The Datsun 1200 Accelerator Pedal (gas pedal, fuel pedal) on mounted to the floor on RHD models, and suspended on LHD models.
Also see: * Throttle Cable * Pedal Box
RHD pedal bolts to the floor, whereas LHD pedal hangs free.
Throttle Cable ball-end fits into slot on end of Accelerator Pedal. Usually a clip goes over the cable ball-end. But as long as the cable is properly adjusted you can drive it for years without the clip.
full
Right-Hand Drive
The Arm is similar to LHD, but has no pedal welded on, and the spring is in a different spot.
See main article: Engine Control Part Numbers
18010-H1010 ARM-COMP,accelerator pedal AUTOMATIC * includes: 18100-H1010 ARM ASS'Y,accelerator pedal AUTO 18021-H1000 BRACKET-ACCELERATOR PEDAL SNAP RING
18010-H1000 LEVER ASSY-PEDAL [MANUAL] * includes 18215-27700 SPRING-PEDAL ROD 18135-14800 BUMPER-ACCELERATOR 18021-H1000 BRACKET-PEDAL LEVER 08310-51014 SCREW 18137-10600 RING-SNAP
18110-H1000 PEDAL-ACCELERATOR [foot rest] * 08310-51214 SCREW (2) * fixing pedal stopper 08360-63512 SCREW 08911-30610 NUT
08360-63512 SCREW
36 Machine screw, Hexagon head
06 size M6
35 mm long
Left-Hand Drive
LHD 1200s use the modern-style suspended throttle pedal. B210 RHD looks similar but is straight (B110 has a dogleg bend above the pivot).
Pedal bumper (just below Throttle Cable clip)
18010-H1902 COMP-ARM ACCELERATOR PEDAL AUTOMATIC 18100-H1602 ASSY-ARM ACCELERATOR PEDAL AUTO
18010-H1602 COMP-ARM ACCELERATOR PEDAL MANUAL 18100-H1902 ASSY-ARM ACCELERATOR PEDAL MANUAL
Above assemblies include: * 18017-H1600 PAD-ACCELERATOR PEDAL * 18021-H1600 BRACKET-ACCELERATOR PEDAL * 18215-H1601 SPRING-RETURN ACCELERATOR * 18137-10600 RING-SNAP E TYPE * 08310-S1614 SCREW-MACHINE M5 FOR BRACKET TO BODY FIX
* 18135-14800 BUMPER-ACCELERATOR PEDAL STOPPER * 18056-H1600 BOLT-PEDAL STOPPER
