Datsun 1200 uses a 38 or 40 liter petrol tank.
Capacity
- Sedan: (40 liter, 10.5 US gal)
- Coupe: (38 liter, 10 US gal)
- Wagon: (38 liter, 10 US gal)
Mounting
Sedan tank is inside boot, just behind rear seat:
Coupe tank is undernearth car, under the boot area:
Gas Cap
Fuel Sender
The fuel level 'sender' is the sensor in the tank.
See main article: Fuel Sender
Return Line
Starting in 1975, North American B210s were fitted with a fuel return line. Here's what the Nissan publication "Introduction of Datsun B210 (1975 model)" says:
Fuel return systemFor preventing abnormal fuel temperature rise, the fuel return system has been installed. In this system, fuel from the fuel tank is delivered to both the carburetor and fuel tank.
The fuel return line services to return a part of the fuel to the fuel tank to suit different engine operating requirements, preventing the possibility of fuel heated flowing through the fuel line inside the engine compartment, and elminating "percolation" inside the carburetor.
Venting
Datsun 1200 in most parts of the world vents the fuel tank to the atmosphere. A simple hose loop goes from the filler tube up above the tank and back down towards the ground. The loop is to prevent a siphoning effect.
EVAPO
In Australia after 1978, and Japan after 1974, and all years in North America 1200s used the Evaporative emissions control system.
With EVAPO, the tank is not vented directly to the air. Instead, fumes are captured by the Evaporate Emission control (EVAPO) system. For details, see Fume Control.
Filler Hose
Coupe
Sedan
Note that the USA B110 sedan tank uses a 2-piece filler hose (there's a small hose inside the bigger one). This is for the EVAPO (emissions market) vehicles:
Two-piece curved filler hose for EVAPO system
This hose is NLA (No Longer Available) in US, Canada or Japan. However, the regular single hose can be fitted as follows:
Straight one-piece filler hose for non-EVAPO system
The hose looks like this:
Filler Hose Comparo
Discussion: Need Fuel Tank!!
Sedan Tank
* Early: ventless (vents through filler hose) up to chassis number B110-145650, B110-600010 17201-H1000 ASS'Y-TANK, fuel 17201-H1001 ASS'Y-TANK, fuel (with baffle plate) > 17201-H100
* Revised: two tank vents All PB110 sedan B110 from chassis number B110-145651, B110-600011 * Fuel Sender updated at same time 17201-H1902 ASS'Y-TANK, fuel 17201-H2800 ASS'Y-TANK, fuel > 17201-H1902
Coupe Tank
Vent hose loop (end hangs free, vents to atmosphere)
Fuel sender vents to filler hose
Fuel Outlet is on bottom half of tank
US EVAPO
Expansion Tank is a liquid/vapor separator. This was replaced by a check valve in the B210 sedan, while B210 coupe continued to use the separator tank. In the B310 this tank was removed and all models used the check valve.
17350-H1801 ASSY-TANK RESERVOIR 17350-H1802 ASSY-TANK RESERVOIR
Diagram
See Coupe Fuel Tank Part Numbers
Truck Tank
17251-G1001 CAP ASS'Y-filler 17251-H1901 CAP ASS'Y-filler EVAPO 1973
EVAPO
Reservoir tanklet was added March 1973 in Japan.
1978 in Australia.
Return line was added October 1989.
Late tank, 1989 October - 1994
TANK ASSY-RESERVE 17350-G1403, 17350-G1402
* placed above main tank, up in the tray sidewall
B210 Sedan Tank is similar to B110 Sedan tank
B310
Parts Sources
- Nissan. In North America, call Ericksen Nissan's toll-free number. If Ericksen says they can't get a part let us know (click "Edit" and add it to this article). Also, if they do get the part for you, let us know that too!
- NOTE: Nissan USA is out of stock forever of the Sedan hose. But perhaps they can get the Coupe hose.
- Wreckers, if you can find a 1200 in a wrecking yard
- Friends with parts cars
- Marine supply stores, for general fuel hose and filler hose. NAPA and other old-line auto parts store carry this generic fuel-rated hose also. Trimmed to length using the old filler hose as a guide. It is tough getting it to flex into shape, but can be done.
Alloy Tanks
Fuel Cell
タンク ガソリン
