CHAMP Price R 75,490 Release Date 200501 Discontinued Date 200909 small indicators
Exterior Colours: black, blue, gold, gray, green, red, silver, white
2006 Champ
2007
CHAMP Base Price R 75,490.00 (incl VAT) Maximum Power 47 @ 6000 kW at r/min Maximum Torque 97 @ 2500 Nm at r/min Power To Mass Ratio 60.88 W/kg Acceleration 16.22 sec (0-100 km/h) Max Speed 146 (km/h) Tank Capacity 45 litre Fuel Range 476 km GCM 1750 kg GVM 1360 kg Ground Clearance 160 mm LoadBox 1518x1285x415 Metallic Paint Option Optional Metallic Paint Option Price R 1050 (incl VAT) Net Load Capacity 591 kg
2008 Heritage Edition
Limited edition of 150 Champ models
See Main Article: Nissan_B140#Heritage_Edition
