How to test your 1978-1982 factory Datsun "matchbox" distributor, from the Nissan factory service manual.
For B310 Electronic Distributor Swap
Manual Testing
A volt-ohn-milliammeter (VOM) may be used to diagnose transistor ignition malfunctions.
Use this scale:
DC: 20V
Ohms: 1000
AC: 10V
Ohms: 50,000
If possible test with components at operating temperature -- this will help find intermittent problems that only occur when the parts are HOT.
It is not necessary to disconnect the harness connectors when performing the following tests.
Power Circuit
= Not Running
- IGN key ON, engine not running
- connect Voltmeter (20V scale) between distributor case and the "B" connection (stem of T)
Results:
- below 11.5 volts. Problem. Check fuse and wiring
- 11.5 - 12.5 volts. This test OK. Complete other tests
= Cranking
- Pull coil wire from cap and ground it
- Crank engine (key at START)
Results:
- Voltage more than 1V below Battery cranking voltage (or below 8.6V). Check ignition switch, fuse and wiring
- Voltage close to battery cranking voltage (no more than 1V less) AND better than 8.6V. This test is OK. Complete other tests.
7 Ignition Primary Circuit
- connect Voltmeter (20V scale) between distributor case and the "C" connection (head of T)
Results:
- below 11.5 volts. Problem. Proceed with Test 8
- 11.5 - 12.5 volts. This test OK. Proceed with Test 9
8 Coil Primary Circuit
- Key OFF
- coil wire removed from coil
