Clutch
Revision as of 04:53, 12 October 2009; view current revision
Category: Clutch
Tightening Torque
  • Clutch cover bolts: 1.5 - 2.2 kg-m (10.8 - 15.9 ft. lb.)
Disc
  • SIZE ID: 13/16
  • SIZE OD: 7 1/8
  • TEETH: 18T
Service Specifications:
  • Deflection limit: 0.5 mm at 85 mm radius
  • Height Diagphragm spring end: 29-31 mm at 62 mm diameter
  • Facing depth to rivets: 0.3 mm or better
Clutch Release Bearing (release bearing, throwout bearing)
  • Bore = 1.5748
  • Outer Diameter = 2.8898
  • Width = 0.752
Throwout Bearing
Mechanical Clutch (RHD)
  1. Withdrawal lever
  2. Return spring
  3. Release bearing
IMPORTANT Grease these locations:
Hydraulic Clutch (LHD)
See Hydraulic clutch
Bearing Sleeve
Discussion: Clutch Problems
For A-series engines, there are two lengths. One is 4.5 mm longer.
For use with A12 Flywheel on A14 engine, use the longer Sleeve:
Or make your own longer sleeve:
Or just use the A14/A15 flywheel. People like the A12 flywheel because it is lighter, but you can lighten the A14 type.
Datsun Sleeve ID:
Pilot Bushing
Dimensions:
  • O.D.: 0.671"
  • Width: 0.723"
  • Bore: 0.48"
Interchange: All A-series engines
  • 1971 - 1973 B110
  • 1974 - 1978 B210
  • 1979 - 1982 B310
  • 1976 - 1978 F10
  • 1979 - 1981 N10
  • Nissan 32202-18000
  • Timkin PB22 $0.90
  • Timkin PB21 $1.57
  • Dorman 14678 $5.99
  • Dorman 690051
  • BCA/NATIONAL Part # PB21 $5.53
Adjustment
  • Cable clutch: as follows
<Hey you Aussies, help by expanding this! How exactly do you adjust a Datsun 1200 cable clutch?>
On transmission: 3-4 mm play. Inside: pad height (139.5-143.5 mm from floor). Then check pedal free play -- it must have free play to avoid burning out the clutch -- check with fingertips). Pedal play is 11-15mm
Details are in the Datsun 1200 Factory Service Manual or any Repair manual (Gregory's, etc).
http://www.rockauto.com
Clutch Kit (Clutch Pressure Plate & Driven Disc)
  • 180mm Diameter (7-1/8" Diameter); 18 Splines, 13/16"
  • BECK/ARNLEY 0619114 $78.89
  • ACDELCO 381622,88989662, 88989662 $83.79
  • RHINO PAC 06001
Nissan
  • 1974 PRESSURE PLATE A13, 694 pounds (315KG)
  • 30100-H5000 DISC. 18cm diameter
  • 30210-H5220 420KG (926 lbs) NISMO HIGH-PERFORMANCE PRESSURE PLATE for A12, A12A
  • 30210-A1200 550KG (1213 lbs) NISMO HIGH-PERFORMANCE PRESSURE PLATE for A14, A15
Centerforce
  • CF420507 for A14
  • Ball Bearing Bore=1.5748" Outer Diameter=2.8898" Width=0.752"
  • BCA 01576 $21.89
  • TIMKEN DNB01576C
Pilot Bushing
  • Bushing O.D.=0.671" Width=0.723" Bore=0.48"
  • BCA/NATIONAL PB21 $5.53
Clutch Alignment Tool (wood, plastic or metal)
  • O.D. 13/16", 18 Splines
  • DORMAN 14502 $2.58
  • 30542-H1600 COVER-DUST WITHDRAWAL LEVER (LHD)
  • 30543-H1600 BOOT-RUBBER (LHD)
Release Bearing
Bearing and spring are same: B110, B120, B210, B310 regardless of engine or tranmission type. RHD and LHD are the same.
  • 30533-H1001 SPRING-RETURN CLUTCH RELEASE
  • 30502-21000 BEARING-CLUTCH RELEASE
    • SKF N2106,N3048$32
    • BCA/National 01576
    • Timken DNB01576C $22
Bearing interchange:
  • 1971 - 1973 Datsun 1200
  • 1974 - 1978 B210
  • 1979 - 1982 B310
  • 1977 - 1988 200SX
  • 1989 - 1990 240SX
  • 1994 - 1998 240SX
  • 1975 - 1979 620 Pickup
  • 1980 - 1986 720 Pickup
  • 1986 - 1994 D21 Pickup
  • 1995 Pickup
  • 1987 - 1996 Pathfinder
  • 1974 - 1977 710
  • 1974 - 1976 Datsun 610
  • 1977 - 1981 810
  • 1970 - 1978 240Z, 260Z, 280Z
  • 1979 - 1983 280ZX
  • 1984 - 1989 300ZX
  • 1982 - 1984 Maxima
  • 1978 - 1981 510
  • 1987 - 1988 Van
Bearing Carrier
  • 30501-H1000 SLEEAVE-BEARING CLUTCH RELEASE B110
  • 30501-H1000 SLEEVE-CLUTCH RELEASE B120 SB
  • 30501-H5000 SLEEVE-CLUTCH RELEASE B120 LB
  • 30501-H5000 SLEEVE-BEARING CLUTCH RELEASE B210 JDM A12
  • 30501-H5000 SLEEVE-BEARING CLUTCH RELEASE B210 -0874 USA
  • 30501-H1000 SLEEVE-BEARING CLUTCH RELEASE B210 0974-0177 USA
  • 30501-H7000 SLEEVE-BEARING CLUTCH RELEASE B210 7607- JDM A14 F4W60L
  • 30501-H7500 SLEEVE-BEARING CLUTCH RELEASE B210 -7606 JDM A14 F4W60L
  • 30501-H7500 SLEEVE-BEARING CLUTCH RELEASE B210 0278- USA
  • 30501-H5000 SLEEVE-BEARING CLUTCH RELEASE B310 56-series
  • 30501-H7500 SLEEVE-BEARING CLUTCH RELEASE B310 60-series
  • 30501-H8560 SLEEVE-BEARING CLUTCH RELEASE B310 A12/A13 5-speed 60 series JDM
  • 30501-K0500 A14 FS5W63A JDM
  • 30411-H5000 PLATE-engine rear B110 GX-5
  • 30411-H5001 PLATE-ENGINE REAR B210 A12 JDM 1973-1974
  • 30411-H5001 PLATE-ENGINE REAR B120 SB
  • 30411-H8200 PLATE-ENGINE REAR B210 A14,A12 JDM 1975-1977
  • 30411-H8200 PLATE-ENGINE REAR B310
RHD Clutch Cable
  • 30670-H1001 CABLE ASS'Y-clutch operating B110
    • small clutch cable hole in transmission [83 cm length]
  • 30670-H5001 CABLE ASS'Y-clutch operating B210 all
    • 1-inch clutch cable hole in transmission
    • 63-series transmission JDM used hydraulic clutch
  • 30670-H8500 -7909 B310 [bracket, no nut]
  • 30670-H8510 7909- B310, 8110- Van
  • 30670-G1600 7510-8304 B120
  • 30670-G1601 8305-8910 B120
  • 30670-G1500 8910- B120
Apparently 1973-up cables interchanges. 1970-1973 are smaller.
  • 1982-1986 Stanza CA20 40.25 inches, BECK/ARNLEY Part # 0930558, ATP Part # Y348 #30670D2801, DORMAN Part # 14850 {TECHoice}
  • 1983 Sentra E15 BECK/ARNLEY Part # 0930556, ATP Part # Y327 {Clutch Cable / 29.5 inches #3067004A00}, DORMAN Part # 14849 {TECHoice}
Suppliers
