A12GX Carburetor Part Numbers
Revision as of 06:22, 23 December 2009; view current revision
Datsun 1200 GX used a matched pair of 38mm sidedrafts, referred to as front and rear carburetors. These are similar to S.U. brand carburetors. For more general information see Hitachi Twin Carb.
[hide]
Variations
Three variations were used in the 1970-1972 B110 JDM GX model run. All are dome-tops:
  • Original
    • 16010-H2332 CARBURETOR ASS'Y-twin, front
    • 16010-H2333 CARBURETOR ASS'Y-twin, rear
  • November 1971
    • 16010-H2334 CARBURETOR ASS'Y-twin, front (from '71-11)
    • 16010-H2335 CARBURETOR ASS'Y-twin, rear (from '71-11)
  • January 1973
    • 16010-H2336 CARBURETOR ASS'Y-twin, front (from '73-1)
    • 16010-H2337 CARBURETOR ASS'Y-twin, rear (from '73-1)
Part Names
Parts Breakdown
  • 1 16122-H2310 SHAFT ASS'Y-throttle
  • 2 16324-H2310 FILTER ASS'Y-piston
  • 3 16144-H2310 NUT ASS'Y-idle adjusting
    16144-H2311 NUT ASS'Y-idle adjusting (from '71-11)
  • 4 16145-H2310 SPRING-idle adjusting screw 2
  • 5 16355-H2310 NOZZLE ASS'Y
    16355-H2310 NOZZLE ASS'Y (from '71-11)
  • (6) 16127-H2310 PLATE ASS'Y-throttle adjusting, front
  • 6 16127-H2311 PLATE ASS'Y-throttle adjusting, rear
  • (7) 16277-H2312 LEVER ASS'Y-first idle, front
  • 7 16277-H2313 LEVER ASS'Y-first idle, rear
    16277-H2315 LEVER ASS'Y-first idle, rear (from '71-11)
    16134-H2310 LEVER ASS'Y-throttle, front
  • 8 16134-H2313 LEVER ASS'Y-throttle, rear
  • 9 16083-58000 SLEEVE 2
  • 10 16214-25610 NUT (8 radius) 2
  • 11 16116-H2310 SLEEVE 2
  • 12 16190-10401 SPRING-starter, return (B)
  • 12 16190-74310 SPRING-starter, return (A)
  • 13 16147-14611 PLATE-cam (B)
  • 13 16147-74311 PLATE-cam (A)
  • 14 16116-14610 SLEEVE (B)
  • 15 16157-14610 SPRING-connecting (B)
  • 15 16157-74310 SPRING-connecting (A)
  • 16 16238-H2310 LEVER ASS'Y-choke, front
  • 16 16238-H2311 LEVER ASS'Y-choke, rear
  • 17 16147-H2310 PLATE-connection, front
  • 17 16147-H2311 PLATE-connection, rear
  • 18 16227-H2300 ADAPTER-front
  • 18 16227-H2311 ADAPTER-rear
  • 19 16322-E3210 BOLT (8Ø) (2)
  • 20 16356-25610 PIPE-rubber, fuel (2)
  • 21 16358-E4310 CLIP-fuel pipe (4)
  • 22 16061-10400 FLOAT
  • 23 16101-H1000 VALVE ASS'Y-needle
    16101-18010 VALVE ASS'Y-needle (from '71-11)
  • 24 16062-10400 LEVER-float (up to '71-10) (2)
    from '71-11
    • 16062-H2310 LEVER-float, front (from '71-11) (1)
    • 16062-H2710 LEVER-float, rear (from '71-11) (1)
  • 25 16066-25610 SHAFT-float
  • 26 16331-10400 SCREW-nipple set
  • 27 16098-25710 FILTER
  • 28 16554-H2310 JET-needle
  • 28 16554-H2316 JET-needle (from '71-11)
  • 29 16031-A8710 PLUG-drain
  • 30 16148-H2310 CLAMP-choke, front
  • 30 16149-H2310 CLAMP-choke, rear
    16149-H2311 CLAMP-choke, rear (from '71-11)
  • 31 16346-10615 SPRING-suction
  • 32 16341-25610 NUT ASS'Y-oil cap
  • 33 16194-H2310 SPRING-throttle
    16194-H2311 SPRING-throttle (from '71-11)
    16194-H2312 SPRING-throttle (from '73-1)
Piston with Needle Jet and needle set-screw
GASKET SET
  • 16455-H2310 GASKET SET
    • A 16335-14610 PACKING (10Ø) (4) [for inlet banjo]
    • B GASKET-float chamber (2)
    • C WASHER (8Ø) (2) [for fuel drain plug]
    • D PACKING (18Ø) (2)
    • E WASHER (10Ø) (2) [for fuel needle & seat ASSY]
SCREW & WASHER "B" SET
  • 16475-H2310 SCREW & WASHER "B" SET
    • F PACKING (12.5Ø) (2) [for piston rod]
    • G WASHER (7Ø) (4) [for pump lever end]
    • H WASHER (5Ø) (2) [for lever linkage]
      WASHER (4Ø) (2)
    • I PIN-cotter (1Ø) (2) [for pump lever]
    • J WASHER-thrust (2) [for throttle shaft]
    • K BOLT (5Ø) (2) [for lever linkage]
      BOLT (5Ø) (2)
    • L WASHER-lock (7Ø) (2) [for lever linkage]
    • M SCREW-set, needle jet (2) [these screw into the piston]
SCREW & WASHER "A" SET
  • 16465-H2310 SCREW & WASHER "A" SET
    • N SCREW (5Ø x 16) (16) [for dome, etc]
    • O SCREW (5Ø x 12) (2) [for choke cable bracket]
      SCREW (4Ø x 10) (2)
      SCREW (4Ø x 8) (4)
    • P WASHER-lock (8Ø) (4) [for though-bolt which fastens float bowl to throttle body, and for throttle lever next to tubular nut]
    • Q WASHER-lock (5Ø) (18) [for choke cable bracket, dome screws, etc]
    • R WASHER-lock (4Ø) (2)
Carburetor Linkage
  • 1 08915-43810 WASHER-plain (4) [fixing carburetor to manifold]
  • 2 08915-13810 WASHER-lock (4) [fixing carburetor to manifold]
  • 3 08911-20810 NUT (4) [fixing carburetor to manifold]
  • 4 16361-H2300 SHAFT ASS'Y-throttle
  • 5 16376-H2300 BRACKET-accelerator cable
  • 6 08915-13510 WASHER-lock,fixing accelerator cable bracket 2
  • 7 08460-51000 SCREW-fixing accelerator cable bracket 2
  • 8 16031-H2300 TUBE-over flow, front
  • 9 16031-H2301 TUBE-over flow, rear
    • 16031-15801 TUBE-over flow, (Vinyl 6 x 9 x 160) 2
  • 10 14012-H2300 BRACKET-over flow tube
  • 10 14012-H2330 BRACKET-over flow tube (from '72-5)
20115.jpg 20146.jpg 20147.jpg 20148.jpg 20149.jpg 20150.jpg 20151.jpg 20152.jpg 20153.jpg 20154.jpg 20155.jpg 20156.jpg 20157.jpg 20158.jpg 20159.jpg 20160.jpg 20161.jpg 20162.jpg 20163.jpg 20164.jpg 20165.jpg 20166.jpg 20167.jpg 20168.jpg 20169.jpg 20170.jpg 20171.jpg 20172.jpg 20173.jpg 20174.jpg 20175.jpg 20176.jpg 20177.jpg
Categories:Hitachi Twin Carb
