Tower bar
Revision as of 23:33, 4 May 2019; view current revision
Category: Suspension Modifications
A strut tower bar is a cool-looking piece of hardware that ties the two strut towers together. Also known as strut bar, dampener, damper bar, strut brace, or Monte Carlo bar. The performance theory is that it reduces chassis deformation on hard cornering.
25378.jpgAlbum 25378
B110 strut-top bolt circle is the same as other Nissans: 122mm diameter
Track 1200s will crack at the back of the strut towers. Not needed on a street car.
The brace can be as simple as a single piece of tubing
650.JPGAlbum 650
Low and high versions
* Flat bar
* Round bar
* Round with taper ends
* Square section tube
jeffroj taper-end bars
17946.jpgAlbum 17946 8427_4b0f59be0a461.jpgUpload click to view
high mounts point for extra clearance
17177.jpgAlbum 17177 16855.jpgAlbum 16855
high-bend bar for extra clearance
4700.jpgAlbum 4700
square tube
12329.jpgAlbum 12329 15854.jpgAlbum 15854 2443.jpgAlbum 2443
3813_4c7360cc7ea87.jpgPost 332487 11462_4d6a0436b4a3c.jpgPost 358288
Vendors
Bprojects
Bprojects
14223.jpgAlbum 14223
Titan
15878.jpgAlbum 15878
eeeCustoms
22268.jpgAlbum 22268
Nissan Prince Sporty Kit
99930-7110P
2825.jpgAlbum 2825
boofhead
13790.jpgAlbum 13790 12888.jpgAlbum 12888 10977.jpgAlbum 10977 10978.jpgAlbum 10978 10957.jpgAlbum 10957 10364.jpgAlbum 10364 10365.jpgAlbum click to view 10369.jpgAlbum 10369 10079.jpgAlbum 10079
Strut Top bar ends
10100.jpgAlbum 10100 10182.jpgAlbum 10182 10183.jpgAlbum 10183 10184.jpgAlbum 10184 11586.jpgAlbum 11586
Nismo
Nismo
Cusco
Cusco Type ST steel shaft クスコ タワーバー (part number 204 510 A) - clears A14/A15 engine
25575.jpgAlbum 25575
4053.jpgAlbum 4053
Mad Dat
Maddat Strut Brace
Maddat Tri-bar Strut Brace
174_514533f80031d.jpgPost 432419
Fumiya
Fumiya
16531.jpgAlbum 16531 16532.jpgAlbum 16532 18839.jpgAlbum 18839 19397.jpgAlbum 19397 19398.jpgAlbum 19398 19399.jpgAlbum 19399 20008.jpgAlbum 20008
low-rise
19126.jpgAlbum 19126 19127.jpgAlbum 19127
hi-rise for clearance
19946.jpgAlbum 19946 19947.jpgAlbum 19947
Toyota
1609.jpgAlbum 1609
Dimensions
1200 strut-top bolt circle: 122mm diameter
17945.jpgAlbum 17945
B110/B120 strut width center-to-center: 936 mm (36.85 inch)
22877.jpgAlbum 22877
10017.jpgAlbum 10017
Adjustable
12526_4e554e33ce7d2.jpgPost 380888 9665_4a38a05756c51.jpgPost 258967 9665_4a38a0fe99949.jpgPost 258967 9665_4ae9795ab2baf.jpgPost 288413
Stiffening Bars
engine damper
15859.jpgAlbum 15859
Crossmember bar
25646.jpgAlbum 25646
Coupe rear body stiffener
25645.jpgAlbum 25645
Rear shock tower bar
25647.jpgAlbum 25647 25648.jpgAlbum 25648
More Photos
1653.jpgAlbum 1653 1936.jpgAlbum 1936 2000.jpgAlbum 2000
Pantel B310
2400.jpgAlbum 2400 2397.jpgAlbum click to view 2398.jpgAlbum click to view
V8
2672.jpgAlbum 2672
2812.jpgAlbum 2812
510
4064.jpgAlbum 4064
sticks
6718.jpgAlbum 6718
modified Nismo bar
4011.jpgAlbum 4011 9430.jpgAlbum 9430
10987.jpgAlbum 10987 12909.jpgAlbum 12909
Laney
13492.jpgAlbum 13492
frankthedolphintrainer - extra clearance for CA18DE
16510.jpgAlbum 16510 16511.jpgAlbum 16511 16512.jpgAlbum 16512 16854.jpgAlbum 16854 16855.jpgAlbum 16855
Spreader bar
19090.jpgAlbum 19090
Strut tower-to-firewall
20810.jpgAlbum 20810
levey
21121.jpgAlbum 21121
21861.jpgAlbum 21861 21862.jpgAlbum 21862
25373.jpgAlbum 25373
strut brace, tower bar,strut bar,dampener,damper bar,brace,Monte Carlo bar not steering
