Cylinder Head Identification
Revision as of 06:20, 3 November 2009; view current revision
Category: Engine Mechanical
At first glance, all A-series cylinder heads look alike. But by careful notice of specific features you can identify the model.
Early or Late?
To determine if the head is for an early (pre-1974) or late (1974-up) engine, check for existence of an oil passage here:
Only early engine have the passage in the head here. Of course, one can have the passage drilled on a newer head, but it is a good sign.
To double-check it is an original early head, look at the outside:
Early head: oil passage boss
Late head: no oil passage boss
Port Shape
Exhaust Ports
All heads have nearly square exhaust ports.
Sizes:
Intake Ports
  • Round port 28mm: A12
  • Round port 28mm lowered: A14 GFU
  • Small Oval port 28x30mm: A13, A12A
  • Medium Oval port 28x34mm: A14
  • Large Oval port 30x34.5mm: A12GX engine
Head Front Face
  • 3-bolt
  • 4-bolt, adds high alt mount
  • 4-bolt, adds high alt mount, with air passage
  • 5-bolt, adds low alt mount
    518.jpg 776.jpg A14T 13032.jpg PICT0378.jpg H72 head
Manifold-side Bosses
  • Without boss, early B110
  • With boss, not drilled, later B110
  • With boss, drilled
X++
  • Without boss
    • 5-bolt face:
  • With boss, not drilled, front boss drilled
  • With boss, drilled, front boss undrilled
  • With boss, drilled, no front boss
Alternator Mounting
Left Side
  • B10,B110: on left side of engine, down low
    • Upper bracket bolts to front face of head
Right Side
  • B210: up high.
    • Upper bracket bolts to Upper bolt hole on head
  • B310: up low.
    • Upper bracket bolts to lower bolt hole on head
A12GX Identification
A true A12GX cylinder head has all these features:
  • Dual valve springs
  • No casting numbers
    • Ports are raised, and extend above upper intake bolts
  • 27x29 mm exhaust ports
  • closed combustion chamber - heart shaped
    • Large size combustion chamber of 29.1 cm3
  • large water holes (one under each intake port). Each hole is about the diameter of a pencil (newer heads have small holes)
  • Seven upper intake face bolts, nine bolt holes (vs only 5 for other pre-74 heads)
  • As with all pre-74 heads, Oil passage on head face (spark plug side)
    • Boss on side, between plugs 2 & 3
  • SAME valve sizes as standard A12: 29mm exhaust, 35mm intake
  • NO bosses on side between plugs 1&2 and 3&4 (that indicates a newer head)
