Also see:
Part Numbers Index Main articless for usage, photos, cross-reference: Body Floor
サニトラ フロア パネル
Front Floor Panel
Rear Floor Panel
リア フロア パネル
16 74502-G1001 PANEL-floor, rear 17 74540-G1000 COVER ASS'Y-floor hole (up to '71-3) 74540-G1001 COVER ASS'Y-floor hole (from '71-4) 18 74546-G1001 ANGLE-floor hole (up to '71-3) (2) 74546-G1002 ANGLE-floor hole (from '71-4) (2) 19 24200-89920 CLIP (2) 20 74850-G1001 MEMBER ASS'Y-rear side (R.H.) 74851-G1000 MEMBER ASS'Y-rear side (L.H.) 21 55202-G1000 BRACKET ASS'Y-rear spring, front (R.H.) 55203-G1000 BRACKET ASS'Y-rear spring, front (L.H.) 22 55242-G1000 STOPPER ASS'Y-bumper rear (R.H.) 55243-G1000 STOPPER ASS'Y-bumper rear (L.H.) 23 55208-G1000 BRACKET ASS'Y-shackle (2) 24 20633-G1001 BRACKET-muffler mounting (2) 25 [not used for Short Bed] 26 74860-G1002 MEMBER ASS'Y-cross #1, replaced 74860-G1001 27 17241-G1000 BRACKET ASS'Y-fuel tank mounting 28 74870-G1000 MEMBER ASS'Y-cross #2 29 74870-G1002 MEMBER ASS'Y-cross #3, replaced 74870-G1001 30 74890-G1001 MEMBER ASS'Y-rear end 31 96206-G1000 BRACKET ASS'Y-license plate 96206-G1001 BRACKET ASS'Y-license plate 32 79110-G1001 PANEL ASS'Y-rear, replaced 79110-G1000 33 79100-G1000 PANEL ASSY-BACK -7803 79100-G1060 PANEL ASSY-BACK 7804- (not pictured) PANEL ASSY-BACK LOWER - See Rear Body Part Numbers
LONG BODY - parts above except: 16 74502-G1400 PANEL-floor, rear LB 17 74540-G1001 COVER ASS'Y-floor hole 17LB 74345-G1401 BRACKET ASS'Y-center bearing, upper 20 74850-G1400 MEMBER ASS'Y-rear side (R.H.) 20 74851-G1400 MEMBER ASS'Y-rear side (L.H.) 21 55202-G1400 BRACKET ASS'Y-rear spring, front (R.H.) 21 55203-G1400 BRACKET ASS'Y-rear spring, front (L.H.) 23 55208-G1400 BRACKET ASS'Y-shackle (R.H.) 23 55209-G1400 BRACKET ASS'Y-shackle (L.H.) 25 74860-G1401 MEMBER ASS'Y-cross #1 26 74867-G1400 MEMBER ASS'Y-cross #2 27 17241-G1400 BRACKET ASS'Y-fuel tank mounting bar 28 74870-G1000 MEMBER ASS'Y-cross #3 29 74880-G1400 MEMBER ASS'Y-cross #4 30 74890-G1400 MEMBER ASS'Y-rear end 31 96206-G1001 BRACKET ASS'Y-license plate 32 79110-G1001 PANEL ASS'Y-rear
LATE CATLOG - TBD 74844 BRACKET-FUEL PUMP 17241-G1000 SB 7510-8503 <2,0> 17241-G1900 17241-G1400 LB 7510-8910 17241-G1900 SB 8504- FUEL TANK MOUNT リヤヨウ 74345 BRACKET-CENTER BEARING, UPPER 74345-G1401 LB 7510-7803 <0,0> 74345-G1461 74345-G1461 LB 7804-8105 <2,0> 74345-G1900 74345-G1900 LB 8504-8908 <0,0> 74345-G1901 74345-G1901 LB 8908-
Rear Floor Fitting
11 76916-00100 PLUG-rubber 2 44 93599-14800 PLUG-floor hole 4 (op.)
