Propeller Shaft
Revision as of 02:18, 15 July 2008; view current revision
Category: Propeller Shaft And Differential Carrier
Datsun 1200 used two types of Propeller Shaft:
  • Replaceable U-joints up to 0273
  • Non-replaceable, from 0373
If your tailshaft has snap rings (C-shaped circlips) holding the U-joints in, they are replaceable.
Automatic driveshaft/tailshaft assembly differs from Manual Transmission. Automatic transmissions are 15mm shorter than a standard transmission, so the automatic shaft slip yoke is 15mm longer. The yoke is the part that is different. The shaft and flange are identical.
Interchange:
  • B210 with H145 Differential uses the same tailshaft
  • B210 with H150 diff use different shaft
  • B120 with H165 differential (PB210) *may* be same as B310 two-piece shaft (?)
  • Longbed Trucks use a 2-piece tailshaft
See Propeller Shaft Swaps for:
  • Part Numbers
  • Specifications, including length
  • Swap information
7662.jpg Dimensions
[hide]
Parts Numbers
B110
Shaft Assembly - Manual
  • 37000-H1001, 37000-H1000 4-speed 56 to 0872
  • 37000-H3100, 37000-H1011 4-speed 56 from 0973
  • 37000-H3100 4-speed 56 from 0373, "Shell" type (non-replaceable U-joints). Same as B210 with H145 diff
Shaft Assembly - Automatic
  • 37111-20300
U-joint Assembly
  • 37125-H1025, 37125-18025
Slip Yoke
  • 37111-18001 manual
  • 37111-20300 automatic
Flange (that bolts to H145 differential)
  • 37117-18000 (30mm from center of u-joint to end of flange)
B120
  • 01111-00051 BOLT-FIX PROPELLER SHAFT (4)
GB
Long Box
