<-- Back to: Lighting System
1. Exterior single element, one bottom contact
Rear T/S (turn signal) -- See Tail Lights * 23 watt Type 1073ᴳ * North America can also use 27 watt Type 1156ᴳ e.g. Wagner 1156 * Japan * 21 watt (other countries)
2. Exterior dual element, two bottom contacts
Dual-filament bulb * Front park & T/S -- See Front Combination Lamp * Rear Tail & Stop -- See Tail Lights
23/8 watt Type 1034ᴳ * Japan * North America (can also use 27/8W Type 1157) 12/5 watt * other countries
3. 10-AMP FUSE
(2 needed) 08941-11000 for Fuse Box
4. 15-AMP FUSE
(4 needed) 08941-11500 for Fuse Box
d
5. Seat Belt Lamp
USA 1972-1973 Seat belt light (on top of dash) Toshiba 12V 10W Type SV8.5 31mm long
* 26945-H4600 (not sure if this lamp only, or whole unit) Type 3175 Wagner 12100
6. Dome Lamp
10 watt (room lamp) 26736-89902 * Type SV7, ~29 mm long (pictured) seems to fit best, but are usually 3w or 5w * Type SV8 Type 5168 10 watt * SV7-8 Festoon base (pointy ends)/ LES / SV7
Some parts stores specify the larger unit (see above Type 3175) which is readily available, but the Room Lamp socket must be bent slightly to fit.
7. Instrument Panel Lamp
Twist-lock holder (7 used in round dash).
26260-89900 Wedge Socket (7 total) $3.28 USD each
These sockets fit bulbs with a W2.1x9.5d base (aka W2, miniature wedge, or T5 base. Possibly also be called W5W base).
T10 bulbs come in different wattage and socket bases, the 1200 ones use a W2.1x9.5d base, known in USA as "Miniature Wedge".
USA * 26261-89902 1.7 watt bulb (ROUND GAUGE) 2.7 watt Type 161 is often specified by aftermarket JPN B110 * 26261-89900 BULB-12V, 3.4W SQUARE METER 7 * 26261-89902 BULB-12V, 1.7W ROUND METER 7 JPN B120 * 26261-89900 7510-7803 12V-3.4W 商B113 8 3.4 watt Type 158 * 26261-89902 7804- 12V-2.7W 商B113 6 * 26711-89900 7804- 12V-1.7W 商B113 2 * 26711-89902 8910- 12V-2.7W 商B113 6 * 26711-89900 8910- 12V-1.7W 商B113 2
T10 glass with T5/W5W base * Type 194 1.0 watt * Type 161 2.7 watt
NOTE: Type 159 is identical looking, but only 1.0 watt 6.3V. In addition there are several others including lower and higher wattage versions.
8. Exterior Lamp
Side-marker lamp
* 8 watt (North America, non-flashing) Wagner 97 Sylvania 97 (9.32 watt nominal) * 6 watt (flashing, non-North America)
License lamp Sylvania 1895 Wagner 1895 (3.78 watt)
* 10 watt (Sedan, except North America) * 7.5 watt Coupe, Van 26715-89901 Ichikho * 7.5 watt Sedan USA Bailey B29.012.625 (7.5w) or [Toshiba A12V8W 6 7]
Reverse light - 10 watt
9. Instrument Panel Turn Signal
Indicators (2 needed)
* 26260-H1800 SOCKET-WITH LEAD WIRE
BA9S/W6W socket
BULBS - G14 glass with BA9S/W6W base * 26711-89900 BULB 1.7 watt (ROUND GAUGE) can use 1.9 watt Type 1445 Wagner 1445 * 26261-89900 3.4 watt (Square Gauge) Type 57
Lamp Specifications
Australia
1974 B120 Owner's Manual (Page 30 ... 30)
Bulb Chart
Head Lamp 26705-04101 Sealed beam unit (Koito) or 26705-08700 Sealed beam unit (Koito)
Front Combination Lamp - Early 26717-89920 BULB (12V-23/7W) 26261-89900 BULB (12V-3W)
Front Combination Lamp - Late 26717-89900 BULB (12V-23) [P21W] 26261-89920 BULB (12V-8/3.4W) [P21/5W???] * or 26261-89925 BULB (12V-8/3.4W) 7804-
North America
| Spec. | SAE No. | Nissan^ | |
| Headlight unit | 12V-50/40W | 6012 | 26705-04201 |
| Direction and Parking | 12V-23/8W | 1034/[*1157] | 26717-89920 |
| Side marker | 12V-8W | 67 | 26715-89902 |
| License plate | 12V-7.5W | 89 | 26715-89901 |
| Rear combo. Light Taillight Stop (brake) Turn signal Back-up light | 12V-23/8W 12V-23/8W 12V-23W 12V-23W | 1034 1034 1073/[**1156] 1073 | 26717-89920 26717-89900 |
| Meter illumination | 12V-1.7W (round gauge) | 161 | 26711-89900 |
| Wiper Knob illumination (1973) | 12V-3.4W | 158 | ? |
| Heater control ill. (1973) | 12V-3.4W | 57 | ? |
| Ignition warning | 12V-1.7W | 161 | 26711-89900 |
| Turn Signal indicator | 12V-1.7W | 161 | 26261-89902 |
| Headlight beam ind. | 12V-1.7W | 161 | 26711-89900 |
| Oil press. warning | 12V-1.7W | 161 | 26711-89900 |
| Brake warning | 12V-1.7W | 161 | 26711-89900 |
| Room light | 12V-10W | n/a | 26736-89902 |
* 1157 can replace 1034 but uses more current
** 1156 can replace type 1073
1972 USA Owners manual (Page 36 ... ):
Bulb Chart
Portugal
Opticas 12V-50/40W 12V-21/5W Luz de mudança de direcção o de presença 12V-6W Luzes laterais de mudança de direcção 12V-7.5W Luz da chapa de matricula
Conjunto de luzes traseiras 12V-5W luz de presença 12V-21W luz de stop (travões) 12V-21W luz de mudança de direcção 12V-21W luz de marcha atrás
12V-3W Luz de iluminacão do painel de instrumentos 12V-3W Luz avisadora da ignicão 12V-3W Luz indicadora dos máximos 12V-3W Luz avisadora da pressao do óleo 12V-10W Luz interior 12V-3W Luz de iluminação do relogió
