Emblem Part Numbers
Revision as of 11:55, 8 August 2016; view current revision
Categories: Body | Catalog
<-- back to Part Numbers Index
Also see:
Main article for usage, photos, cross-reference:
Badges
[hide]
Sedan
Early
Also see Grille Part Numbers#Early
RADIATOR GRILLE (SEDAN)
4 62312-H1026 SET-ORNAMENT, radiator grille
  fixing ornament
  5 08915-43410  WASHER-plain 2
  6 08915-13410  WASHER-lock 2
  7 08911-10410  NUT 2
8 62330-H2026 SET-EMBLEM, radiator grille "GL"
9 62330-H2325 SET-EMBLEM, radiator grille "GX"
  fixing radiator grille emblem
  10 62332-H2000 RETAINER-emblem
  11 08915-43410  WASHER-plain 4
  12 08915-13410  WASHER-lock 4
  13 08911-10410  NUT 4
1972
Also see Grille Part Numbers#1972
 7 62312-H3125 ORNAMENT KIT-radiator grille
 8 08915-43410  WASHER-plain 2
 9 08915-14340  WASHER-lock 2
10 08911-10410  NUT 2
11 62330-H3125 EMBLEM SET-radiator grille "DELUXE"
12 08915-43410  WASHER-plain 2
13 62330-H3325 EMBLEM SET-radiator grille "GL"
14 62330-H3425 EMBLEM SET-radiator grille "GX"
   62330-H7225 EMBLEM SET-radiator grille "GL 5 SPEED"
15 62332-H3300  RETAINER-emblem GL,GX
16 08915-43410  WASHER-plain 4 GL,GX
17 08915-13410  WASHER-lock 4 GL,GX
18 08911-10410  NUT 4 GL,GX
Coupe
48 79200-H1020 MARK-"Nissan Full Automatic" with clip
49 63845-18000  CLIP-Tubular
50 79200-H2820 MARK-"Nissan Full Automatic" with clip (from '71-Apr.)
Truck
62311 ORNAMENT-FRONT
  08915-43410 WASHER-PLAIN 2 -8910
  08915-13410 WASHER-LOCK 2 -8910
  08911-10410 NUT 2 -8910
 62312-H1026 -7803 S
 62312-G1025 7804-7907 S
 62312-G1625 7908-8503
 62312-G1660 8504-8910
 62312-G1265 8910- カクガタ NISSAN
78801 EMBLEM-SIDE REAR,RH DX, ALL.7510-8910
 76854-H1050 -8102 2 'Sunny' チューブラー トメ [tubular fasten]
 76854-G1900 8103-8910 2 'NISSAN' セッチャク トメ [adhesive fasten]
78801A CLIP-TUBULAR
 63845-18000 6 DX, ALL.7510-8102
05 see above
06 see above
28 84822-H1000 EMBLEM-trunk lid(SUNNY 1200) -73
    63845-18000 CLIP-tubular 3 DX -73
29 84823-H1000 MARK-deluxe DX -73
30  63845-18000 CLIP-tubular 2 DX -73
40 96905-15200 LABEL-leading capacity -8109
40 96905-89900 LABEL-LOADING CAPACITY 8110-8910
40 96905-89900 LABEL-LOADING CAPACITY 8910-
41 96907-G1100 LABEL-4 speed -73
42 96906-84600 LABEL-rear mane (LONG BODY)
42 96908-G1661 SB 8110- SUNNY
42 96908-G1665 SB 8110- SUNNY, LONG BODY
42 90890-G5100 8910- NISSAN
43 96906-A4600 LABEL-frigid zones (op.) カンレイチ シヨウ
LABEL
14806 LABEL-UNLEADED FUEL ONLY
      14806-89901 8910- ムエン ニ カギル
14807 STICKER-FUEL
      14807-89910
14808 LABEL-EMISSION CONTROL,A
      14808-G2200 7510-7907
      14808-H9460 7908-8109
      14808-H9470 8110-8910
      14808-95W00 8910-
21435 LABEL-CAUTION,RADIATOR
      21450-89900 8110-8504
      21435-89900 8504-8910 2
      21435-89902 8910- キヤンペ ヨウ キイロ
84815U LABEL-REAR
       96908-G1661 'SUNNY' short body 8110-
       96908-G1665 'SUNNY LONG BODY' long body 8110-
       96908-G5100 'NISSAN' 8910-
96901 PLATE-MODEL NUMBER
      99070-89909 8504-8910
96905 LABEL-LOADING CAPACITY
      96905-15200 -8109 <2,0> 96905-89900
      96905-89900 8110-
96906 LABEL-FRIGID ZONE
      96906-89900 *8110- カンレイチ シヨウ
99053 LABEL-OIL CAUTION
      96903-89921 8110-8503
      99053-G1900 8504-8910
      99053-79965 8910-
99072 PLATE-CAUTION
      48477-C0400 7510-8910 T/SIGNAL & DIM SW
      96920-89900 8110-8306 <2,0> 96920-89910
      96920-89910 8307-8910
      48477-C0400 8910-
99072M TAG-KEY CAUTION
      68215-89903 8110-8910
      68215-89901 8910-
99090 PLACARD-TIRE LIMIT
      99090-G1660 8110-8910
      99090-95W00 8910-
99099 LABEL
      21450-89915 8110-8503 LLC ヨウ30
      21450-89935*8110-8504 LLC ヨウ50
      21450-89916 8504-8910 LLC ヨウ30
      21450-89936*8504-8910 LLC ヨウ50
      21435-89915 8910- LLC ヨウ30
      21435-89945*8910- LLC ヨウ50
01 62312-H1825 SET-ORNAMENT, RADIATOR GRILLE COUPE
02  08915-43410 WASHER-PLAIN 2
03  08915-13410 WASHER-LOCK 2
04  08911-10410 NUT 2
05 84822-H1856 EMBLEM-'DATSUN 1200' TRUNK LID COUPE 84822-H1806 2
06 76854-H1600 EMBLEM-'DATSUN' BODY SIDE SEDAN,COUPE 2
08 84822-H1806 EMBLEM-'DATSUN 1200' TRUNK LID COUPE
09 79855-N2200 MARK-NISSAN AUTOMATIC SEDAN,COUPE
10 79202-H1826 SET-ORNAMENT, REAR PANEL COUPE
01 62312-H1626 SET-ORNAMENT, RADIATOR GRILLE SEDAN
07 84822-H1600 EMBLEM-'DATSUN 1200' TRUNK LID SEDAN
11 84823-H1000 MARK-DELUXE DELUXE
12 76852-H1000 BADGE-DELUXE SEDAN (DX)
