Datsun 1200s had optional AM and AM/FM radios. Original Equipment Manufacturers (OEMs) included Clarion, Hitachi, Philips and Ferrisᴳ.
Contents[hide] |
The same radio is used with either RHD or LHD 1200s, and whether round-gauge dash or rectangle-gauge
Operation
1972 USA Owners manual (Page 20 ... 20):
RADIO (Optional)
The radio has five push buttons for station selection. Other stations may be selected by the manual tuning knob.
- 1 Pull the button to be reset straight out until it stops
- 2 Then turn the tuning knob to station setting you want for the button
- 3 Push the button all the way in to lock it [to] the station setting
Radio Instruction Card
Here's a radio instruction card, for the Hitachi AM radio:
HITACHI CAR RADIO Operating Guide
OPERATION
(1) [right knob] ON-OFF SWITCH & VOLUME CONTROL (inner) (2) [right knob] TONE CONTROL (outer) (1) [left knob] TUNING CONTROL
- Turn the ON-OFF SWITCH clockwise to switch on the radio.
- To switch off the radio,turn It counterclockwise until a click is heard.
- To increase volume, turn the VOLUME CONTROL clockwise.
- Desired tone is obtained by turning the TONE CONTROL (outer).
- Turn the TUNING CONTROL, adjusting the dial pointer to the frequency of the wanted station.
HOW TO SET TUNING BUTTON FOR THE DESIRED BROADCAST
- Pinch a TUNING BUTTON located near the frequency of the desired broadcast station, and pull the button out
- Tune the radio exactly for the desired broadcast station by turning the TUNING CONTROL.
- Push the button in until a snap is heard.
Set the other buttons for the other stations respectively in the same manner as mentioned above. Now you can select the desired broadcast merely by pushing the button corresponding to the broadcast.
When the broadcast once set can not be heard well or if you want to set the button for the other station, [set it again] follow the same way as mentioned above.
GENERAL DIRECTIONS
- When your car body is over heated by strong sunlight. cool the body by driving your car for a while, then operate the radio.
- Keep the radio away from heat and moisture. Direct contact with hot objects or exposure to strong sunlight may damage the radio.
- In weak signal areas, pull out the telescopic antenna to its full length. Where signals are strong enough, push the antenna into its receptacle.
Printed in Japan 7632622
Radio Delete Plate
Perhaps most 1200s came without a radio and were factory-fitted with a blank plate.
Faceplates
Radio faceplate bezel has the brand and the dial markings (Datsun, Hitachi, Clarion or no name). Some Clarion and Philips bezels have no markings but instead have them on the radio itself.
1972 facelift radio bezel is angled to match the new dashboard. Radios are the same as 1971
Custom printed radio bezel plate
Factory Options
- Monoraul AM, single speaker
- Mono AM/FM, with single speaker
- Stereo AM/FM, with dual speakers
Stock AM Radio, Ferris - Datsun (Australia)
Stock AM Radio, Hitachi - Datsun 5⁴-16 khz ALL IC (USA, 1972)
Stock AM Radio, 5³-16 khz Clarion (Japan)
Stock AM Radio, Philips - Datsun 5-5 - 16.0 (Australia)
Stock AM/FM Radio, 5⁴-16 Clarion (JDM, 1972)
Datsun 510 AM/FM Radio 99993-00006☁ installed in 1200, Datsun Hitachi 5⁴-16 khz (USA)
Model RN-120 5³-16 khz Clarion (Japan)
5³-16 khz Clarion (Portugal)
p
Model RN-121M 5³-16 khz Clarion (Japan)
Speakers
Antenna
Stock 1200 aerial mounts along the A-pillar and is manually collapsible/extendable.
There are just three wires:
- Speaker drive -
- Speaker drive +
- ACC (power)
ACC on the Ignition Switch feeds the Radio:
Newer 1200s can use this connector, still with the same basic wiring:
Datsun B310 used this connector, still with three-wire setup:
The ones marked '?' are not used (no connection)
B14 and N14,N15,B14,S14,S15 with M30 connector
Mounting
* Factory location * Console or glovebox mounting * DIN chassis * Modern 2-shaft head units
Cassette Stereo
During the time of the B210, cassette players were offered as an option
Aux Input Radio
Late 70s/early 80s Datsun AM/FM radios have an Auxiliary input. The DIN connector was originally used as a connection for factory option external tape decks. Today it allows you to play portable CD players or iPods through the car stereo.
Europe
UKW/MW Band Radio (Western Europe)
B110
1970-1971 DX, GL, GX * 27900-H1105 KIT-RADIO, with antenna (帝国電波) ** Radio Empire changed name to Clarion December 1970 ** supercedes 27900-H1105
27900-H1112 KIT-RADIO, with antenna (日立 [Hitachi])
STD * 68470-H1000 MASK-radio (sunny mark) 1970-1971 * 68470-H3100 MASK-radio 1972 ** 08915-43510 WASHER-plain (2) ** 08915-53610 WASHER-plain (2) ** 08911-10510 NUT (2) * 27978-H1000 PLUG-RUBBER 3.6 (2) ** antenna bolt holes - A-pillar * 27979-H1000 PLUG-RUBBER 12 ** antenna cable hole - A-pillar
1972 (op.) STD * 27900-H3200 RADIO-KIT-with antenna (CLARION) * 27900-H3211 RADIO-KIT-with antenna (HITACHI) * 27900-H3213 RADIO-KIT-with antenna (HITACHI) from '72-1 1972 (op.) ALL * #27900-H3320 RADIO-KIT-with antenna (AM-FM) (CLARION)
1972 kit AM Radio, 5³-16 Clarion (JDM, 1972)
B120
B120 Options catalog C-288 1974
- 27900-H1105 Radio Kit-with antenna (CLARION)
- 27900-H1112 Radio Kit-with antenna (HITACHI)
- 27900-G1010
B120
- 27900-H1105 RADIO KIT-with antenna (Radio Empire) DX, (op.) STD
- 27900-G1011 RADIO KIT-with antenna (Hitachi) DX, (op.) STD
- 27900-G1010 RADIO KIT-with antenna (Hitachi)
- replaced 27900-H1112 RADIO KIT-with antenna
- 68470-H1000 MASK-radio STD
- 08915-53610 WASHER-plain 2
- 08911-10510 NUT 2
- 27978-H1000 PLUG-rubber (3.6ø) 2 STD [plug for a-pillar, antenna]
- 27979-H1000 PLUG-rubber (12ø) 1 STD [plug for a-pillar, antenna]
- 27900-G1101 RADIO KIT HITACHI A608 7510-7803
- 27900-G1060 RADIO KIT HITACHI A608 7804-8109
- Hitachi Model No. TM-411G
- 28001-G1660 RADIO KIT HITACHI A608 8110-8503
- 27900-H1104 RADIO KIT 8504-8910
- 27910-95W00 RADIO KIT 8910-9107 HITACHI A608
- Hitachi Model No. TM-411D
- 28011-95W00 RADIO KIT 9107- A403
- Clarion model RN-1006M
Datsun Accessory Kits
* Datsun 99993-00105 8 TRACK CAR STEREO WITH AM RADIO * Datsun 99993-00008 FM MPX CARTRIDGE TUNER
Nissan Accessory Kits
- 99993-00132 Hitachi AM/FM Radio model A-1681
- 99993-00119 Hitachi AM/FM Radio model A-1581
B110
- 27900-H1110 KIT-RADIO WITH ANTENNA (HITACHI) OP
- 27900-H1105 KIT-RADIO WITH ANTENNA (CLARION) OP
- supercedes 27363-18200
- 27900-H1102 KIT-RADIO WITH ANTENNA (CLARION) OP
- 27962-H1110 ASSY-ANTENNA OP
- 27962-H1100 ASSY-ANTENNA OP
- Same as Datsun 620 pickup
- 27984-H5001 CONDENSER-TYPE B OP
- supercedes 27984-89900
- 68470-H1100 MASK-RADIO DATSUN MARK
- 27978-H1000 PLUG-RUBBER 3.6 diameter (2)
- 27979-H1000 PLUG-RUBBER 12 diameter
- 27910-H7225 KIT-RADIO AM (CLARION) OP 0875- 27910-H6225
- 27910-H6226 KIT-RADIO AM FM MONO. (CLARION) OP 0774-0775
- 27910-H7226 KIT-RADIO AM FM MONO. (CLARION) OP 0875- 27910-H6226
- 27910-H6228 KIT-RADIO AM FM MULTI. (CLARION) OP 0774-0775
- 27910-H7227 KIT-RADIO AM FM MULTI. (CLARION) OP 0875- 27910-H6228
- 27910-H6225 KIT-RADIO MW (CLARION) OP -
- 27910-H6100 SET RADIO RECEIVER MW (CLARION) OP -
- 27910-H6205 SET RADIO RECEIVER AM FM MONO (CLARIO OP 0774-
- 27910-H6210 SET RADIO RECEIVER AM FM MULTI (CLARI OP 0774-
- 27924-H6100 ESCUTCHEON-RADIO OP -
- 27923-H5025 SET-KNOB WITH WASHER & NUT OP 0774-
- 27923-H5025 SET-KNOB WITH WASHER & NUT AM FM MULTI OP 0774-
- X3803-43700 KNOB-INNER MW (CLARION) OP -
- X3803-43800 KNOB-OUTER MW (CLARION) OP -
- 27962-H6100 ASSY-ANTENNA (CLARION) OP -176
- 27962-H6101 ASSY-ANTENNA (CLARION) OP 0276- 27962-H6100
- 27962-H6110 ASSY-ANTENNA (HITACHI) OP -
- 27962-H6111 ASSY-ANTENNA (HITACHI) OP 0476- 27962-H6110
- 27984-H5000 CONDENCER TYPE B OP -
- 27984-H5001 CONDENCER TYPE B OP - 27984-H5000
- 27933-H5010 ASSY-SPEAKER MW (HITACHI) OP -
- 27933-H5001 ASSY-SPEAKER AM FM MULTI. (CLARION) OP 0774-0775
- 27933-H5001 ASSY-SPEAKER AM FM MULTI. (CLARION) OP 0875-
- 29440-H5001 ASSY-SPEAKER AM FM MULTI. (CLARION) RE OP 0875-
- 27933-H5001 ASSY-SPEAKER MW (CLARION) OP -
- 68470-H5000 MASK-RADIO -
- 27978-H1000 PLUG-RUBBER -
- 27979-H1000 PLUG-RUBBER -
- 27979-H5000 COVER-ANTENNA OP. -
- 68480-H6200 ASSY-INDICATOR LAMP,SEAT BELT CAN -
- 68480-H7302 ASSY-INDICATOR LAMP,BELT CATALYST & F CAL 0875- 68480-H7301
- 68480-H7301 ASSY-INDICATOR LAMP,BELT CATALYST & F CAL 0974-0775 68480-H6200
- 68480-H7302 ASSY-IND LAMP,SEAT BELT, CATALYST & F FED(GFU) 1276-
- 68480-H7200 ASSY-INDICATOR LAMP,SEAT FED 0974-0776 68480-H6200
- 68480-H6200 ASSY-INDICATOR LAMP,SEAT BELT -874
- 68480-H6200 ASSY-INDICATOR LAMP,SEAT FED 0876- 68480-H7200
- F8480-H6200 ASSY-SOCKET WITH HARNESS FORINDICATOR LA -874
- 26261-89900 BULB-INDICATOR LAMP -
- 26261-89900 BULB-INDICATOR LAMP FED 0974-
- 26261-89900 BULB-INDICATOR LAMP CAL 0974-
- 27989-H5000 ASSY-BONDING WIRE OP -
- 24875-H7201 DETECTOR-DRIVE COUNTER FED 0974-
B310
- B7910-H9111 RADIO KIT-AM/FM MONO (HITACHI) OP
- B7910-H9101 RADIO KIT-AM/FM MONO (CLARION) OP
- B7910-H9161 RADIO KIT-AM/FM MPX (CLARION) OP
- B7910-H8501 RADIO KIT-AM(CLARION) OP
- 27901-W5800 RADIO UNIT-AM OP
- 27907-W5800 RADIO UNIT-AM/FM MONO OP
- 27911-W5800 RADIO UNIT-AM/FM MPX OP
- 27933-89925 KNOB SET-RADIO,OUTER/INNER OP
- 27933-89901 KNOB-RADIO,OUTER OP
- 27934-89901 KNOB-RADIO,INNER OP
- 08915-44010 WASHER-PLAIN OP
- 27939-89900 NUT OP
- 27927-H8500 BRACKET-RADIO RH OP
- 27928-H8500 BRACKET-RADIO LH OP
- 08310-50812 SCREW(FOR UNIT) OP
- 08540-51242 SCREW(FOR INST) OP
- 24210-89962 CLIP OP
- 24210-89932 CLIP OP
- 99604-H1400 CLIP OP
- 27984-K0100 CONDENSER(FOR IGN COIL) OP
- 01461-00061 SCREW-TAPPING(M6) OP
- 27984-M0900 CONDENSER(FOR REGULATOR) OP
- 08510-61612 SCREW-TAPPING(M6) OP
- 27987-W5000 WIRE-BONDING(ENGINE DASH) OP
- 27960-H9100 ANTENNA SET (CLARION) OP
- 27960-H9110 ANTENNA SET (HITACHI) OP
- B7945-H8510 SPEAKER KIT-AM/FM MONO (HITACHI) OP
- B7945-H9301 SPEAKER KIT-AM/FM MPX (CLARION) OP WAGON
- B7945-H9161 SPEAKER KIT-AM/FM MPX OP SEDAN
- B7945-H8500 SPEAKER KIT-AM/FM MONO (CLARION) OP
- B7945-H8500 SPEAKER KIT-AM (CLARION) OP
- B7945-H9101 SPEAKER KIT-AM/FM MPX (CLARION) OP COUPE
- B9315-H9200 CASSETTE DECK KIT OP
- 24325-H8663 HARNESS-ADOPTER OP
- 29337-U7800 CABLE-ADOPTER EARTH OP
- 08540-51212 SCREW OP
- 96926-H8903 MASK-CONSOLE(FOR STEREO) (BLUE) OP
- 96926-H8901 MASK-CONSOLE(FOR STEREO) (BLACK) OP
- 96926-H8902 MASK-CONSOLE(FOR STEREO) (BROWN) OP
If the hole is cut out, a DIN unit will fit
F10
- B7920-M5906 KIT-RADIO(AM/FM) (CL COUPE,OP 0278- Y B7920-M5905
- B7920-M5910 KIT-RADIO(AM/FM) (HI COUPE,OP -
- B7920-M4900 KIT-RADIO(AM) (CLARI OP -
- B7920-M5905 KIT-RADIO(AM/FM) (CL COUPE,OP -178 8
- 27911-M5905 TUNER (AM/FM) (CLARI COUPE,OP -178 8
- 27914-M5906 TUNER (AM/FM) (CLARI COUPE,OP 0278- Y 27914-M5905
- 27914-M5910 TUNER (AM/FM) (HITAC COUPE,OP -
- 27914-M4900 TUNER (AM) (CLARION) OP(SEDAN WAGON) -
- 27935-M3825 SET-KNOB WITH WASHER OP - Y 27935-M0225
- 27935-M5925 SET-KNOB WITH WASHER COUPE,OP -
- 27935-M3825 SET-KNOB WITH WASHER COUPE,OP - Y 27935-M3825
- 27935-M0225 SET-KNOB WITH WASHER OP -
- 27935-M0227 PLATE-ESCUTCHEON (FO OP -
- 27935-M5927 PLATE-ESCUTCHEON (FO COUPE,OP -
- 08313-51698 SCREW-PAN HEAD WITH COUPE,OP -
- 27933-H5001 SPEAKER COUPE,OP -
- 08510-41297 SCREW-PAN HEAD TAPPI COUPE,OP -
- 27984-M3060 SUPPRESSOR-NOISE,FOR COUPE,OP -
- 27984-M3061 SUPPRESSOR-NOISE,FOR COUPE,OP - Y 27984-M3060
- 27984-M0900 SUPPRESSOR-NOISE,C F COUPE,OP -
- 27982-M0200 TERMINAL-EARTH COUPE,OP -
- 27964-M3000 ANTENNA-PILLAR COUPE,OP -476 6
- 27964-M3001 ANTENNA-PILLAR COUPE,OP 0576- Y 27964-M3000
- 08510-51612 SCREW COUPE,OP -
- 08530-51690 SCREW COUPE,OP -
510
- 27900-21610 KIT RADIO OP. CANADA
- 27900-26110 RADIO KIT OP. USA -0768
- 27900-A0810 RADIO KIT OP. 0868-0669 supercedes 27900-26110
- 27910-A4625 RADIO KIT OP 0769- supercedes 27900-A0800
- 27910-A4626 RADIO KIT OP. 0769-0172 supercedes 27900-A0810
- 27900-N0225 RADIO KIT OP 0272- supercedes 27910-A4626
Datsun 620 Pickup
- 27914-89909 UNIT-RECEIVER,RADIO (AM) (CLARION) to 0775
- replaces 27914-89903
B10
Datsun 1000 Coupe
BC 5³-16 X100KC NISSAN CLARION (Australia)
B11
1984 Nissan B11 Sentra was found to have this Datsun AM/FM radio:
B210 radios fit in a 1200, but come with swoopy faceplates.
310
1958 Datsun 310 radio CLARION 8TRANSISTOR
Aftermarket
Vintage Aftermarket
Many classic Shaft-style car radiosᴳ will fit, even deep units. There is a lot of room under the dash.
For example: Sanyo FT-C2ᴳ auto-reverse cassette stereo
Audiovoxᴳ marketed a radio specific to the 1200 circa 1972. Audiovox was founded 1960 in USA, and purchased most of its products from sources in Asia, Europe, and the United States. There brands included Jensen, RCA and Acoustic Research. Audiovox was renamed Voxx in 2012.
Audiovox DTN-1200-FM (DTN-620-PB may also fit)
Modern 2-Shaft Receiver
A few companies still offer a Shaft-style audio receiver in a modern design, with USB and flash card memory playing MP3 and WMA, etc.
Example 2016 August Pyle In-Dash AM/FM-MPX MP3 Shaft Style Dual Knob Radio * with USB/SD Card * $45 Amazon.comᴳ![]()
For a few hundred you can get a decent retro fit style radio made by Retrosound that has positionable shafts. http://www.retrosoundusa.comᴳ
DIN
DIN chassis mount will fit in the 1200 dash if the dash frame opening is cut out a bit
In glovebox
ラジオ
Amplifier
RESPONSE Cat. No. AA-0434 2 x 150WRMS HIGH POWER CAR AMPLIFIER
Kenwood 1000WATT MAXIMUMPOWER KAC81010 Subwoofer Power Amplifier
