<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference Manifold
1 14003-H1900 MANIFOLD-INTAKE A12 EXHAUST -571 1 14003-H1901 MANIFOLD-INTAKE A12,CALIFORNIA 0671-0771 0 14003-H1900 1 14003-H3900 MANIFOLD-INTAKE A12,MANUAL 0771- 5 14003-H1900 1 14003-H3901 MANIFOLD-INTAKE A12,AUTO 0771- 5 14003-H1901 1 14003-H1000 MANIFOLD-INTAKE A12 CRANK 2 08216-62210 STUD FIXING CARBURETOR (4) A12 3 14004-H1930 MANIFOLD-EXHAUST A12 EXHAUST 3 14004-H3931 MANIFOLD-EXHAUST A12 0373- 4 14004-H3930 3 14004-H3950 MANIFOLD-EXHAUST A12 0671- 3 14004-H1030 MANIFOLD-EXHAUST A12 CRANK -273 3 14004-H3930 MANIFOLD-EXHAUST A12 -273 2 14004-H3950 4 08213-82810 STUD FIXING EXHAUST MANIFOLD TO EXHAUST (2) A12 14005-18001 GASKET-INTAKE TO EXHAUT MANIFOLD A12 14005-18000 5 14005-18000 GASKET-INTAKE TO EXHAUT MANIFOLD A12 6 08110-63210 BOLT INTAKE TO EXHAUT MANIFOLD (2) A12 7 01111-00032 BOLT A12 8 08915-13610 WASHER-LOCK INTAKE TO EXHAUT MANIFOLD (3) A12 9 08911-10810 NUT CYLINDER HEAD TO MANIFOLD (9) A12 10 08915-13810 WASHER-LOCK (5) A12 11 14037-32200 YOKE-MANIFOLD (4) A12 14035-K7700 GASKET-MANIFOLD TO CYLINDER HEAD A12 14035-18000 12 14035-18000 GASKET-MANIFOLD TO CYLINDER HEAD A12 13 14022-18000 SPRING-HEAT CONTROL THERMS A12 14 14025-85061 KEY-HEAT CONTROL VALVE A12 15 14026-18001 WEIGHT-COUNTER VALVE A12 16 14027-36700 WASHER-HEAT CONTROL A12 17 14047-36700 SPRING-STOPPER HEAT CONTROL A12 00933-1101A PLUG-WELCH A12 00933-11000 18 00933-11000 PLUG-WELCH A12 19 08310-51610 SCREW-SET A12 20 14006-18000 PIN-SPRING HEAT CONTROL TO INTAKE MANIF A12 21 16174-H1000 INSULATOR-CARBURETOR A12 21 16177-H1000 KIT-JOINT SEAT A12 21 16174-H3900 INSULATOR-CARBURETOR A12 0671- 21 16177-H3900 KIT-JOINT SEAT A12 0671- 22 08915-13610 WASHER-SPRING (4) A12 23 08911-10610 NUT-HEX M6 (4) A12
1973 LB110 USA Parts Catalog
