[[Category:Engine Mechanical]
To comply with 1981 emission standards, improve fuel economy and increase driveability, the A-series engines for USA and Canada have undergone several modifications.
Datsun 210
An A15 engine has replace the A14 engine model formerly used with the manual transmission. The A14 engine has also replaced the A15 engine in MPG models, providing a new addition to the current selection of models available for non-California and Canada destinations.
Datsun 310
An A15 engine has also replaced the A14 engine formerly used in the N10 Pulsar front wheel drive chassis.
Engine Mechanical System
To meet emission control standards and to improve combustion properties, the following modifications have been made:
- In order to increase the "skish" effect, the combustion chamber design has been modified and the lower surface area of the combustion chamber has been reduced. In conjunction with these change the valve seat has been installed in a slightly higher position.
- The spark plug has been moved 6 mm (0.24 in) closer to the center of the combustion chamber for increased ignition performance.
- Weirs have been added inside the intake port to increase the "swirl" effect. Additionally, the cross-sectional area of the port has been increased in relation to the reduction of the intake valve diameter at the bevel.
Part Numbers:
- 11041-H7285 CYLINDER HEAD ASSY B310 A15, A12A CAN 0880-
- 11041-H9500 CYLINDER HEAD ASSY B310 A15 CAL, FED 0880-
- 11041-H8700 CYLINDER HEAD ASSY B310 A14 FED, A12A CAL 0880-
Valve
To accomodate the new combustion chamber design, the intake and exhaust valves have been shortened by 4 mm (0.16 in) and the diameter of the intake valve at the bevel portion reduce from 37 mm dia. to 35 mm dia.
- 1981 length: 100 mm
- 1980 length: 104 mm
- Exhaust valve head: 30 mm
- Intake valve head 1980: 37 mm
- Intake valve head 1981: 35 mm
Part Numbers (100 mm)
- 13202-H9500 VALVE-EXHAUST 0880- [30 mm] A12A, A14, A15
- 13201-H9500 VALVE-INTAKE 0880- [35 mm] A12A, A14, A15
Piston
The crest of the piston has been redesigned to accomodate the new combustion chamber design. The piston ring groove has also been modified to match the new top ring design.
The specifications for the piston rings used in the A14 and A15 engines have been revised for lower oil consumption.
Top Ring:
- 1980 : Barrel type face 1.2 mm steel
- 1981 A14: Taper type face 2.0 mm cast iron
- 1981 A15: Taper type face 1.2 mm steel
2nd Ring:
- 1980: Taper type 2.0 mm cast iron
- 1981: Under-cut type 2.0 mm cast iron
Camshaft
The cam profile and its operating angle have been modified for increased stability during idle and increase torque at low speed.
- Duration: 248
- 1980: 256 for A14/A14, 248 A12A
- Valve lift: 5.60 mm
- 1980: 5.33 intake, 5.60 exhaust
- Overlap: 32 degrees
- 1980 A14/A14: 34 degrees
- 1980 A12A: 26 degrees
Part Number:
- 13001-H9800 CAMSHAFT 0880- A12A, A14, A15
Intake Manifold
The intake manifold has been re-designed to match the cross-sectional contour of the oblong intake port. In addition, the riser has been installed in a slightly higher position and a groove has been added to the intake ports for easier starting when the engine is cold. The manifold gasket has also been modified.
Groove at bottom of runners:
- Datsun 210: #1 and #2 branches
- Datsun 310: All branches
Fuel riser:
- Raised about 5 mm (0.20 in)
Exhaust Manifold
The 1981 exhaust manifold is based on the 1980 FED (USA, non-California) model with the following modifications:
- To increase the flow of secondary air, the diameter of the secondary air passage hole has been increased from 11 mm dia. to 18 mm dia.
- The diameter of the E.G.R. tube mounting screw has been changed from M20 x 1.5 to M22 x 1.5 for increase EGR flow
On California models, the same exhaust manifold as described here is utilized due to the adoption of an air induction system.
