<-- back to Part Numbers Index
Also see: Main articles for usage, photos, cross-reference Grille Front Bumper Core Support Hooks Badges
Coupe
RADIATOR GRILLE (COUPE)
1 62302-H1800 GRILLE-radiator (exc. GX)
62302-H2400 GRILLE-radiator GX
2 08963-10510 NUT-type "A" (10)
1972
3 08510-51697 SCREW-with washer (4)
4 08510-52597 SCREW-with washer (6)
1970-1971
08510-51642 SCREW (4)
08915-43542 WASHER-plain (10)
08510-52542 SCREW (6)
5 62312-H1825 ORNAMENT-radiator grille
62312-H4025 ORNAMENT-radiator grille 1972
6 08915-43410 WASHER-plain (2)
7 08915-13410 WASHER-lock (2)
8 08911-10410 NUT (2)
9 62330-H2026 EMBLEM-"GL", radiator grille
62330-H3325 EMBLEM-"GL", radiator grille 1972
10 62330-H2325 SET-MARK "GX", radiator grille
62330-H7225 EMBLEM "GX 5 SPEED", radiator grille
11 08915-43410 WASHER-plain (2) (4 for 5 speed)
12 08915-13410 WASHER-lock (2) (4 for 5 speed)
13 08911-10410 NUT (2) (4 for 5 speed)
14 62322-H1001 SURROUND-radiator grille, upper
15 62323-H1001 SURROUND-radiator grille, lower
16 62324-H1001 SURROUND-radiator grille, side with rubber (R.H.)
17 62325-H1001 SURROUND-radiator grille, side with rubber (L.H.)
18 08540-41012 SCREW (6)
29 08540-41090 SCREW (10)
Sedan & Van
Original
Includes 1970-1971 Sedan and all years Van
RADIATOR GRILLE
1 62302-H1003 ASS'Y-GRILLE, radiator (exc. GX)
62302-H2300 ASS'Y-GRILLE, radiator 4GX
2 96706-B0700 SCREW-grommet, fixing radiator grille (5)
3 85104104 SCREW (5)
4 62312-H1026 SET-ORNAMENT, radiator grille
5 89154341 WASHER, plain (2)
6 89151341 WASHER, lock (2)
7 89111041 NUT (2)
8 62330-H2026 SET-EMBLEM, radiator grille "GL"
9 62330-H2325 SET-EMBLEM, radiator grille "GX"
10 62332-H2000 RETAINER-emblem
11 89154341 WASHER-plain (4)
12 89151341 WASHER-lock (4)
13 89111041 NUT (4)
14 62320-H1002 ASS'Y-RIM, head lamp (R.H.)
15 62321-H1002 ASS'Y-RIM, head lamp (L.H.)
16 96706-B0700 SCREW-grommet (4)
17 85104104 SCREW (4)
18 85304129 SCREW (2)
19 89641044 NUT-spring (2)
20 62322-H1001 SURROUND-radiator grille, upper
21 62323-H1001 SURROUND-radiator grille, lower
22 62324-H1051 SURROUND-radiator grille, side with rubber (R.H.)
23 62325-H1051 SURROUND-radiator grille, side with rubber (L.H.)
62326-H1001 RUBBER-surround (2)
24 854041012 SCREW (6)
25 85404109 SCREW (10)
1972
RADIATOR GRILLE (SEDAN) 1 62302-H3100 GRILLE ASS'Y-radiator Sedan (exc. GX) 62302-H7200 GRILLE ASS'Y-radiator (from '72-8) SGX 2 62380-H3125 FINISHER KIT-radiator grille 2 3 08964-10440 NUT-spring 2 4 08510-41642 SCREW 2 5 08915-43442 WASHER-plain 2 6 08961-24810 NUT-spring 4 7 62312-H3125 ORNAMENT KIT-radiator grille 8 08915-43410 WASHER-plain 2 9 08915-14340 WASHER-lock 2 10 08911-10410 NUT 2 11 62330-H3125 EMBLEM SET-radiator grille "DELUXE" 12 08915-43410 WASHER-plain 2 13 62330-H3325 EMBLEM SET-radiator grille "GL" 14 62330-H3425 EMBLEM SET-radiator grille "GX" 62330-H7225 EMBLEM SET-radiator grille "GL 5 SPEED" 15 62332-H3300 RETAINER-emblem GL,GX 16 08915-43410 WASHER-plain 4 GL,GX 17 08915-13410 WASHER-lock 4 GL,GX 18 08911-10410 NUT 4 GL,GX 19 96706-80700 GROMMET-screw, fixing grille 5 20 08540-41040 SCREW, fixing grille 5 21 63230-H3100 RIM-head lamp 2 22 08964-10440 NUT-spring 6 23 08543-40890 SCREW 6 24 62322-H1001 SURROUND-radiator grille, upper 25 62323-H1001 SURROUND-radiator grille, lower 26 62324-H1001 SURROUND-radiator grille, side (R.H.) 27 62325-H1001 SURROUND-radiator grille, side (L.H.) 28 08540-41012 SCREW, fixing radiator surround 6 29 08540-41090 SCREW, fixing radiator surround 10
Sunny Truck
Grille
To March 1978
1 62301 GRILLE KIT-FRONT 62302-G1000 STD 62302-H1003 DX 62302-H1003 ALL 7510-7803 2 96706-B0700 GROMMET-SCREW 5 3 08540-41040 SCREW 5 4 62312-H1026 ORNAMENT-FRONT 5 08915-43410 WASHER-plain 2 6 08915-13410 WASHER-lock 2 7 08911-10410 NUT 2 8 62410 FINISHER-HEAD LAMP,RH (RIM) 62320-G1000 STD 62320-H1002 DX 62320-H1002 ALL 商B113 7510-7803 9 62411 FINISHER-HEAD LAMP,LH (RIM) 62321-G1000 STD 62321-H1002 DX 62321-H1002 ALL 商B113 7510-7803 10 96706-B0700 GROMMET-SCREW (fixing grille) 4 11 08510-41012 SCREW (fixing grille & rim) 8 12 08530-41290 SCREW (fixing rim) 2 13 08964-10440 NUT-sping (fixing rim) 2 14 62322-H1001 MOULDING-SURROUND,UPPER 15 62323-H1001 MOULDING-SURROUND,LOWER 16 62324-H1051 MOULDING-SURROUND SIDE,RH (with rubber) 17 62325-H1051 MOULDING-SURROUND SIDE,LH (with rubber) 18 62326-H1001 SEALING RUBBER 2 19 08540-41012 SCREW 6 20 08964-41090 SCREW 10
April 1978 to October 1989
62301 GRILLE KIT-FRONT 62302-H1003 7510-7803 62302-G1060 7804-8910 62301A SCREW [fixing grille] 01461-00033 8212- 8 08915-43542 7804-8212 WASHER -8211 08510-51642 7804-8212 SCREW -8211 62301E GROMMET-SCREW 96706-B0700 7510-8503 5 62322 MOULDING-SURROUND,UPPER 62322-G1900 8304-8503 62322-H1001 8504- 62323 MOULDING-SURROUND,LOWER 62323-G1900 8304-8503 62323-G1265 2 0 62323-H1001 8504-8910 62323-G1900 2 0 62324 MOULDING-SURROUND SIDE,RH 62324-H1051 7510- 62325 MOULDING-SURROUND SIDE,LH 62325-H1051 7510- 62326 SEALING RUBBER-RH 62326-H1001 7510- 2 62813E GROMMET-SCREW 96706-B0700 7510-8910 4
SURROUND [fixing lower surround to apron] 08540-41012 SCREW 6 -8910 [fixing upper surround] snaps on to hood [fixing side surround to fender] 08964-10440 NUT 2 08530-41290 SCREW 2
From October 1989
62301 GRILLE KIT-FRONT 62312-G1265 8910- 62301A SCREW [fixing grille] 01461-00033 8212- 8 62311 See Emblem Part Numbers 62322 MOULDING-SURROUND,UPPER 62322-H1001 8504- 62322H CLIP-MOULDING 62318-01W00 8910- 4 62323 MOULDING-SURROUND,LOWER 62323-G1265 8910- 62323H CLIP-MOULDING 62380-U7400 8910 4 62324 MOULDING-SURROUND SIDE,RH 62324-H1051 7510- 62325 MOULDING-SURROUND SIDE,LH 62325-H1051 7510- 62326 SEALING RUBBER-RH 62326-H1001 7510- 2
SURROUND [fixing lower surround to apron] 08540-4105A SCREW 6 8910- [fixing upper surround] snaps on to hood [fixing side surround to fender] 08964-10440 NUT 2 08530-41290 SCREW 2
Front Bumper
To March 1978
21 62651-G1001 BUMPER ASS'Y-front STD 21 62651-H1001 BUMPER ASS'Y-front DX 21 62651-H1025 BUMPER ASSY-FRONT 7510-7803 メッキ 22 62670-H1001 STAY-front bumper (R.H.)(up to '72-6) 22 62670-H1002 STAY-front bumper (R.H.)(from '72-7) 23 62671-H1001 STAY-front bumper (L.H.)(up to '72-6) 23 62671-H1002 STAY-front bumper (L.H.)(from '72-7) fixing bumper face 24 62663-G1050 BOLT-bumper "B" 4 STD < 62663-15401 24 62663-15401 BOLT-bumper "B" 4 STD < 62663-G1050 24 62663-27700 BOLT-bumper "B" 4 DX 24 22663-27700 7510-8503 クローム メッキ(CR-10S) 2 25 08915-43610 WASHER-plain 4 26 08915-13610 WASHER-lock 4 27 08911-10610 NUT 4 fixing stay to body 28 08110-81662 BOLT (up to '72-6) 4 28 08114-22510 BOLT (from '72-7) 4 28 08124-23010 BOLT 4 < 08114-22510, 08110-81662 29 08915-53810 WASHER-plain (up to '72-6) 4 29 08915-44210 WASHER-plain (from '72-7) 4 30 08915-14210 WASHER-lock 4 supporting bumper ends 31 62672-H1001 BRACKET-front bumper (R.H.) 32 62673-H1001 BRACKET-front bumper (L.H.) 33 62663-G1050 BOLT-bumper "B" 2 STD < 62663-15401 33 62663-27700 BOLT-bumper "B" 2 STD < 62663-G1050 33 62663-15401 BOLT-bumper "B" 2 ALL 33 08360-61626 BOLT 2 7510- 34 08911-10610 NUT 2 35 08915-43610 WASHER-plain 2 36 08915-13610 WASHER-lock 2 37 08360-62014 BOLT 2 38 08915-43610 WASHER-plain 2 39 62678-21000 SHIM-bracket bumper 2 40 62682-H7000 HOOK-tie down (R.H.) -73 41 62683-H7000 HOOK-tie down (L.H.) -73
From April 1978
62650 BUMPER ASSY-FRONT 62651-H1060 7804-8910 メッキ 62651-95W00 8910- トン 62650A BOLT-CARRIAGE 62663-27700 7510-8503 クローム メッキ 4 08915-43610 WASHER-plain 4 08915-13610 WASHER-lock 4 08911-10610 NUT 4 62652 BUMPER-FRONT,RH [rubber end] 62024-G1060 7804- 62653 BUMPER-FRONT,LH [rubber end] 62025-G1060 7804- fixing rubber end to bumper 08911-10637 NUT 08360-61026 BOLT 62671 STAY-FRONT BUMPER,RH 62670-H1002 7510- 62672 STAY-FRONT BUMPER,LH 62671-H1002 7510- fixing stay to body 08124-23010 BOLT 4 08915-44210 WASHER-plain 4 08915-14210 WASHER-lock 4 62673 BRACKET-FRONT BUMPER SIDE,RH 62672-H1001 7510- 62673A BOLT 22663-G1900 8504-8910 クローム メッキ(CR-12S) 4 22663-G1205 8910- ブラック ハンッャトンウ 4 08915-13610 WASHER-lock 2 08915-43610 WASHER-plain 2 08911-10610 NUT 2 62673E SHIM-BRACKET BUMPER 62678-21000 7510- 08360-61626 BOLT 2 62678-21000 SHIM-bracket bumper 2 62674 BRACKET-FRONT BUMPER SIDE,LH 62673-H1001 7510-
Sedan
To June 1972 (1971 and 1972 Model year)
1 62302-H1003 ASSY-GRILLE,RADIATOR SEDAN 2 96706-B0700 GROMMET-SCREW,GRILLE FIX (5) SEDAN 3 08540-41012 SCREW-TAPPING,GRILLE FIX (5) SEDAN 4 62320-H1002 ASSY-RIM,HEAD LAMP,RH SEDAN 5 62321-H1002 ASSY-RIM,HEAD LAMP,LH SEDAN 6 96706-B0700 GROMMET-SCREW,RIM FIX (4) SEDAN 7 08510-41040 SCREW-TAPPING,RIM FIX (4) SEDAN 8 08530-41212 SCREW-TAPPING,RIM FIX (2) SEDAN 9 08964-10410 NUT-SPRING,RIM FIX (2) SEDAN 10 62322-H1001 SURROUND-RADIATOR GRILLE, UPPER SEDAN 11 62323-H1001 SURROUND-RADIATOR GRILLE, LOWER SEDAN 12 62324-H1001 SURROUND-RADIATOR GRILLE, SIDE,RH SEDAN 12 62324-H1051 SURROUND-RADIATOR GRILLE, SIDE,RH,W/RU SEDAN 13 62325-H1001 SURROUND-RADIATOR GRILLE, SIDE,LH SEDAN 13 62325-H1051 SURROUND-RADIATOR GRILLE, SIDE,LH,W/RU SEDAN 14 62326-H1001 RUBBER-SURROUND,RADIATOR GRILLE (2) SEDAN 15 08540-41012 SCREW-TAPPING (6) SEDAN 16 08540-41012 SCREW-TAPPING 1 (10) SEDAN 17 62651-H7000 ASSY-BUMPER,FRONT SEDAN 0772- 17 62651-H1900 ASSY-BUMPER,FRONT SEDAN 18 62670-H1001 STAY-FRONT BUMPER,FRONT,RH SEDAN 19 62671-H1001 STAY-FRONT BUMPER,FRONT,LH SEDAN 20 62670-H7000 STAY-FRONT BUMPER (2) SEDAN 0772- 21 62663-27700 BOLT-BUMPER (4) SEDAN 21 62663-18000 BOLT-BUMPER (4) SEDAN 01135-00191 BOLT-BUMPER (4) SEDAN 22 08915-43610 WASHER-PLAIN (4) SEDAN 23 08915-13610 WASHER-SPRING (4) SEDAN 24 08911-10610 NUT-HEX (4) SEDAN 25 08124-23010 BOLT-HEX (4) SEDAN 26 08134-23510 BOLT (4) COUPE 0772- 27 08915-53810 WASHER-PLAIN (4) SEDAN 28 08915-44210 WASHER-PLAIN (4) SEDAN 0772- 29 08915-14210 WASHER-LOCK (4) SEDAN 0772- 30 62680-H7000 BRACKET-BUMPER STAY FRONT,RH SEDAN 0772- 31 62681-H7000 BRACKET-BUMPER STAY FRONT,LH SEDAN 0772- 32 08110-82062 BOLT (6) SEDAN 0772- 33 08915-43810 WASHER-PLAIN (6) SEDAN 0772- 01135-00191 BOLT-BUMPER,B (4) SEDAN 34 62663-18000 BOLT-BUMPER,B (4) SEDAN 34 62663-27700 BOLT-BUMPER,B (4) SEDAN 0772- 35 08911-10610 NUT (4) SEDAN 0772- 36 08915-43610 WASHER-PLAIN (4) SEDAN 0772- 37 08915-13610 WASHER-LOCK (4) SEDAN 0772- 38 62672-H1001 BRACKET-FRONT BUMPER SIDE,RH SEDAN 39 62672-H7000 BRACKET-FRONT BUMPER,SIDE,RH SEDAN 0772- 40 62673-H1001 BRACKET-FRONT BUMPER,SIDE,LH SEDAN 41 62673-H7000 BRACKET-FRONT BUMPER,SIDE,LH SEDAN 0772- 42 62663-27700 BOLT-BUMPER (2) SEDAN 42 62663-18000 BOLT-BUMPER (2) SEDAN 43 08911-10610 NUT-HEX (2) SEDAN 44 08915-43610 WASHER-PLAIN (2) SEDAN 45 08915-13610 WASHER-LOCK (2) SEDAN 46 08360-62014 BOLT-HEX (2) SEDAN 47 62678-21000 SHIM-BRACKET (2) SEDAN 48 08915-43610 WASHER-PLAIN (2) SEDAN 49 08110-61662 BOLT-WITH LOCK WASHER (4) SEDAN 50 08915-43610 WASHER-PLAIN (4) SEDAN 51 62674-H1900 OVERRIDER-FRONT BUMPER RH SEDAN 0772-0672 52 62674-H7000 OVERRIDER-FRONT BUMPER RH SEDAN 0772- 53 62675-H1900 OVERRIDER-FRONT BUMPER LH SEDAN 0772-0672 54 62675-H7000 OVERRIDER-FRONT BUMPER LH SEDAN 0772- 55 85024-H1900 RUBBER-OVERRIDER (2) SEDAN 0772-0672 56 08114-01610 BOLT (4) SEDAN 0772- 57 08915-44010 WASHER-PLAIN (4) SEDAN 0772- 58 08915-14010 WASHER-LOCK (4) SEDAN 0772- 59 62682-H7000 HOOK-TIE DOWN,RH SEDAN 0772- 60 62683-H7000 HOOK-TIE DOWN,LH SEDAN 0772-
From July 1973 (1973 Model year)
Coupe
1 62302-H1800 GRILLE-RADIATOR COUPE 2 08963-10510 NUT-SPRING TYPE A M5 1 (10) COUPE 3 08510-51012 SCREW-TAPPING TYPE 1 M5 (4) COUPE 4 08915-43510 WASHER-PLAIN 1 (10) COUPE 5 08510-52010 SCREW-TAPPING TYPE 1 M5 (6) COUPE 6 62322-H1001 SURROUND-RADIATOR GRILLE UPPER COUPE 7 62323-H1001 SURROUND-RADIATOR GRILLE LOWER COUPE 8 62324-H1001 SURROUND-RADIATOR GRILLE SIDE RH COUPE 8 62324-H1051 SURROUND-RADIATOR GRILLE SIDE RH W/RU COUPE 2 62324-H1001 9 62325-H1001 SURROUND-RADIATOR GRILLE SIDE LH COUPE 9 62325-H1051 SURROUND-RADIATOR GRILLE SIDE LH W/RU COUPE 2 62325-H1001 10 62326-H1001 RUBBER-SURROUND RADIATOR GRILLE (2) COUPE 11 08540-41012 SCREW-TAPPING M4 (6) COUPE 12 08540-41012 SCREW-TAPPING M4 1 (10) COUPE 13 62500-H1800 ASSY-SUPPORT RADIATOR CORE COUPE 14 62510-H1800 RAIL-SUPPORT RADIATOR CORE UPPER COUPE 15 62522-H1001 STAY-HOOD CATCH COUPE 16 62610-H1800 ASSY-PANEL APRON FRONT COUPE 17 62651-H1900 ASSY-BUMPER,FRONT COUPE 17 62651-H1001 ASSY-BUMPER FRONT COUPE 2 62651-H1000 17 62651-H1000 ASSY-BUMPER FRONT COUPE 18 62651-H7000 ASSY-BUMPER,FRONT COUPE 0772- 0 62651-H1900 19 62670-H1001 STAY-FRONT BUMPER FRONT RH COUPE -672 2 20 62671-H1001 STAY-FRONT BUMPER FRONT LH COUPE -672 2 21 62670-H7000 STAY-FRONT BUMPER (2) COUPE 0772- 0 62670-H1001 22 62663-18000 BOLT-BUMPER B BUMPER TO STAY (4) COUPE 23 08915-43610 WASHER-PLAIN M6 BUMPER TO STAY (4) COUPE 24 08915-13610 WASHER-SPRING M6 BUMPER TO STAY (4) COUPE 25 08911-10610 NUT-HEX M6 BUMPER TO STAY (4) COUPE 26 08124-23010 BOLT-HEX WITH LOCK WASHER STAY TO HOOD (4) COUPE 27 08134-23510 BOLT-STAY TO HOOD LEDGE (4) COUPE 0772- 28 08915-53810 WASHER-PLAIN M8 STAY TO HOODLEDGE (4) COUPE 29 08915-44210 WASHER-PLAIN (4) COUPE 0772- 30 08915-14210 WASHER-LOOK (4) COUPE 0772- 31 62680-H7000 BRACKET-BUMPER STAY FRONT RH COUPE 0772- 32 62681-H7000 BRACKET-BUMPER STAY FRONT LH COUPE 0772- 33 08110-82062 BOLT-STAY TO BRACKET (6) COUPE 0772- 34 08915-43810 WASHER-PLAIN (6) COUPE 0772- 35 62663-27700 BOLT-BUMPER B,BUMPER TO BRACKET (4) COUPE 0772- 35 62663-18000 BOLT-BUMPER B,BUMPER TO BRACKET (4) COUPE 0772- 2 62663-27700 36 08911-10610 NUT (4) COUPE 0772- 37 08915-43610 WASHER-PLAIN (4) COUPE 0772- 38 08915-13610 WASHER-SPRING (4) COUPE 0772- 39 62672-H1001 BRACKET-FRONT BUMPER SIDE RH COUPE 40 62672-H7000 BRACKET-FRONT BUMPER SIDE RH COUPE 0772- 0 62672-H1001 41 62673-H1001 BRACKET-FRONT BUMPER SIDE LH COUPE 42 62673-H7000 BRACKET-FRONT BUMPER SIDE LH COUPE 0772- 0 62673-H1001 43 62663-27700 BOLT-BUMPER B BRACKET TO BUMPER (2) COUPE 43 62663-18000 BOLT-BUMPER B BRACKET TO BUMPER (2) COUPE 2 62663-27700 44 08911-10610 NUT-HEX M6 BRACKET TO BUMPER (2) COUPE 45 08915-43610 WASHER-PLAIN BRACKET TO BUMPER (2) COUPE 46 08915-13610 WASHER-LOCK BRACKET TO BUMPER (2) COUPE 47 08360-62014 BOLT-HEX WITH SPRING WASHER BUMPER SIDE (2) COUPE 48 62678-21000 SHIM-BRACKET BUMPER SIDE TO FENDER (2) COUPE 49 08915-43610 WASHER-PLAIN BUMPER SIDE TO FENDER (2) COUPE 50 62611-H1000 COVER-UNDER FRONT COUPE 51 08915-43610 WASHER-PLAIN (4) COUPE 52 08915-13610 WASHER-LOCK (4) COUPE 53 08110-62010 BOLT-HEX M6X1.0 (4) COUPE 54 62674-H1900 OVERRIDER-FRONT BUMPER,RH COUPE 0772- 55 62675-H1900 OVERRIDER FRONT BUMPER LH COUPE -672 2 56 62674-H7000 OVERRIDER-FRONT BUMPER,RH COUPE 0772- 0 62674-H1900 57 62675-H7000 OVERRIDER-FRONT BUMPER,LH COUPE 0772- 0 62675-H1900 58 85024-H1900 RUBBER-OVERRIDER (4) COUPE -672 2 59 08114-01610 BOLT (4) COUPE 0772- 60 08915-44010 WASHER-PLAIN (4) COUPE 0772- 61 08915-14010 WASHER-LOCK (4) COUPE 0772- 62 62682-H7000 HOOK-TIE DOWN,RH COUPE 0772- 63 62683-H7000 HOOK-TIE DOWN,LH COUPE 0772-
